[Ovmsdev] Nissan Leaf ZE1 - Total loss of power
Wayne Love wayne at gsjs.org
Sat Apr 12 05:18:07 HKT 2025
> Rather than the crash, it could be the subsequent boot that causes the problem.
> Previously I've caused the 2016 car to throw dashboard errors by typing "module reset" over SSH while charging was in progress. I assume this is an orderly shutdown, and hence it's the boot process that disturbs the CAN bus of an active car.
> Chris
My thinking is that the issue is caused when the module goes down. The reason that I say this is that in my instances when the module crashes it does not come back up again, you need to power cycle it for it to restart.
Is there a chance that we are seeing floating voltages on the CAN connectors when they are not actively controlled by the cpu?
Cheers
Wayne
