[Ovmsdev] High hologram usage
Fri Apr 11 04:30:52 HKT 2025
Am 10.04.25 um 19:16 schrieb Craig Leres:
> On 4/9/25 10:54, Michael Balzer via OvmsDev wrote:
>> I cannot see how the modem in your bench module "dev" could cause >8
>> MB network traffic when the module has Wifi all the time, except by
>> many reconnects + Hologram counting these as traffic (which I think
>> they shouldn't and don't do), or by the module not using Wifi due to
>> a test or very poor signal level.
>> The only modem change coming to my mind is the GSM signal quality
>> extension by Jaime, which initially had switched good & bad signal
>> levels. But that wouldn't have triggered a modem reconnect, rather
>> reboots, and that wouldn't have gone unnoticed by you.
>> You can check the cellular reconnect count from "cellular status
>> debug". Of course that only counts reconnects that need an IP
>> renegotiation, not transparent transitions to other cell towers.
>> Looking forward to your findings.
> The version that causes problems for me is 3.3.004-324-g367f6b95
That would be commit 367f6b950f62adef04c8c877f5e29889e6e22c64, which
only included minor changes to the e-Up module, so that can be ruled out
as the causing commit.
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/367f6b950f62adef04c8c877f5e29889e6e22c64
> All modules are using a lot more cellular data but one in particular
> stands out. It's the one with the lowest wifi dBm but it's not *that*
> bad, but it makes me wonder if there is some kind of wifi power saving
> that's making wifi frequently unavailable causing cellular data usage
> (combined with something in this version that is 10X as chatty -- I
> suspect fixing this will get my usage back down).
Did you check your network wifi SQ & reconnect settings?
Not that they would make any difference from that commit, but maybe it's
not the commit but some random Wifi fluctuation causing an occasional
switch to cellular.
That should be clearly visible in the logs though.
>         Craig
> # ovms-dev
> OVMS# wifi
> Power: on
> Mode: Client mode
> STA SSID: Team America (-30.6 dBm) [fixed]
>   MAC: 94:b9:7e:ff:ff:ff
>   IP: 172.16.1.299/255.255.255.0
>   GW: 172.16.1.1
>   AP: 30:87:d9:ff:ff:ff
> # ovms-v
> OVMS# wifi
> Power: on
> Mode: Client mode
> STA SSID: Team America (-60.7 dBm) [fixed]
>   IP: 172.16.1.298/255.255.255.0
>   GW: 172.16.1.1
> # ovms-z
> OVMS# wifi
> Power: on
> Mode: Client mode
> STA SSID: Team America (-64.7 dBm) [fixed]
>   MAC: 24:d7:eb:ff:ff:ff
>   IP: 172.16.1.297/255.255.255.0
>   GW: 172.16.1.1
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250410/9f27cb2e/attachment.sig>
