[Ovmsdev] High hologram usage
Craig Leres
leres at xse.com
Fri Apr 11 05:21:23 HKT 2025
On 4/10/25 14:12, Michael Balzer via OvmsDev wrote:
> Am 10.04.25 um 22:44 schrieb Craig Leres:
>> On 4/10/25 13:30, Michael Balzer via OvmsDev wrote:
>>> Am 10.04.25 um 19:16 schrieb Craig Leres:
>>>> On 4/9/25 10:54, Michael Balzer via OvmsDev wrote:
>>>>> I cannot see how the modem in your bench module "dev" could cause
>>>>> >8 MB network traffic when the module has Wifi all the time, except
>>>>> by many reconnects + Hologram counting these as traffic (which I
>>>>> think they shouldn't and don't do), or by the module not using Wifi
>>>>> due to a test or very poor signal level.
>>>>> The only modem change coming to my mind is the GSM signal quality
>>>>> extension by Jaime, which initially had switched good & bad signal
>>>>> levels. But that wouldn't have triggered a modem reconnect, rather
>>>>> reboots, and that wouldn't have gone unnoticed by you.
>>>>> You can check the cellular reconnect count from "cellular status
>>>>> debug". Of course that only counts reconnects that need an IP
>>>>> renegotiation, not transparent transitions to other cell towers.
>>>>> Looking forward to your findings.
>>>> The version that causes problems for me is 3.3.004-324-g367f6b95
>>> That would be commit 367f6b950f62adef04c8c877f5e29889e6e22c64, which
>>> only included minor changes to the e-Up module, so that can be ruled
>>> out as the causing commit.
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/
>>> commit/367f6b950f62adef04c8c877f5e29889e6e22c64
>> My testing found:
>> 3.3.004-323-gbc1f75c9 24Nov24 good
>> 3.3.004-324-g367f6b95 25Nov24 BAD
>> When I run:
>> git diff bc1f75c9 367f6b95
>> I see a *lot* more changes than in the url you show above.
>> I guess there are somehow multiple commits hidden in the range between
>> 323 and 324?
> bc1f75c9 is not a master branch commit… it's a merge of the master state
> 470979369be56fe18eae0df90f1619afdd27e850 into Dimitrie's SmartEQ
> development branch.
> I'd recommend strictly sticking to the master branch. git bisect
> normally does that by itself, so I guess you're doing a manual search?
>>>> All modules are using a lot more cellular data but one in particular
>>>> stands out. It's the one with the lowest wifi dBm but it's not
>>>> *that* bad, but it makes me wonder if there is some kind of wifi
>>>> power saving that's making wifi frequently unavailable causing
>>>> cellular data usage (combined with something in this version that is
>>>> 10X as chatty -- I suspect fixing this will get my usage back down).
>>> Did you check your network wifi SQ & reconnect settings?
>> I don't know what those are (and it seems to be somewhat of a POLA
>> violation that the default config would use 10X the cellular data
>> (especially for modules that are on wifi).
> The defaults do not cause any issues, my suspicion is you maybe
> accidentally changed them during some test.
> The defaults are shown here: https://docs.openvehicles.com/en/latest/
> userguide/wifi.html#wifi-signal-quality
I think this says I haven't set anything in the "network" param:
OVMS# config list network
network (readable writeable)
dns:
(all three modules are the same).
I'm now testing 3.3.004-313-g78a49a59 (which is older than
3.3.004-323-gbc1f75c9, yet another git annoyance for me that the hashes
are not chronological...) But I think it has one change that
3.3.004-313-g78a49a59 does not.
Craig
