[Ovmsdev] How I got sphinx working on ubuntu 23.1 + WSL
Wed Nov 20 02:22:29 HKT 2024
I've switched the plugin from m2r2 to sphinx_mdinclude, works here as well.
Note: I've kept the name consistent for the install documentation, this
works due to pip automatically switching between underscore & dash as
needed.
@Mark: I guess this also needs some change to the ReadTheDocs configuration?
Am 17.11.24 um 23:59 schrieb Michael Geddes:
> Michael what do you think of switching over to mdinclude?
> On Mon, 18 Nov 2024, 05:28 Craig Leres, <leres at xse.com> wrote:
>     On 11/16/24 16:19, Michael Geddes via OvmsDev wrote:
>     > For some reason I was getting run-time python errors with m2r2
>     which is
>     > why I tried switching to mdinclude.
>     Over here in FreeBSD-land, I can "gmake html" if I change conf.py
>     to use
>     sphinx_mdinclude instead of m2r2.
>                     Craig
>     ice 4003 % pkg info | fgrep sphinx
>     py311-sphinx-5.3.0_3,1         Python documentation generator
>     py311-sphinx-mdinclude-0.6.2   Sphinx extension that enables
>     including
>     Markdown documents
>     py311-sphinx_rtd_theme-1.0.0   Mobile-friendly py-sphinx theme
>     py311-sphinxcontrib-applehelp-1.0.2 Extension which outputs Apple
>     help books
>     py311-sphinxcontrib-devhelp-1.0.2 Sphinx extension which outputs
>     Devhelp
>     document
>     py311-sphinxcontrib-htmlhelp-2.1.0 Sphinx extension which renders
>     HTML
>     help files
>     py311-sphinxcontrib-jsmath-1.0.1 Sphinx extension which renders
>     display
>     math in HTML via JavaScript
>     py311-sphinxcontrib-qthelp-2.0.0 Sphinx extension which outputs
>     QtHelp
>     document
>     py311-sphinxcontrib-serializinghtml-2.0.0 Sphinx extension which
>     outputs
>     serialized HTML files (json and pickle)
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241119/c294947f/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241119/c294947f/attachment.sig>
