[Ovmsdev] High hologram usage
Craig Leres
leres at xse.com
Fri Apr 11 04:44:43 HKT 2025
On 4/10/25 13:30, Michael Balzer via OvmsDev wrote:
> Am 10.04.25 um 19:16 schrieb Craig Leres:
>> On 4/9/25 10:54, Michael Balzer via OvmsDev wrote:
>>> I cannot see how the modem in your bench module "dev" could cause >8
>>> MB network traffic when the module has Wifi all the time, except by
>>> many reconnects + Hologram counting these as traffic (which I think
>>> they shouldn't and don't do), or by the module not using Wifi due to
>>> a test or very poor signal level.
>>> The only modem change coming to my mind is the GSM signal quality
>>> extension by Jaime, which initially had switched good & bad signal
>>> levels. But that wouldn't have triggered a modem reconnect, rather
>>> reboots, and that wouldn't have gone unnoticed by you.
>>> You can check the cellular reconnect count from "cellular status
>>> debug". Of course that only counts reconnects that need an IP
>>> renegotiation, not transparent transitions to other cell towers.
>>> Looking forward to your findings.
>> The version that causes problems for me is 3.3.004-324-g367f6b95
> That would be commit 367f6b950f62adef04c8c877f5e29889e6e22c64, which
> only included minor changes to the e-Up module, so that can be ruled out
> as the causing commit.
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/
> commit/367f6b950f62adef04c8c877f5e29889e6e22c64
My testing found:
3.3.004-323-gbc1f75c9 24Nov24 good
3.3.004-324-g367f6b95 25Nov24 BAD
When I run:
git diff bc1f75c9 367f6b95
I see a *lot* more changes than in the url you show above.
I guess there are somehow multiple commits hidden in the range between
323 and 324?
>> All modules are using a lot more cellular data but one in particular
>> stands out. It's the one with the lowest wifi dBm but it's not *that*
>> bad, but it makes me wonder if there is some kind of wifi power saving
>> that's making wifi frequently unavailable causing cellular data usage
>> (combined with something in this version that is 10X as chatty -- I
>> suspect fixing this will get my usage back down).
> Did you check your network wifi SQ & reconnect settings?
I don't know what those are (and it seems to be somewhat of a POLA
violation that the default config would use 10X the cellular data
(especially for modules that are on wifi).
> Not that they would make any difference from that commit, but maybe it's
> not the commit but some random Wifi fluctuation causing an occasional
> switch to cellular.
> That should be clearly visible in the logs though.
I guess I have more commit hashes to test.
Craig
