[Ovmsdev] High hologram usage
Craig Leres leres at xse.com
Thu Apr 17 01:07:32 HKT 2025
On 4/10/25 14:21, Craig Leres via OvmsDev wrote:
> I'm now testing 3.3.004-313-g78a49a59 (which is older than 3.3.004-323-
> gbc1f75c9, yet another git annoyance for me that the hashes are not
> chronological...) But I think it has one change that 3.3.004-313-
> g78a49a59 does not.
It looks like 78a49a59 is the source of my hologram usage increase. I
see these:
     +  m_updatetime_keepalive = 29*60;
     +  m_legacy_event_topic = true;
But m_legacy_event_topic doesn't look like it has an impact
(mg_mqtt_publish() still gets called).
However, this worries me:
+    [server.v3] updatetime.keepalive -- Max number of seconds to allow
the MQTT connection to be idle before
+                                        sending PINGREQ. Should be set
slightly shorter than the network's
+                                        NAT timeout and the timeout of
your MQTT server. If these are unknown
+                                        you can use trial and error.
Symptoms of keepalive being too high are
+                                        a lack of metric updates after
a certain point, or "Disconnected from
+                                        OVMS Server V3" appearing in
the log. In previous releases this used
+                                        the Mongoose default of 60. New
default value 1740 aligns with
+                                        observed Hologram timeout of 1800.
but, again, not clear how it can drive up cellular usage when I'm on
wifi. (Unless there is some kind of wifi-sleep mode happening that
causes cellular to be used?) So maybe this is just triggering a
previously latent bug?
Anyway, I don't see how to disable this short of commenting code out.
		Craig
OVMS# config list server.v3
server.v3 (readable writeable)
   port:
   server: example.net
   tls: yes
   topic.prefix:
   updatetime.connected:
   updatetime.idle:
   user: fred
