[Ovmsdev] High hologram usage
Fri Apr 11 05:12:16 HKT 2025
Am 10.04.25 um 22:44 schrieb Craig Leres:
> On 4/10/25 13:30, Michael Balzer via OvmsDev wrote:
>> Am 10.04.25 um 19:16 schrieb Craig Leres:
>>> On 4/9/25 10:54, Michael Balzer via OvmsDev wrote:
>>>> I cannot see how the modem in your bench module "dev" could cause
>>>> >8 MB network traffic when the module has Wifi all the time, except
>>>> by many reconnects + Hologram counting these as traffic (which I
>>>> think they shouldn't and don't do), or by the module not using Wifi
>>>> due to a test or very poor signal level.
>>>> The only modem change coming to my mind is the GSM signal quality
>>>> extension by Jaime, which initially had switched good & bad signal
>>>> levels. But that wouldn't have triggered a modem reconnect, rather
>>>> reboots, and that wouldn't have gone unnoticed by you.
>>>> You can check the cellular reconnect count from "cellular status
>>>> debug". Of course that only counts reconnects that need an IP
>>>> renegotiation, not transparent transitions to other cell towers.
>>>> Looking forward to your findings.
>>> The version that causes problems for me is 3.3.004-324-g367f6b95
>> That would be commit 367f6b950f62adef04c8c877f5e29889e6e22c64, which
>> only included minor changes to the e-Up module, so that can be ruled
>> out as the causing commit.
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/
>> commit/367f6b950f62adef04c8c877f5e29889e6e22c64
> My testing found:
>     3.3.004-323-gbc1f75c9    24Nov24 good
>     3.3.004-324-g367f6b95    25Nov24 BAD
> When I run:
>     git diff bc1f75c9 367f6b95
> I see a *lot* more changes than in the url you show above.
> I guess there are somehow multiple commits hidden in the range between
> 323 and 324?
bc1f75c9 is not a master branch commit… it's a merge of the master state
470979369be56fe18eae0df90f1619afdd27e850 into Dimitrie's SmartEQ
development branch.
I'd recommend strictly sticking to the master branch. git bisect
normally does that by itself, so I guess you're doing a manual search?
>>> All modules are using a lot more cellular data but one in particular
>>> stands out. It's the one with the lowest wifi dBm but it's not
>>> *that* bad, but it makes me wonder if there is some kind of wifi
>>> power saving that's making wifi frequently unavailable causing
>>> cellular data usage (combined with something in this version that is
>>> 10X as chatty -- I suspect fixing this will get my usage back down).
>> Did you check your network wifi SQ & reconnect settings?
> I don't know what those are (and it seems to be somewhat of a POLA
> violation that the default config would use 10X the cellular data
> (especially for modules that are on wifi).
The defaults do not cause any issues, my suspicion is you maybe
accidentally changed them during some test.
The defaults are shown here:
https://docs.openvehicles.com/en/latest/userguide/wifi.html#wifi-signal-quality
>> Not that they would make any difference from that commit, but maybe
>> it's not the commit but some random Wifi fluctuation causing an
>> occasional switch to cellular.
>> That should be clearly visible in the logs though.
> I guess I have more commit hashes to test.
>         Craig
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250410/71e0e0de/attachment-0001.sig>
