[Ovmsdev] How I got sphinx working on ubuntu 23.1 + WSL
Wed Nov 20 15:08:16 HKT 2024
Mark,
I can login to readthedocs.com using my Github account (dexterbg).
Regarding the build issue, I'd suspect an error in the requirements.txt
file. I didn't change the other lines, but wondered why it defines these
requirements with maximum version numbers:
mistune<2.0.0
requests<2.29.0
Was that necessary for m2r2? If so, maybe try without, so pip determines
the best match?
Manually installing sphinx_mdinclude on my machine produced this
constellation:
sphinx_mdinclude              0.6.2
mistune                       3.0.2
requests                      2.32.3
Am 20.11.24 um 01:01 schrieb Mark Webb-Johnson:
> Michael,
> Yes, readthedocs is broken. But seems to have had various problems
> building the docs for the past few weeks (although more to do with
> errors in the docs files before).
> Build logs shown below. Seems to be a dependency problem (probably
> docutils vs sphinx_mdinclude). I can’t see a trivial solution (it was
> painful enough to get it working with m2r), and am out of time now,
> but will try again tonight.
> P.S. I’ve added your eMail to the readthedocs notification list so you
> see build notifications. If you create an account on readthedocs.com
> <http://readthedocs.com>, I can also add you as a maintainer there, if
> it helps.
>     Read the Docs build information
>     Build id: 26335608
>     Project: ovms
>     Version: latest
>     Commit: 1f863527d0a593fe8b10d2faee5cc0e04da4a843
>     Date: 2024-11-19T23:56:17.734263Z
>     State: finished
>     Success: False
>     [rtd-command-info] start-time: 2024-11-19T23:56:18.277210Z, end-time: 2024-11-19T23:56:22.276851Z, duration: 3, exit-code: 0
>     git clone --depth 1https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3.git  .
>     Cloning into '.'...
>     [rtd-command-info] start-time: 2024-11-19T23:56:22.296787Z, end-time: 2024-11-19T23:56:24.339706Z, duration: 2, exit-code: 0
>     git fetch origin --force --prune --prune-tags --depth 50 refs/heads/master:refs/remotes/origin/master
>     [rtd-command-info] start-time: 2024-11-19T23:56:24.414382Z, end-time: 2024-11-19T23:56:25.042773Z, duration: 0, exit-code: 0
>     git checkout --force origin/master
>     Note: switching to 'origin/master'.
>     You are in 'detached HEAD' state. You can look around, make experimental
>     changes and commit them, and you can discard any commits you make in this
>     state without impacting any branches by switching back to a branch.
>     If you want to create a new branch to retain commits you create, you may
>     do so (now or later) by using -c with the switch command. Example:
>        git switch -c <new-branch-name>
>     Or undo this operation with:
>        git switch -
>     Turn off this advice by setting config variable advice.detachedHead to false
>     HEAD is now at 1f86352 Include docutils, without specific version
>     [rtd-command-info] start-time: 2024-11-19T23:56:25.068777Z, end-time: 2024-11-19T23:56:25.129267Z, duration: 0, exit-code: 0
>     cat .readthedocs.yaml
>     # .readthedocs.yaml
>     # Read the Docs configuration file
>     # Seehttps://docs.readthedocs.io/en/stable/config-file/v2.html  for details
>     # Required
>     version: 2
>     # Set the version of Python and other tools you might need
>     build:
>        os: ubuntu-22.04
>        tools:
>          python: "3.11"
>     # Build documentation in the docs/ directory with Sphinx
>     sphinx:
>        configuration: docs/source/conf.py
>     # We recommend specifying your dependencies to enable reproducible builds:
>     #https://docs.readthedocs.io/en/stable/guides/reproducible-builds.html
>     python:
>        install:
>          - requirements: docs/source/requirements.txt
>     [rtd-command-info] start-time: 2024-11-19T23:56:30.973717Z, end-time: 2024-11-19T23:56:31.050053Z, duration: 0, exit-code: 0
>     asdf global python 3.11.10
>     [rtd-command-info] start-time: 2024-11-19T23:56:31.420254Z, end-time: 2024-11-19T23:56:32.502084Z, duration: 1, exit-code: 0
>     python -mvirtualenv $READTHEDOCS_VIRTUALENV_PATH
>     created virtual environment CPython3.11.10.final.0-64 in 772ms
>        creator CPython3Posix(dest=/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest, clear=False, no_vcs_ignore=False, global=False)
>        seeder FromAppData(download=False, pip=bundle, setuptools=bundle, wheel=bundle, via=copy, app_data_dir=/home/docs/.local/share/virtualenv)
>          added seed packages: pip==23.1, setuptools==67.6.1, wheel==0.40.0
>        activators BashActivator,CShellActivator,FishActivator,NushellActivator,PowerShellActivator,PythonActivator
>     [rtd-command-info] start-time: 2024-11-19T23:56:32.536062Z, end-time: 2024-11-19T23:56:46.548826Z, duration: 14, exit-code: 0
>     python -m pip install --upgrade --no-cache-dir pip setuptools
>     Requirement already satisfied: pip in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (23.1)
>     Collecting pip
>        Downloading pip-24.3.1-py3-none-any.whl (1.8 MB)
>           ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.8/1.8 MB 9.8 MB/s eta 0:00:00
>     Requirement already satisfied: setuptools in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (67.6.1)
>     Collecting setuptools
>        Downloading setuptools-75.5.0-py3-none-any.whl (1.2 MB)
>           ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.2/1.2 MB 21.1 MB/s eta 0:00:00
>     Installing collected packages: setuptools, pip
>        Attempting uninstall: setuptools
>          Found existing installation: setuptools 67.6.1
>          Uninstalling setuptools-67.6.1:
>            Successfully uninstalled setuptools-67.6.1
>        Attempting uninstall: pip
>          Found existing installation: pip 23.1
>          Uninstalling pip-23.1:
>            Successfully uninstalled pip-23.1
>     Successfully installed pip-24.3.1 setuptools-75.5.0
>     [rtd-command-info] start-time: 2024-11-19T23:56:46.593930Z, end-time: 2024-11-19T23:56:56.073085Z, duration: 9, exit-code: 0
>     python -m pip install --upgrade --no-cache-dir sphinx
>     Collecting sphinx
>        Downloading sphinx-8.1.3-py3-none-any.whl.metadata (6.4 kB)
>     Collecting sphinxcontrib-applehelp>=1.0.7 (from sphinx)
>        Downloading sphinxcontrib_applehelp-2.0.0-py3-none-any.whl.metadata (2.3 kB)
>     Collecting sphinxcontrib-devhelp>=1.0.6 (from sphinx)
>        Downloading sphinxcontrib_devhelp-2.0.0-py3-none-any.whl.metadata (2.3 kB)
>     Collecting sphinxcontrib-htmlhelp>=2.0.6 (from sphinx)
>        Downloading sphinxcontrib_htmlhelp-2.1.0-py3-none-any.whl.metadata (2.3 kB)
>     Collecting sphinxcontrib-jsmath>=1.0.1 (from sphinx)
>        Downloading sphinxcontrib_jsmath-1.0.1-py2.py3-none-any.whl.metadata (1.4 kB)
>     Collecting sphinxcontrib-qthelp>=1.0.6 (from sphinx)
>        Downloading sphinxcontrib_qthelp-2.0.0-py3-none-any.whl.metadata (2.3 kB)
>     Collecting sphinxcontrib-serializinghtml>=1.1.9 (from sphinx)
>        Downloading sphinxcontrib_serializinghtml-2.0.0-py3-none-any.whl.metadata (2.4 kB)
>     Collecting Jinja2>=3.1 (from sphinx)
>        Downloading jinja2-3.1.4-py3-none-any.whl.metadata (2.6 kB)
>     Collecting Pygments>=2.17 (from sphinx)
>        Downloading pygments-2.18.0-py3-none-any.whl.metadata (2.5 kB)
>     Collecting docutils<0.22,>=0.20 (from sphinx)
>        Downloading docutils-0.21.2-py3-none-any.whl.metadata (2.8 kB)
>     Collecting snowballstemmer>=2.2 (from sphinx)
>        Downloading snowballstemmer-2.2.0-py2.py3-none-any.whl.metadata (6.5 kB)
>     Collecting babel>=2.13 (from sphinx)
>        Downloading babel-2.16.0-py3-none-any.whl.metadata (1.5 kB)
>     Collecting alabaster>=0.7.14 (from sphinx)
>        Downloading alabaster-1.0.0-py3-none-any.whl.metadata (2.8 kB)
>     Collecting imagesize>=1.3 (from sphinx)
>        Downloading imagesize-1.4.1-py2.py3-none-any.whl.metadata (1.5 kB)
>     Collecting requests>=2.30.0 (from sphinx)
>        Downloading requests-2.32.3-py3-none-any.whl.metadata (4.6 kB)
>     Collecting packaging>=23.0 (from sphinx)
>        Downloading packaging-24.2-py3-none-any.whl.metadata (3.2 kB)
>     Collecting MarkupSafe>=2.0 (from Jinja2>=3.1->sphinx)
>        Downloading MarkupSafe-3.0.2-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (4.0 kB)
>     Collecting charset-normalizer<4,>=2 (from requests>=2.30.0->sphinx)
>        Downloading charset_normalizer-3.4.0-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (34 kB)
>     Collecting idna<4,>=2.5 (from requests>=2.30.0->sphinx)
>        Downloading idna-3.10-py3-none-any.whl.metadata (10 kB)
>     Collecting urllib3<3,>=1.21.1 (from requests>=2.30.0->sphinx)
>        Downloading urllib3-2.2.3-py3-none-any.whl.metadata (6.5 kB)
>     Collecting certifi>=2017.4.17 (from requests>=2.30.0->sphinx)
>        Downloading certifi-2024.8.30-py3-none-any.whl.metadata (2.2 kB)
>     Downloading sphinx-8.1.3-py3-none-any.whl (3.5 MB)
>         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.5/3.5 MB 116.3 MB/s eta 0:00:00
>     Downloading alabaster-1.0.0-py3-none-any.whl (13 kB)
>     Downloading babel-2.16.0-py3-none-any.whl (9.6 MB)
>         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 9.6/9.6 MB 181.2 MB/s eta 0:00:00
>     Downloading docutils-0.21.2-py3-none-any.whl (587 kB)
>         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 587.4/587.4 kB 366.5 MB/s eta 0:00:00
>     Downloading imagesize-1.4.1-py2.py3-none-any.whl (8.8 kB)
>     Downloading jinja2-3.1.4-py3-none-any.whl (133 kB)
>     Downloading packaging-24.2-py3-none-any.whl (65 kB)
>     Downloading pygments-2.18.0-py3-none-any.whl (1.2 MB)
>         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.2/1.2 MB 365.8 MB/s eta 0:00:00
>     Downloading requests-2.32.3-py3-none-any.whl (64 kB)
>     Downloading snowballstemmer-2.2.0-py2.py3-none-any.whl (93 kB)
>     Downloading sphinxcontrib_applehelp-2.0.0-py3-none-any.whl (119 kB)
>     Downloading sphinxcontrib_devhelp-2.0.0-py3-none-any.whl (82 kB)
>     Downloading sphinxcontrib_htmlhelp-2.1.0-py3-none-any.whl (98 kB)
>     Downloading sphinxcontrib_jsmath-1.0.1-py2.py3-none-any.whl (5.1 kB)
>     Downloading sphinxcontrib_qthelp-2.0.0-py3-none-any.whl (88 kB)
>     Downloading sphinxcontrib_serializinghtml-2.0.0-py3-none-any.whl (92 kB)
>     Downloading certifi-2024.8.30-py3-none-any.whl (167 kB)
>     Downloading charset_normalizer-3.4.0-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (142 kB)
>     Downloading idna-3.10-py3-none-any.whl (70 kB)
>     Downloading MarkupSafe-3.0.2-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (23 kB)
>     Downloading urllib3-2.2.3-py3-none-any.whl (126 kB)
>     Installing collected packages: snowballstemmer, urllib3, sphinxcontrib-serializinghtml, sphinxcontrib-qthelp, sphinxcontrib-jsmath, sphinxcontrib-htmlhelp, sphinxcontrib-devhelp, sphinxcontrib-applehelp, Pygments, packaging, MarkupSafe, imagesize, idna, docutils, charset-normalizer, certifi, babel, alabaster, requests, Jinja2, sphinx
>     Successfully installed Jinja2-3.1.4 MarkupSafe-3.0.2 Pygments-2.18.0 alabaster-1.0.0 babel-2.16.0 certifi-2024.8.30 charset-normalizer-3.4.0 docutils-0.21.2 idna-3.10 imagesize-1.4.1 packaging-24.2 requests-2.32.3 snowballstemmer-2.2.0 sphinx-8.1.3 sphinxcontrib-applehelp-2.0.0 sphinxcontrib-devhelp-2.0.0 sphinxcontrib-htmlhelp-2.1.0 sphinxcontrib-jsmath-1.0.1 sphinxcontrib-qthelp-2.0.0 sphinxcontrib-serializinghtml-2.0.0 urllib3-2.2.3
>     [rtd-command-info] start-time: 2024-11-19T23:56:56.096582Z, end-time: 2024-11-19T23:56:59.156352Z, duration: 3, exit-code: 0
>     python -m pip install --exists-action=w --no-cache-dir -r docs/source/requirements.txt
>     Collecting sphinx_rtd_theme (from -r docs/source/requirements.txt (line 1))
>        Downloading sphinx_rtd_theme-3.0.2-py2.py3-none-any.whl.metadata (4.4 kB)
>     Collecting sphinx_mdinclude (from -r docs/source/requirements.txt (line 2))
>        Downloading sphinx_mdinclude-0.6.2-py3-none-any.whl.metadata (4.6 kB)
>     Requirement already satisfied: docutils in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from -r docs/source/requirements.txt (line 3)) (0.21.2)
>     Collecting mistune<2.0.0 (from -r docs/source/requirements.txt (line 4))
>        Downloading mistune-0.8.4-py2.py3-none-any.whl.metadata (8.5 kB)
>     Collecting requests<2.29.0 (from -r docs/source/requirements.txt (line 5))
>        Downloading requests-2.28.2-py3-none-any.whl.metadata (4.6 kB)
>     Requirement already satisfied: sphinx<9,>=6 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (8.1.3)
>     Collecting sphinxcontrib-jquery<5,>=4 (from sphinx_rtd_theme->-r docs/source/requirements.txt (line 1))
>        Downloading sphinxcontrib_jquery-4.1-py2.py3-none-any.whl.metadata (2.6 kB)
>     INFO: pip is looking at multiple versions of sphinx-mdinclude to determine which version is compatible with other requirements. This could take a while.
>        Downloading sphinx_mdinclude-0.6.1-py3-none-any.whl.metadata (4.6 kB)
>        Downloading sphinx_mdinclude-0.6.0-py3-none-any.whl.metadata (4.6 kB)
>        Downloading sphinx_mdinclude-0.5.4-py3-none-any.whl.metadata (4.6 kB)
>        Downloading sphinx_mdinclude-0.5.3-py3-none-any.whl.metadata (4.1 kB)
>        Downloading sphinx_mdinclude-0.5.2-py3-none-any.whl.metadata (4.0 kB)
>        Downloading sphinx_mdinclude-0.5.1-py3-none-any.whl.metadata (4.0 kB)
>        Downloading sphinx_mdinclude-0.5.0-py3-none-any.whl.metadata (4.0 kB)
>     INFO: pip is still looking at multiple versions of sphinx-mdinclude to determine which version is compatible with other requirements. This could take a while.
>        Downloading sphinx_mdinclude-0.4.0-py3-none-any.whl.metadata (4.0 kB)
>     Requirement already satisfied: charset-normalizer<4,>=2 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from requests<2.29.0->-r docs/source/requirements.txt (line 5)) (3.4.0)
>     Requirement already satisfied: idna<4,>=2.5 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from requests<2.29.0->-r docs/source/requirements.txt (line 5)) (3.10)
>     Collecting urllib3<1.27,>=1.21.1 (from requests<2.29.0->-r docs/source/requirements.txt (line 5))
>        Downloading urllib3-1.26.20-py2.py3-none-any.whl.metadata (50 kB)
>     Requirement already satisfied: certifi>=2017.4.17 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from requests<2.29.0->-r docs/source/requirements.txt (line 5)) (2024.8.30)
>     Requirement already satisfied: sphinxcontrib-applehelp>=1.0.7 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.0.0)
>     Requirement already satisfied: sphinxcontrib-devhelp>=1.0.6 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.0.0)
>     Requirement already satisfied: sphinxcontrib-htmlhelp>=2.0.6 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.1.0)
>     Requirement already satisfied: sphinxcontrib-jsmath>=1.0.1 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (1.0.1)
>     Requirement already satisfied: sphinxcontrib-qthelp>=1.0.6 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.0.0)
>     Requirement already satisfied: sphinxcontrib-serializinghtml>=1.1.9 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.0.0)
>     Requirement already satisfied: Jinja2>=3.1 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (3.1.4)
>     Requirement already satisfied: Pygments>=2.17 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.18.0)
>     Requirement already satisfied: snowballstemmer>=2.2 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.2.0)
>     Requirement already satisfied: babel>=2.13 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.16.0)
>     Requirement already satisfied: alabaster>=0.7.14 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (1.0.0)
>     Requirement already satisfied: imagesize>=1.3 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (1.4.1)
>     INFO: pip is looking at multiple versions of sphinx to determine which version is compatible with other requirements. This could take a while.
>     Collecting sphinx<9,>=6 (from sphinx_rtd_theme->-r docs/source/requirements.txt (line 1))
>        Downloading sphinx-8.1.2-py3-none-any.whl.metadata (6.4 kB)
>        Downloading sphinx-8.1.1-py3-none-any.whl.metadata (6.4 kB)
>        Downloading sphinx-8.1.0-py3-none-any.whl.metadata (6.4 kB)
>        Downloading sphinx-8.0.2-py3-none-any.whl.metadata (6.2 kB)
>        Downloading sphinx-8.0.1-py3-none-any.whl.metadata (6.2 kB)
>        Downloading sphinx-8.0.0-py3-none-any.whl.metadata (6.2 kB)
>        Downloading sphinx-7.4.7-py3-none-any.whl.metadata (6.1 kB)
>     Collecting alabaster~=0.7.14 (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1))
>        Downloading alabaster-0.7.16-py3-none-any.whl.metadata (2.9 kB)
>     INFO: pip is still looking at multiple versions of sphinx to determine which version is compatible with other requirements. This could take a while.
>        Downloading sphinx-7.4.6-py3-none-any.whl.metadata (6.1 kB)
>        Downloading sphinx-7.4.5-py3-none-any.whl.metadata (6.1 kB)
>        Downloading sphinx-7.4.4-py3-none-any.whl.metadata (6.1 kB)
>        Downloading sphinx-7.4.3-py3-none-any.whl.metadata (6.1 kB)
>        Downloading sphinx-7.4.2-py3-none-any.whl.metadata (6.1 kB)
>     INFO: This is taking longer than usual. You might need to provide the dependency resolver with stricter constraints to reduce runtime. Seehttps://pip.pypa.io/warnings/backtracking  for guidance. If you want to abort this run, press Ctrl + C.
>        Downloading sphinx-7.4.1-py3-none-any.whl.metadata (6.1 kB)
>        Downloading sphinx-7.4.0-py3-none-any.whl.metadata (6.1 kB)
>        Downloading sphinx-7.3.7-py3-none-any.whl.metadata (6.0 kB)
>     Requirement already satisfied: packaging>=21.0 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (24.2)
>     Requirement already satisfied: MarkupSafe>=2.0 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from Jinja2>=3.1->sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (3.0.2)
>     Downloading sphinx_rtd_theme-3.0.2-py2.py3-none-any.whl (7.7 MB)
>         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 7.7/7.7 MB 143.1 MB/s eta 0:00:00
>     Downloading sphinx_mdinclude-0.4.0-py3-none-any.whl (14 kB)
>     Downloading mistune-0.8.4-py2.py3-none-any.whl (16 kB)
>     Downloading requests-2.28.2-py3-none-any.whl (62 kB)
>     Downloading sphinx-7.3.7-py3-none-any.whl (3.3 MB)
>         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.3/3.3 MB 164.0 MB/s eta 0:00:00
>     Downloading sphinxcontrib_jquery-4.1-py2.py3-none-any.whl (121 kB)
>     Downloading urllib3-1.26.20-py2.py3-none-any.whl (144 kB)
>     Downloading alabaster-0.7.16-py3-none-any.whl (13 kB)
>     Installing collected packages: mistune, urllib3, sphinx_mdinclude, alabaster, requests, sphinx, sphinxcontrib-jquery, sphinx_rtd_theme
>        Attempting uninstall: urllib3
>          Found existing installation: urllib3 2.2.3
>          Uninstalling urllib3-2.2.3:
>            Successfully uninstalled urllib3-2.2.3
>        Attempting uninstall: alabaster
>          Found existing installation: alabaster 1.0.0
>          Uninstalling alabaster-1.0.0:
>            Successfully uninstalled alabaster-1.0.0
>        Attempting uninstall: requests
>          Found existing installation: requests 2.32.3
>          Uninstalling requests-2.32.3:
>            Successfully uninstalled requests-2.32.3
>        Attempting uninstall: sphinx
>          Found existing installation: Sphinx 8.1.3
>          Uninstalling Sphinx-8.1.3:
>            Successfully uninstalled Sphinx-8.1.3
>     Successfully installed alabaster-0.7.16 mistune-0.8.4 requests-2.28.2 sphinx-7.3.7 sphinx_mdinclude-0.4.0 sphinx_rtd_theme-3.0.2 sphinxcontrib-jquery-4.1 urllib3-1.26.20
>     [rtd-command-info] start-time: 2024-11-19T23:56:59.229935Z, end-time: 2024-11-19T23:56:59.285486Z, duration: 0, exit-code: 0
>     cat docs/source/conf.py
>     # Configuration file for the Sphinx documentation builder.
>     # This file only contains a selection of the most common options. For a full
>     # list see the documentation:
>     #http://www.sphinx-doc.org/en/master/config
>     # -- Path setup --------------------------------------------------------------
>     # If extensions (or modules to document with autodoc) are in another directory,
>     # add these directories to sys.path here. If the directory is relative to the
>     # documentation root, use os.path.abspath to make it absolute, like shown here.
>     # import os
>     # import sys
>     # sys.path.insert(0, os.path.abspath('.'))
>     # -- Project information -----------------------------------------------------
>     project = 'Open Vehicles'
>     copyright = '2019-2024, Open Vehicles Developers'
>     author = 'Open Vehicle Developers'
>     # -- General configuration ---------------------------------------------------
>     # Add any Sphinx extension module names here, as strings. They can be
>     # extensions coming with Sphinx (named 'sphinx.ext.*') or your custom
>     # ones.
>     extensions = [
>        'sphinx_mdinclude',
>     # Add any paths that contain templates here, relative to this directory.
>     templates_path = ['_templates']
>     # List of patterns, relative to source directory, that match files and
>     # directories to ignore when looking for source files.
>     # This pattern also affects html_static_path and html_extra_path.
>     exclude_patterns = [
>        'docs',
>        '*/**.md',
>        '*/wolfssl/*',
>        '*/duktape/*',
>        '*/mongoose/*',
>     master_doc = 'index'
>     # -- Source configuration ----------------------------------------------------
>     # - |clearfix| global substitution to clear floats (e.g. images)
>     rst_epilog = """
>     .. |clearfix| raw:: html
>        <div class="clearfix"></div>
>     # -- Options for HTML output -------------------------------------------------
>     # The theme to use for HTML and HTML Help pages.  See the documentation for
>     # a list of builtin themes.
>     #html_theme = 'default'
>     html_theme = 'sphinx_rtd_theme'
>     # Add any paths that contain custom static files (such as style sheets) here,
>     # relative to this directory. They are copied after the builtin static files,
>     # so a file named "default.css" will overwrite the builtin "default.css".
>     html_static_path = ['_static']
>     html_context = {
>     def setup(app):
>          app.add_css_file('theme_overrides.css')
>          app.add_css_file('copybutton.css')
>          app.add_js_file('clipboard.min.js')
>          app.add_js_file('copybutton.js')
>     [rtd-command-info] start-time: 2024-11-19T23:56:59.307664Z, end-time: 2024-11-19T23:56:59.818337Z, duration: 0, exit-code: 2
>     python -m sphinx -T -b html -d _build/doctrees -D language=en . $READTHEDOCS_OUTPUT/html
>     Running Sphinx v7.3.7
>     Traceback (most recent call last):
>        File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx/registry.py", line 453, in load_extension
>          mod = import_module(extname)
>        File "/home/docs/.asdf/installs/python/3.11.10/lib/python3.11/importlib/__init__.py", line 126, in import_module
>          return _bootstrap._gcd_import(name[level:], package, level)
>        File "<frozen importlib._bootstrap>", line 1204, in _gcd_import
>        File "<frozen importlib._bootstrap>", line 1176, in _find_and_load
>        File "<frozen importlib._bootstrap>", line 1147, in _find_and_load_unlocked
>        File "<frozen importlib._bootstrap>", line 690, in _load_unlocked
>        File "<frozen importlib._bootstrap_external>", line 940, in exec_module
>        File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
>        File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx_mdinclude/__init__.py", line 17, in <module>
>          from docutils.core import ErrorString
>     ImportError: cannot import name 'ErrorString' from 'docutils.core' (/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/docutils/core.py)
>     The above exception was the direct cause of the following exception:
>        File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx/cmd/build.py", line 332, in build_main
>          app = Sphinx(args.sourcedir, args.confdir, args.outputdir,
>        File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx/application.py", line 229, in __init__
>          self.setup_extension(extension)
>        File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx/application.py", line 402, in setup_extension
>          self.registry.load_extension(self, extname)
>        File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx/registry.py", line 456, in load_extension
>          raise ExtensionError(__('Could not import extension %s') % extname,
>     sphinx.errors.ExtensionError: Could not import extension sphinx_mdinclude (exception: cannot import name 'ErrorString' from 'docutils.core' (/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/docutils/core.py))
>     Extension error:
>> On 20 Nov 2024, at 2:22 AM, Michael Balzer via OvmsDev
>> <ovmsdev at lists.openvehicles.com> wrote:
>> Signed PGP part
>> I've switched the plugin from m2r2 to sphinx_mdinclude, works here as
>> well.
>> Note: I've kept the name consistent for the install documentation,
>> this works due to pip automatically switching between underscore &
>> dash as needed.
>> @Mark: I guess this also needs some change to the ReadTheDocs
>> configuration?
>> Am 17.11.24 um 23:59 schrieb Michael Geddes:
>>> Michael what do you think of switching over to mdinclude?
>>> On Mon, 18 Nov 2024, 05:28 Craig Leres, <leres at xse.com> wrote:
>>>     On 11/16/24 16:19, Michael Geddes via OvmsDev wrote:
>>>     > For some reason I was getting run-time python errors with m2r2
>>>     which is
>>>     > why I tried switching to mdinclude.
>>>     Over here in FreeBSD-land, I can "gmake html" if I change
>>>     conf.py to use
>>>     sphinx_mdinclude instead of m2r2.
>>>     Craig
>>>     ice 4003 % pkg info | fgrep sphinx
>>>     py311-sphinx-5.3.0_3,1         Python documentation generator
>>>     py311-sphinx-mdinclude-0.6.2   Sphinx extension that enables
>>>     including
>>>     Markdown documents
>>>     py311-sphinx_rtd_theme-1.0.0  Mobile-friendly py-sphinx theme
>>>     py311-sphinxcontrib-applehelp-1.0.2 Extension which outputs
>>>     Apple help books
>>>     py311-sphinxcontrib-devhelp-1.0.2 Sphinx extension which outputs
>>>     Devhelp
>>>     document
>>>     py311-sphinxcontrib-htmlhelp-2.1.0 Sphinx extension which
>>>     renders HTML
>>>     help files
>>>     py311-sphinxcontrib-jsmath-1.0.1 Sphinx extension which renders
>>>     display
>>>     math in HTML via JavaScript
>>>     py311-sphinxcontrib-qthelp-2.0.0 Sphinx extension which outputs
>>>     QtHelp
>>>     document
>>>     py311-sphinxcontrib-serializinghtml-2.0.0 Sphinx extension which
>>>     outputs
>>>     serialized HTML files (json and pickle)
>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241120/ee32fd98/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241120/ee32fd98/attachment-0001.sig>
