[Ovmsdev] How I got sphinx working on ubuntu 23.1 + WSL
Michael Geddes
Wed Nov 20 06:46:48 HKT 2024
Perfect. Maybe include my howto using pipx for Ubuntu systems, since it is
doing it the Ubuntu preferred way?
On Wed, 20 Nov 2024, 02:22 Michael Balzer via OvmsDev, <
> I've switched the plugin from m2r2 to sphinx_mdinclude, works here as well.
> Note: I've kept the name consistent for the install documentation, this
> works due to pip automatically switching between underscore & dash as
> needed.
> @Mark: I guess this also needs some change to the ReadTheDocs
> configuration?
> Am 17.11.24 um 23:59 schrieb Michael Geddes:
> Michael what do you think of switching over to mdinclude?
> On Mon, 18 Nov 2024, 05:28 Craig Leres, <leres at xse.com> wrote:
>> On 11/16/24 16:19, Michael Geddes via OvmsDev wrote:
>> > For some reason I was getting run-time python errors with m2r2 which is
>> > why I tried switching to mdinclude.
>> Over here in FreeBSD-land, I can "gmake html" if I change conf.py to use
>> sphinx_mdinclude instead of m2r2.
>> Craig
>> ice 4003 % pkg info | fgrep sphinx
>> py311-sphinx-5.3.0_3,1 Python documentation generator
>> py311-sphinx-mdinclude-0.6.2 Sphinx extension that enables including
>> Markdown documents
>> py311-sphinx_rtd_theme-1.0.0 Mobile-friendly py-sphinx theme
>> py311-sphinxcontrib-applehelp-1.0.2 Extension which outputs Apple help
>> books
>> py311-sphinxcontrib-devhelp-1.0.2 Sphinx extension which outputs Devhelp
>> document
>> py311-sphinxcontrib-htmlhelp-2.1.0 Sphinx extension which renders HTML
>> help files
>> py311-sphinxcontrib-jsmath-1.0.1 Sphinx extension which renders display
>> math in HTML via JavaScript
>> py311-sphinxcontrib-qthelp-2.0.0 Sphinx extension which outputs QtHelp
>> document
>> py311-sphinxcontrib-serializinghtml-2.0.0 Sphinx extension which outputs
>> serialized HTML files (json and pickle)
> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke <https://www.google.com/maps/search/Am+Rahmen+5+*+D-58313+Herdecke?entry=gmail&source=g>
> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241120/d91aef49/attachment.htm>
