[Ovmsdev] High hologram usage
Craig Leres leres at xse.com
Fri Apr 11 01:16:13 HKT 2025
On 4/9/25 10:54, Michael Balzer via OvmsDev wrote:
> I cannot see how the modem in your bench module "dev" could cause >8 MB
> network traffic when the module has Wifi all the time, except by many
> reconnects + Hologram counting these as traffic (which I think they
> shouldn't and don't do), or by the module not using Wifi due to a test
> or very poor signal level.
> The only modem change coming to my mind is the GSM signal quality
> extension by Jaime, which initially had switched good & bad signal
> levels. But that wouldn't have triggered a modem reconnect, rather
> reboots, and that wouldn't have gone unnoticed by you.
> You can check the cellular reconnect count from "cellular status debug".
> Of course that only counts reconnects that need an IP renegotiation, not
> transparent transitions to other cell towers.
> Looking forward to your findings.
The version that causes problems for me is 3.3.004-324-g367f6b95
All modules are using a lot more cellular data but one in particular
stands out. It's the one with the lowest wifi dBm but it's not *that*
bad, but it makes me wonder if there is some kind of wifi power saving
that's making wifi frequently unavailable causing cellular data usage
(combined with something in this version that is 10X as chatty -- I
suspect fixing this will get my usage back down).
		Craig
# ovms-dev
OVMS# wifi
Power: on
Mode: Client mode
STA SSID: Team America (-30.6 dBm) [fixed]
   MAC: 94:b9:7e:ff:ff:ff
   IP: 172.16.1.299/255.255.255.0
   GW: 172.16.1.1
   AP: 30:87:d9:ff:ff:ff
# ovms-v
OVMS# wifi
Power: on
Mode: Client mode
STA SSID: Team America (-60.7 dBm) [fixed]
   IP: 172.16.1.298/255.255.255.0
   GW: 172.16.1.1
# ovms-z
OVMS# wifi
Power: on
Mode: Client mode
STA SSID: Team America (-64.7 dBm) [fixed]
   MAC: 24:d7:eb:ff:ff:ff
   IP: 172.16.1.297/255.255.255.0
   GW: 172.16.1.1
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250410/1d17583d/attachment-0001.png>
