[Ovmsdev] How I got sphinx working on ubuntu 23.1 + WSL
Wed Nov 20 08:01:54 HKT 2024
Michael,
Yes, readthedocs is broken. But seems to have had various problems building the docs for the past few weeks (although more to do with errors in the docs files before).
Build logs shown below. Seems to be a dependency problem (probably docutils vs sphinx_mdinclude). I can’t see a trivial solution (it was painful enough to get it working with m2r), and am out of time now, but will try again tonight.
P.S. I’ve added your eMail to the readthedocs notification list so you see build notifications. If you create an account on readthedocs.com <http://readthedocs.com/>, I can also add you as a maintainer there, if it helps.
Read the Docs build information
Build id: 26335608
Project: ovms
Version: latest
Commit: 1f863527d0a593fe8b10d2faee5cc0e04da4a843
Date: 2024-11-19T23:56:17.734263Z
State: finished
Success: False
[rtd-command-info] start-time: 2024-11-19T23:56:18.277210Z, end-time: 2024-11-19T23:56:22.276851Z, duration: 3, exit-code: 0
git clone --depth 1 https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3.git .
Cloning into '.'...
[rtd-command-info] start-time: 2024-11-19T23:56:22.296787Z, end-time: 2024-11-19T23:56:24.339706Z, duration: 2, exit-code: 0
git fetch origin --force --prune --prune-tags --depth 50 refs/heads/master:refs/remotes/origin/master
[rtd-command-info] start-time: 2024-11-19T23:56:24.414382Z, end-time: 2024-11-19T23:56:25.042773Z, duration: 0, exit-code: 0
git checkout --force origin/master
Note: switching to 'origin/master'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by switching back to a branch.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -c with the switch command. Example:
  git switch -c <new-branch-name>
Or undo this operation with:
  git switch -
Turn off this advice by setting config variable advice.detachedHead to false
HEAD is now at 1f86352 Include docutils, without specific version
[rtd-command-info] start-time: 2024-11-19T23:56:25.068777Z, end-time: 2024-11-19T23:56:25.129267Z, duration: 0, exit-code: 0
cat .readthedocs.yaml
# .readthedocs.yaml
# Read the Docs configuration file
# See https://docs.readthedocs.io/en/stable/config-file/v2.html for details
# Required
version: 2
# Set the version of Python and other tools you might need
build:
  os: ubuntu-22.04
  tools:
    python: "3.11"
# Build documentation in the docs/ directory with Sphinx
sphinx:
  configuration: docs/source/conf.py
# We recommend specifying your dependencies to enable reproducible builds:
# https://docs.readthedocs.io/en/stable/guides/reproducible-builds.html
python:
  install:
    - requirements: docs/source/requirements.txt
[rtd-command-info] start-time: 2024-11-19T23:56:30.973717Z, end-time: 2024-11-19T23:56:31.050053Z, duration: 0, exit-code: 0
asdf global python 3.11.10
[rtd-command-info] start-time: 2024-11-19T23:56:31.420254Z, end-time: 2024-11-19T23:56:32.502084Z, duration: 1, exit-code: 0
python -mvirtualenv $READTHEDOCS_VIRTUALENV_PATH
created virtual environment CPython3.11.10.final.0-64 in 772ms
  creator CPython3Posix(dest=/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest, clear=False, no_vcs_ignore=False, global=False)
  seeder FromAppData(download=False, pip=bundle, setuptools=bundle, wheel=bundle, via=copy, app_data_dir=/home/docs/.local/share/virtualenv)
    added seed packages: pip==23.1, setuptools==67.6.1, wheel==0.40.0
  activators BashActivator,CShellActivator,FishActivator,NushellActivator,PowerShellActivator,PythonActivator
[rtd-command-info] start-time: 2024-11-19T23:56:32.536062Z, end-time: 2024-11-19T23:56:46.548826Z, duration: 14, exit-code: 0
python -m pip install --upgrade --no-cache-dir pip setuptools
Requirement already satisfied: pip in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (23.1)
Collecting pip
  Downloading pip-24.3.1-py3-none-any.whl (1.8 MB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.8/1.8 MB 9.8 MB/s eta 0:00:00
Requirement already satisfied: setuptools in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (67.6.1)
Collecting setuptools
  Downloading setuptools-75.5.0-py3-none-any.whl (1.2 MB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.2/1.2 MB 21.1 MB/s eta 0:00:00
Installing collected packages: setuptools, pip
  Attempting uninstall: setuptools
    Found existing installation: setuptools 67.6.1
    Uninstalling setuptools-67.6.1:
      Successfully uninstalled setuptools-67.6.1
  Attempting uninstall: pip
    Found existing installation: pip 23.1
    Uninstalling pip-23.1:
      Successfully uninstalled pip-23.1
Successfully installed pip-24.3.1 setuptools-75.5.0
[rtd-command-info] start-time: 2024-11-19T23:56:46.593930Z, end-time: 2024-11-19T23:56:56.073085Z, duration: 9, exit-code: 0
python -m pip install --upgrade --no-cache-dir sphinx
Collecting sphinx
  Downloading sphinx-8.1.3-py3-none-any.whl.metadata (6.4 kB)
Collecting sphinxcontrib-applehelp>=1.0.7 (from sphinx)
  Downloading sphinxcontrib_applehelp-2.0.0-py3-none-any.whl.metadata (2.3 kB)
Collecting sphinxcontrib-devhelp>=1.0.6 (from sphinx)
  Downloading sphinxcontrib_devhelp-2.0.0-py3-none-any.whl.metadata (2.3 kB)
Collecting sphinxcontrib-htmlhelp>=2.0.6 (from sphinx)
  Downloading sphinxcontrib_htmlhelp-2.1.0-py3-none-any.whl.metadata (2.3 kB)
Collecting sphinxcontrib-jsmath>=1.0.1 (from sphinx)
  Downloading sphinxcontrib_jsmath-1.0.1-py2.py3-none-any.whl.metadata (1.4 kB)
Collecting sphinxcontrib-qthelp>=1.0.6 (from sphinx)
  Downloading sphinxcontrib_qthelp-2.0.0-py3-none-any.whl.metadata (2.3 kB)
Collecting sphinxcontrib-serializinghtml>=1.1.9 (from sphinx)
  Downloading sphinxcontrib_serializinghtml-2.0.0-py3-none-any.whl.metadata (2.4 kB)
Collecting Jinja2>=3.1 (from sphinx)
  Downloading jinja2-3.1.4-py3-none-any.whl.metadata (2.6 kB)
Collecting Pygments>=2.17 (from sphinx)
  Downloading pygments-2.18.0-py3-none-any.whl.metadata (2.5 kB)
Collecting docutils<0.22,>=0.20 (from sphinx)
  Downloading docutils-0.21.2-py3-none-any.whl.metadata (2.8 kB)
Collecting snowballstemmer>=2.2 (from sphinx)
  Downloading snowballstemmer-2.2.0-py2.py3-none-any.whl.metadata (6.5 kB)
Collecting babel>=2.13 (from sphinx)
  Downloading babel-2.16.0-py3-none-any.whl.metadata (1.5 kB)
Collecting alabaster>=0.7.14 (from sphinx)
  Downloading alabaster-1.0.0-py3-none-any.whl.metadata (2.8 kB)
Collecting imagesize>=1.3 (from sphinx)
  Downloading imagesize-1.4.1-py2.py3-none-any.whl.metadata (1.5 kB)
Collecting requests>=2.30.0 (from sphinx)
  Downloading requests-2.32.3-py3-none-any.whl.metadata (4.6 kB)
Collecting packaging>=23.0 (from sphinx)
  Downloading packaging-24.2-py3-none-any.whl.metadata (3.2 kB)
Collecting MarkupSafe>=2.0 (from Jinja2>=3.1->sphinx)
  Downloading MarkupSafe-3.0.2-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (4.0 kB)
Collecting charset-normalizer<4,>=2 (from requests>=2.30.0->sphinx)
  Downloading charset_normalizer-3.4.0-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (34 kB)
Collecting idna<4,>=2.5 (from requests>=2.30.0->sphinx)
  Downloading idna-3.10-py3-none-any.whl.metadata (10 kB)
Collecting urllib3<3,>=1.21.1 (from requests>=2.30.0->sphinx)
  Downloading urllib3-2.2.3-py3-none-any.whl.metadata (6.5 kB)
Collecting certifi>=2017.4.17 (from requests>=2.30.0->sphinx)
  Downloading certifi-2024.8.30-py3-none-any.whl.metadata (2.2 kB)
Downloading sphinx-8.1.3-py3-none-any.whl (3.5 MB)
   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.5/3.5 MB 116.3 MB/s eta 0:00:00
Downloading alabaster-1.0.0-py3-none-any.whl (13 kB)
Downloading babel-2.16.0-py3-none-any.whl (9.6 MB)
   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 9.6/9.6 MB 181.2 MB/s eta 0:00:00
Downloading docutils-0.21.2-py3-none-any.whl (587 kB)
   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 587.4/587.4 kB 366.5 MB/s eta 0:00:00
Downloading imagesize-1.4.1-py2.py3-none-any.whl (8.8 kB)
Downloading jinja2-3.1.4-py3-none-any.whl (133 kB)
Downloading packaging-24.2-py3-none-any.whl (65 kB)
Downloading pygments-2.18.0-py3-none-any.whl (1.2 MB)
   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.2/1.2 MB 365.8 MB/s eta 0:00:00
Downloading requests-2.32.3-py3-none-any.whl (64 kB)
Downloading snowballstemmer-2.2.0-py2.py3-none-any.whl (93 kB)
Downloading sphinxcontrib_applehelp-2.0.0-py3-none-any.whl (119 kB)
Downloading sphinxcontrib_devhelp-2.0.0-py3-none-any.whl (82 kB)
Downloading sphinxcontrib_htmlhelp-2.1.0-py3-none-any.whl (98 kB)
Downloading sphinxcontrib_jsmath-1.0.1-py2.py3-none-any.whl (5.1 kB)
Downloading sphinxcontrib_qthelp-2.0.0-py3-none-any.whl (88 kB)
Downloading sphinxcontrib_serializinghtml-2.0.0-py3-none-any.whl (92 kB)
Downloading certifi-2024.8.30-py3-none-any.whl (167 kB)
Downloading charset_normalizer-3.4.0-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (142 kB)
Downloading idna-3.10-py3-none-any.whl (70 kB)
Downloading MarkupSafe-3.0.2-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (23 kB)
Downloading urllib3-2.2.3-py3-none-any.whl (126 kB)
Installing collected packages: snowballstemmer, urllib3, sphinxcontrib-serializinghtml, sphinxcontrib-qthelp, sphinxcontrib-jsmath, sphinxcontrib-htmlhelp, sphinxcontrib-devhelp, sphinxcontrib-applehelp, Pygments, packaging, MarkupSafe, imagesize, idna, docutils, charset-normalizer, certifi, babel, alabaster, requests, Jinja2, sphinx
Successfully installed Jinja2-3.1.4 MarkupSafe-3.0.2 Pygments-2.18.0 alabaster-1.0.0 babel-2.16.0 certifi-2024.8.30 charset-normalizer-3.4.0 docutils-0.21.2 idna-3.10 imagesize-1.4.1 packaging-24.2 requests-2.32.3 snowballstemmer-2.2.0 sphinx-8.1.3 sphinxcontrib-applehelp-2.0.0 sphinxcontrib-devhelp-2.0.0 sphinxcontrib-htmlhelp-2.1.0 sphinxcontrib-jsmath-1.0.1 sphinxcontrib-qthelp-2.0.0 sphinxcontrib-serializinghtml-2.0.0 urllib3-2.2.3
[rtd-command-info] start-time: 2024-11-19T23:56:56.096582Z, end-time: 2024-11-19T23:56:59.156352Z, duration: 3, exit-code: 0
python -m pip install --exists-action=w --no-cache-dir -r docs/source/requirements.txt
Collecting sphinx_rtd_theme (from -r docs/source/requirements.txt (line 1))
  Downloading sphinx_rtd_theme-3.0.2-py2.py3-none-any.whl.metadata (4.4 kB)
Collecting sphinx_mdinclude (from -r docs/source/requirements.txt (line 2))
  Downloading sphinx_mdinclude-0.6.2-py3-none-any.whl.metadata (4.6 kB)
Requirement already satisfied: docutils in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from -r docs/source/requirements.txt (line 3)) (0.21.2)
Collecting mistune<2.0.0 (from -r docs/source/requirements.txt (line 4))
  Downloading mistune-0.8.4-py2.py3-none-any.whl.metadata (8.5 kB)
Collecting requests<2.29.0 (from -r docs/source/requirements.txt (line 5))
  Downloading requests-2.28.2-py3-none-any.whl.metadata (4.6 kB)
Requirement already satisfied: sphinx<9,>=6 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (8.1.3)
Collecting sphinxcontrib-jquery<5,>=4 (from sphinx_rtd_theme->-r docs/source/requirements.txt (line 1))
  Downloading sphinxcontrib_jquery-4.1-py2.py3-none-any.whl.metadata (2.6 kB)
INFO: pip is looking at multiple versions of sphinx-mdinclude to determine which version is compatible with other requirements. This could take a while.
  Downloading sphinx_mdinclude-0.6.1-py3-none-any.whl.metadata (4.6 kB)
  Downloading sphinx_mdinclude-0.6.0-py3-none-any.whl.metadata (4.6 kB)
  Downloading sphinx_mdinclude-0.5.4-py3-none-any.whl.metadata (4.6 kB)
  Downloading sphinx_mdinclude-0.5.3-py3-none-any.whl.metadata (4.1 kB)
  Downloading sphinx_mdinclude-0.5.2-py3-none-any.whl.metadata (4.0 kB)
  Downloading sphinx_mdinclude-0.5.1-py3-none-any.whl.metadata (4.0 kB)
  Downloading sphinx_mdinclude-0.5.0-py3-none-any.whl.metadata (4.0 kB)
INFO: pip is still looking at multiple versions of sphinx-mdinclude to determine which version is compatible with other requirements. This could take a while.
  Downloading sphinx_mdinclude-0.4.0-py3-none-any.whl.metadata (4.0 kB)
Requirement already satisfied: charset-normalizer<4,>=2 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from requests<2.29.0->-r docs/source/requirements.txt (line 5)) (3.4.0)
Requirement already satisfied: idna<4,>=2.5 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from requests<2.29.0->-r docs/source/requirements.txt (line 5)) (3.10)
Collecting urllib3<1.27,>=1.21.1 (from requests<2.29.0->-r docs/source/requirements.txt (line 5))
  Downloading urllib3-1.26.20-py2.py3-none-any.whl.metadata (50 kB)
Requirement already satisfied: certifi>=2017.4.17 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from requests<2.29.0->-r docs/source/requirements.txt (line 5)) (2024.8.30)
Requirement already satisfied: sphinxcontrib-applehelp>=1.0.7 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.0.0)
Requirement already satisfied: sphinxcontrib-devhelp>=1.0.6 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.0.0)
Requirement already satisfied: sphinxcontrib-htmlhelp>=2.0.6 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.1.0)
Requirement already satisfied: sphinxcontrib-jsmath>=1.0.1 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (1.0.1)
Requirement already satisfied: sphinxcontrib-qthelp>=1.0.6 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.0.0)
Requirement already satisfied: sphinxcontrib-serializinghtml>=1.1.9 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.0.0)
Requirement already satisfied: Jinja2>=3.1 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (3.1.4)
Requirement already satisfied: Pygments>=2.17 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.18.0)
Requirement already satisfied: snowballstemmer>=2.2 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.2.0)
Requirement already satisfied: babel>=2.13 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.16.0)
Requirement already satisfied: alabaster>=0.7.14 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (1.0.0)
Requirement already satisfied: imagesize>=1.3 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (1.4.1)
INFO: pip is looking at multiple versions of sphinx to determine which version is compatible with other requirements. This could take a while.
Collecting sphinx<9,>=6 (from sphinx_rtd_theme->-r docs/source/requirements.txt (line 1))
  Downloading sphinx-8.1.2-py3-none-any.whl.metadata (6.4 kB)
  Downloading sphinx-8.1.1-py3-none-any.whl.metadata (6.4 kB)
  Downloading sphinx-8.1.0-py3-none-any.whl.metadata (6.4 kB)
  Downloading sphinx-8.0.2-py3-none-any.whl.metadata (6.2 kB)
  Downloading sphinx-8.0.1-py3-none-any.whl.metadata (6.2 kB)
  Downloading sphinx-8.0.0-py3-none-any.whl.metadata (6.2 kB)
  Downloading sphinx-7.4.7-py3-none-any.whl.metadata (6.1 kB)
Collecting alabaster~=0.7.14 (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1))
  Downloading alabaster-0.7.16-py3-none-any.whl.metadata (2.9 kB)
INFO: pip is still looking at multiple versions of sphinx to determine which version is compatible with other requirements. This could take a while.
  Downloading sphinx-7.4.6-py3-none-any.whl.metadata (6.1 kB)
  Downloading sphinx-7.4.5-py3-none-any.whl.metadata (6.1 kB)
  Downloading sphinx-7.4.4-py3-none-any.whl.metadata (6.1 kB)
  Downloading sphinx-7.4.3-py3-none-any.whl.metadata (6.1 kB)
  Downloading sphinx-7.4.2-py3-none-any.whl.metadata (6.1 kB)
INFO: This is taking longer than usual. You might need to provide the dependency resolver with stricter constraints to reduce runtime. See https://pip.pypa.io/warnings/backtracking for guidance. If you want to abort this run, press Ctrl + C.
  Downloading sphinx-7.4.1-py3-none-any.whl.metadata (6.1 kB)
  Downloading sphinx-7.4.0-py3-none-any.whl.metadata (6.1 kB)
  Downloading sphinx-7.3.7-py3-none-any.whl.metadata (6.0 kB)
Requirement already satisfied: packaging>=21.0 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (24.2)
Requirement already satisfied: MarkupSafe>=2.0 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from Jinja2>=3.1->sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (3.0.2)
Downloading sphinx_rtd_theme-3.0.2-py2.py3-none-any.whl (7.7 MB)
   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 7.7/7.7 MB 143.1 MB/s eta 0:00:00
Downloading sphinx_mdinclude-0.4.0-py3-none-any.whl (14 kB)
Downloading mistune-0.8.4-py2.py3-none-any.whl (16 kB)
Downloading requests-2.28.2-py3-none-any.whl (62 kB)
Downloading sphinx-7.3.7-py3-none-any.whl (3.3 MB)
   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.3/3.3 MB 164.0 MB/s eta 0:00:00
Downloading sphinxcontrib_jquery-4.1-py2.py3-none-any.whl (121 kB)
Downloading urllib3-1.26.20-py2.py3-none-any.whl (144 kB)
Downloading alabaster-0.7.16-py3-none-any.whl (13 kB)
Installing collected packages: mistune, urllib3, sphinx_mdinclude, alabaster, requests, sphinx, sphinxcontrib-jquery, sphinx_rtd_theme
  Attempting uninstall: urllib3
    Found existing installation: urllib3 2.2.3
    Uninstalling urllib3-2.2.3:
      Successfully uninstalled urllib3-2.2.3
  Attempting uninstall: alabaster
    Found existing installation: alabaster 1.0.0
    Uninstalling alabaster-1.0.0:
      Successfully uninstalled alabaster-1.0.0
  Attempting uninstall: requests
    Found existing installation: requests 2.32.3
    Uninstalling requests-2.32.3:
      Successfully uninstalled requests-2.32.3
  Attempting uninstall: sphinx
    Found existing installation: Sphinx 8.1.3
    Uninstalling Sphinx-8.1.3:
      Successfully uninstalled Sphinx-8.1.3
Successfully installed alabaster-0.7.16 mistune-0.8.4 requests-2.28.2 sphinx-7.3.7 sphinx_mdinclude-0.4.0 sphinx_rtd_theme-3.0.2 sphinxcontrib-jquery-4.1 urllib3-1.26.20
[rtd-command-info] start-time: 2024-11-19T23:56:59.229935Z, end-time: 2024-11-19T23:56:59.285486Z, duration: 0, exit-code: 0
cat docs/source/conf.py
# Configuration file for the Sphinx documentation builder.
# This file only contains a selection of the most common options. For a full
# list see the documentation:
# http://www.sphinx-doc.org/en/master/config
# -- Path setup --------------------------------------------------------------
# If extensions (or modules to document with autodoc) are in another directory,
# add these directories to sys.path here. If the directory is relative to the
# documentation root, use os.path.abspath to make it absolute, like shown here.
# import os
# import sys
# sys.path.insert(0, os.path.abspath('.'))
# -- Project information -----------------------------------------------------
project = 'Open Vehicles'
copyright = '2019-2024, Open Vehicles Developers'
author = 'Open Vehicle Developers'
# -- General configuration ---------------------------------------------------
# Add any Sphinx extension module names here, as strings. They can be
# extensions coming with Sphinx (named 'sphinx.ext.*') or your custom
# ones.
extensions = [
  'sphinx_mdinclude',
# Add any paths that contain templates here, relative to this directory.
templates_path = ['_templates']
# List of patterns, relative to source directory, that match files and
# directories to ignore when looking for source files.
# This pattern also affects html_static_path and html_extra_path.
exclude_patterns = [
  'docs',
  '*/**.md',
  '*/wolfssl/*',
  '*/duktape/*',
  '*/mongoose/*',
master_doc = 'index'
# -- Source configuration ----------------------------------------------------
# - |clearfix| global substitution to clear floats (e.g. images)
rst_epilog = """
.. |clearfix| raw:: html
  <div class="clearfix"></div>
# -- Options for HTML output -------------------------------------------------
# The theme to use for HTML and HTML Help pages.  See the documentation for
# a list of builtin themes.
#html_theme = 'default'
html_theme = 'sphinx_rtd_theme'
# Add any paths that contain custom static files (such as style sheets) here,
# relative to this directory. They are copied after the builtin static files,
# so a file named "default.css" will overwrite the builtin "default.css".
html_static_path = ['_static']
html_context = {
def setup(app):
    app.add_css_file('theme_overrides.css')
    app.add_css_file('copybutton.css')
    app.add_js_file('clipboard.min.js')
    app.add_js_file('copybutton.js')
[rtd-command-info] start-time: 2024-11-19T23:56:59.307664Z, end-time: 2024-11-19T23:56:59.818337Z, duration: 0, exit-code: 2
python -m sphinx -T -b html -d _build/doctrees -D language=en . $READTHEDOCS_OUTPUT/html
Running Sphinx v7.3.7
Traceback (most recent call last):
  File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx/registry.py", line 453, in load_extension
    mod = import_module(extname)
  File "/home/docs/.asdf/installs/python/3.11.10/lib/python3.11/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1204, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1176, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1147, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 690, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 940, in exec_module
  File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
  File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx_mdinclude/__init__.py", line 17, in <module>
    from docutils.core import ErrorString
ImportError: cannot import name 'ErrorString' from 'docutils.core' (/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/docutils/core.py)
The above exception was the direct cause of the following exception:
  File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx/cmd/build.py", line 332, in build_main
    app = Sphinx(args.sourcedir, args.confdir, args.outputdir,
  File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx/application.py", line 229, in __init__
    self.setup_extension(extension)
  File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx/application.py", line 402, in setup_extension
    self.registry.load_extension(self, extname)
  File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx/registry.py", line 456, in load_extension
    raise ExtensionError(__('Could not import extension %s') % extname,
sphinx.errors.ExtensionError: Could not import extension sphinx_mdinclude (exception: cannot import name 'ErrorString' from 'docutils.core' (/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/docutils/core.py))
Extension error:
> On 20 Nov 2024, at 2:22 AM, Michael Balzer via OvmsDev <ovmsdev at lists.openvehicles.com> wrote:
> Signed PGP part
> I've switched the plugin from m2r2 to sphinx_mdinclude, works here as well.
> Note: I've kept the name consistent for the install documentation, this works due to pip automatically switching between underscore & dash as needed.
> @Mark: I guess this also needs some change to the ReadTheDocs configuration?
> Am 17.11.24 um 23:59 schrieb Michael Geddes:
>> Michael what do you think of switching over to mdinclude?
>> On Mon, 18 Nov 2024, 05:28 Craig Leres, <leres at xse.com <mailto:leres at xse.com>> wrote:
>>> On 11/16/24 16:19, Michael Geddes via OvmsDev wrote:
>>> > For some reason I was getting run-time python errors with m2r2 which is
>>> > why I tried switching to mdinclude.
>>> Over here in FreeBSD-land, I can "gmake html" if I change conf.py to use
>>> sphinx_mdinclude instead of m2r2.
>>>                 Craig
>>> ice 4003 % pkg info | fgrep sphinx
>>> py311-sphinx-5.3.0_3,1         Python documentation generator
>>> py311-sphinx-mdinclude-0.6.2   Sphinx extension that enables including
>>> Markdown documents
>>> py311-sphinx_rtd_theme-1.0.0   Mobile-friendly py-sphinx theme
>>> py311-sphinxcontrib-applehelp-1.0.2 Extension which outputs Apple help books
>>> py311-sphinxcontrib-devhelp-1.0.2 Sphinx extension which outputs Devhelp
>>> document
>>> py311-sphinxcontrib-htmlhelp-2.1.0 Sphinx extension which renders HTML
>>> help files
>>> py311-sphinxcontrib-jsmath-1.0.1 Sphinx extension which renders display
>>> math in HTML via JavaScript
>>> py311-sphinxcontrib-qthelp-2.0.0 Sphinx extension which outputs QtHelp
>>> document
>>> py311-sphinxcontrib-serializinghtml-2.0.0 Sphinx extension which outputs
>>> serialized HTML files (json and pickle)
> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
> Fon 02330 9104094 * Handy 0176 20698926
> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241120/5697fce3/attachment-0001.htm>
