[Ovmsdev] High hologram usage
Thu Apr 10 01:54:06 HKT 2025
Craig,
I cannot see how the modem in your bench module "dev" could cause >8 MB
network traffic when the module has Wifi all the time, except by many
reconnects + Hologram counting these as traffic (which I think they
shouldn't and don't do), or by the module not using Wifi due to a test
or very poor signal level.
The only modem change coming to my mind is the GSM signal quality
extension by Jaime, which initially had switched good & bad signal
levels. But that wouldn't have triggered a modem reconnect, rather
reboots, and that wouldn't have gone unnoticed by you.
You can check the cellular reconnect count from "cellular status debug".
Of course that only counts reconnects that need an IP renegotiation, not
transparent transitions to other cell towers.
Looking forward to your findings.
Am 06.04.25 um 19:48 schrieb Craig Leres:
> I'm still hunting the regression that causes high hologram usage. My
> search so far shows:
> 3.3.004-298-gd00134c2 16Nov24 good
> 3.3.004-327-ge8bac6d4 31Dec24 bad
> I just built/booted 3.3.004-323-gbc1f75c9 (24Nov24). I've been letting
> test versions run at least a few days before checking the hologram
> dashboard usage graph. But I must admit, once I found a version that I
> got the charges down from $45/month (back to ~$5/month), I've been
> less aggressive in my testing.
> Craig
Am 20.02.25 um 00:06 schrieb Craig Leres via OvmsDev:
> I have three ovms modules, two are in cars and one is on the bench.
> Most of the time they are on my home wifi.
> hologram used to bill me less often than once a month. But I noticed
> recently this had increased to about once every three days. When I
> looked at usage (see attached) things changed in early January.
> I keep an archive of the builds I've run. On January 8th I upgraded
> from 3.3.004-246-ge9decc46 (September 8th, 2024) to
> 3.3.004-332-gadce9471. That seems to be when hologram usage increased.
> Last week I upgraded to 3.3.004-382-ge83be0e7 but usage still seems
> high. I looked a per-sim usage and though I put similar miles on each
> car in a month, one is 50% higher than the other. But even the dev
> unit is way higher than I would expect for a module that is *always*
> in range of wifi.
> What am I missing?
> Craig
> # ovms-z
> OVMS# cell
> MODEM Status
> Model: SIM7600
> Network Registration: RegisteredRoaming
> Provider: T-Mobile Hologram
> Signal: -85 dBm
> Mode: LTE,Online
> State: NetMode
> Mux: Status up
> PPP: Connected on channel: #2
> GPS: Connected on channel: #1
> # ovms-v
> OVMS# cell
> MODEM Status
> Model: SIM7600
> Signal: -79 dBm
> Mode: LTE,Online
> State: NetMode
> Mux: Status up
> # dev
> OVMS# cell
> MODEM Status
> Model: SIM7600
> Signal: -85 dBm
> Mode: LTE,Online
> State: NetMode
> Mux: Status up
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250409/4c566202/attachment.sig>
