[Ovmsdev] How I got sphinx working on ubuntu 23.1 + WSL
Wed Nov 20 15:13:22 HKT 2024
Michael,
I added you as a maintainer. Please check inbox for invite.
Removing the dependencies for mistune and requests seems to have resolved it. Those were there before to deal with various m2r issues with Sphinx.
> On 20 Nov 2024, at 3:08 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> I can login to readthedocs.com using my Github account (dexterbg).
> Regarding the build issue, I'd suspect an error in the requirements.txt file. I didn't change the other lines, but wondered why it defines these requirements with maximum version numbers:
> mistune<2.0.0
> requests<2.29.0
> Was that necessary for m2r2? If so, maybe try without, so pip determines the best match?
> Manually installing sphinx_mdinclude on my machine produced this constellation:
> sphinx_mdinclude              0.6.2
> mistune                       3.0.2
> requests                      2.32.3
> Am 20.11.24 um 01:01 schrieb Mark Webb-Johnson:
>> Michael,
>> Yes, readthedocs is broken. But seems to have had various problems building the docs for the past few weeks (although more to do with errors in the docs files before).
>> Build logs shown below. Seems to be a dependency problem (probably docutils vs sphinx_mdinclude). I can’t see a trivial solution (it was painful enough to get it working with m2r), and am out of time now, but will try again tonight.
>> P.S. I’ve added your eMail to the readthedocs notification list so you see build notifications. If you create an account on readthedocs.com <http://readthedocs.com/>, I can also add you as a maintainer there, if it helps.
>> Read the Docs build information
>> Build id: 26335608
>> Project: ovms
>> Version: latest
>> Commit: 1f863527d0a593fe8b10d2faee5cc0e04da4a843
>> Date: 2024-11-19T23:56:17.734263Z
>> State: finished
>> Success: False
>> [rtd-command-info] start-time: 2024-11-19T23:56:18.277210Z, end-time: 2024-11-19T23:56:22.276851Z, duration: 3, exit-code: 0
>> git clone --depth 1 https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3.git .
>> Cloning into '.'...
>> [rtd-command-info] start-time: 2024-11-19T23:56:22.296787Z, end-time: 2024-11-19T23:56:24.339706Z, duration: 2, exit-code: 0
>> git fetch origin --force --prune --prune-tags --depth 50 refs/heads/master:refs/remotes/origin/master
>> [rtd-command-info] start-time: 2024-11-19T23:56:24.414382Z, end-time: 2024-11-19T23:56:25.042773Z, duration: 0, exit-code: 0
>> git checkout --force origin/master
>> Note: switching to 'origin/master'.
>> You are in 'detached HEAD' state. You can look around, make experimental
>> changes and commit them, and you can discard any commits you make in this
>> state without impacting any branches by switching back to a branch.
>> If you want to create a new branch to retain commits you create, you may
>> do so (now or later) by using -c with the switch command. Example:
>>   git switch -c <new-branch-name>
>> Or undo this operation with:
>>   git switch -
>> Turn off this advice by setting config variable advice.detachedHead to false
>> HEAD is now at 1f86352 Include docutils, without specific version
>> [rtd-command-info] start-time: 2024-11-19T23:56:25.068777Z, end-time: 2024-11-19T23:56:25.129267Z, duration: 0, exit-code: 0
>> cat .readthedocs.yaml
>> # .readthedocs.yaml
>> # Read the Docs configuration file
>> # See https://docs.readthedocs.io/en/stable/config-file/v2.html for details
>> # Required
>> version: 2
>> # Set the version of Python and other tools you might need
>> build:
>>   os: ubuntu-22.04
>>   tools:
>>     python: "3.11"
>> # Build documentation in the docs/ directory with Sphinx
>> sphinx:
>>   configuration: docs/source/conf.py
>> # We recommend specifying your dependencies to enable reproducible builds:
>> # https://docs.readthedocs.io/en/stable/guides/reproducible-builds.html
>> python:
>>   install:
>>     - requirements: docs/source/requirements.txt
>> [rtd-command-info] start-time: 2024-11-19T23:56:30.973717Z, end-time: 2024-11-19T23:56:31.050053Z, duration: 0, exit-code: 0
>> asdf global python 3.11.10
>> [rtd-command-info] start-time: 2024-11-19T23:56:31.420254Z, end-time: 2024-11-19T23:56:32.502084Z, duration: 1, exit-code: 0
>> python -mvirtualenv $READTHEDOCS_VIRTUALENV_PATH
>> created virtual environment CPython3.11.10.final.0-64 in 772ms
>>   creator CPython3Posix(dest=/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest, clear=False, no_vcs_ignore=False, global=False)
>>   seeder FromAppData(download=False, pip=bundle, setuptools=bundle, wheel=bundle, via=copy, app_data_dir=/home/docs/.local/share/virtualenv)
>>     added seed packages: pip==23.1, setuptools==67.6.1, wheel==0.40.0
>>   activators BashActivator,CShellActivator,FishActivator,NushellActivator,PowerShellActivator,PythonActivator
>> [rtd-command-info] start-time: 2024-11-19T23:56:32.536062Z, end-time: 2024-11-19T23:56:46.548826Z, duration: 14, exit-code: 0
>> python -m pip install --upgrade --no-cache-dir pip setuptools
>> Requirement already satisfied: pip in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (23.1)
>> Collecting pip
>>   Downloading pip-24.3.1-py3-none-any.whl (1.8 MB)
>>      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.8/1.8 MB 9.8 MB/s eta 0:00:00
>> Requirement already satisfied: setuptools in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (67.6.1)
>> Collecting setuptools
>>   Downloading setuptools-75.5.0-py3-none-any.whl (1.2 MB)
>>      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.2/1.2 MB 21.1 MB/s eta 0:00:00
>> Installing collected packages: setuptools, pip
>>   Attempting uninstall: setuptools
>>     Found existing installation: setuptools 67.6.1
>>     Uninstalling setuptools-67.6.1:
>>       Successfully uninstalled setuptools-67.6.1
>>   Attempting uninstall: pip
>>     Found existing installation: pip 23.1
>>     Uninstalling pip-23.1:
>>       Successfully uninstalled pip-23.1
>> Successfully installed pip-24.3.1 setuptools-75.5.0
>> [rtd-command-info] start-time: 2024-11-19T23:56:46.593930Z, end-time: 2024-11-19T23:56:56.073085Z, duration: 9, exit-code: 0
>> python -m pip install --upgrade --no-cache-dir sphinx
>> Collecting sphinx
>>   Downloading sphinx-8.1.3-py3-none-any.whl.metadata (6.4 kB)
>> Collecting sphinxcontrib-applehelp>=1.0.7 (from sphinx)
>>   Downloading sphinxcontrib_applehelp-2.0.0-py3-none-any.whl.metadata (2.3 kB)
>> Collecting sphinxcontrib-devhelp>=1.0.6 (from sphinx)
>>   Downloading sphinxcontrib_devhelp-2.0.0-py3-none-any.whl.metadata (2.3 kB)
>> Collecting sphinxcontrib-htmlhelp>=2.0.6 (from sphinx)
>>   Downloading sphinxcontrib_htmlhelp-2.1.0-py3-none-any.whl.metadata (2.3 kB)
>> Collecting sphinxcontrib-jsmath>=1.0.1 (from sphinx)
>>   Downloading sphinxcontrib_jsmath-1.0.1-py2.py3-none-any.whl.metadata (1.4 kB)
>> Collecting sphinxcontrib-qthelp>=1.0.6 (from sphinx)
>>   Downloading sphinxcontrib_qthelp-2.0.0-py3-none-any.whl.metadata (2.3 kB)
>> Collecting sphinxcontrib-serializinghtml>=1.1.9 (from sphinx)
>>   Downloading sphinxcontrib_serializinghtml-2.0.0-py3-none-any.whl.metadata (2.4 kB)
>> Collecting Jinja2>=3.1 (from sphinx)
>>   Downloading jinja2-3.1.4-py3-none-any.whl.metadata (2.6 kB)
>> Collecting Pygments>=2.17 (from sphinx)
>>   Downloading pygments-2.18.0-py3-none-any.whl.metadata (2.5 kB)
>> Collecting docutils<0.22,>=0.20 (from sphinx)
>>   Downloading docutils-0.21.2-py3-none-any.whl.metadata (2.8 kB)
>> Collecting snowballstemmer>=2.2 (from sphinx)
>>   Downloading snowballstemmer-2.2.0-py2.py3-none-any.whl.metadata (6.5 kB)
>> Collecting babel>=2.13 (from sphinx)
>>   Downloading babel-2.16.0-py3-none-any.whl.metadata (1.5 kB)
>> Collecting alabaster>=0.7.14 (from sphinx)
>>   Downloading alabaster-1.0.0-py3-none-any.whl.metadata (2.8 kB)
>> Collecting imagesize>=1.3 (from sphinx)
>>   Downloading imagesize-1.4.1-py2.py3-none-any.whl.metadata (1.5 kB)
>> Collecting requests>=2.30.0 (from sphinx)
>>   Downloading requests-2.32.3-py3-none-any.whl.metadata (4.6 kB)
>> Collecting packaging>=23.0 (from sphinx)
>>   Downloading packaging-24.2-py3-none-any.whl.metadata (3.2 kB)
>> Collecting MarkupSafe>=2.0 (from Jinja2>=3.1->sphinx)
>>   Downloading MarkupSafe-3.0.2-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (4.0 kB)
>> Collecting charset-normalizer<4,>=2 (from requests>=2.30.0->sphinx)
>>   Downloading charset_normalizer-3.4.0-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (34 kB)
>> Collecting idna<4,>=2.5 (from requests>=2.30.0->sphinx)
>>   Downloading idna-3.10-py3-none-any.whl.metadata (10 kB)
>> Collecting urllib3<3,>=1.21.1 (from requests>=2.30.0->sphinx)
>>   Downloading urllib3-2.2.3-py3-none-any.whl.metadata (6.5 kB)
>> Collecting certifi>=2017.4.17 (from requests>=2.30.0->sphinx)
>>   Downloading certifi-2024.8.30-py3-none-any.whl.metadata (2.2 kB)
>> Downloading sphinx-8.1.3-py3-none-any.whl (3.5 MB)
>>    ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.5/3.5 MB 116.3 MB/s eta 0:00:00
>> Downloading alabaster-1.0.0-py3-none-any.whl (13 kB)
>> Downloading babel-2.16.0-py3-none-any.whl (9.6 MB)
>>    ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 9.6/9.6 MB 181.2 MB/s eta 0:00:00
>> Downloading docutils-0.21.2-py3-none-any.whl (587 kB)
>>    ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 587.4/587.4 kB 366.5 MB/s eta 0:00:00
>> Downloading imagesize-1.4.1-py2.py3-none-any.whl (8.8 kB)
>> Downloading jinja2-3.1.4-py3-none-any.whl (133 kB)
>> Downloading packaging-24.2-py3-none-any.whl (65 kB)
>> Downloading pygments-2.18.0-py3-none-any.whl (1.2 MB)
>>    ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.2/1.2 MB 365.8 MB/s eta 0:00:00
>> Downloading requests-2.32.3-py3-none-any.whl (64 kB)
>> Downloading snowballstemmer-2.2.0-py2.py3-none-any.whl (93 kB)
>> Downloading sphinxcontrib_applehelp-2.0.0-py3-none-any.whl (119 kB)
>> Downloading sphinxcontrib_devhelp-2.0.0-py3-none-any.whl (82 kB)
>> Downloading sphinxcontrib_htmlhelp-2.1.0-py3-none-any.whl (98 kB)
>> Downloading sphinxcontrib_jsmath-1.0.1-py2.py3-none-any.whl (5.1 kB)
>> Downloading sphinxcontrib_qthelp-2.0.0-py3-none-any.whl (88 kB)
>> Downloading sphinxcontrib_serializinghtml-2.0.0-py3-none-any.whl (92 kB)
>> Downloading certifi-2024.8.30-py3-none-any.whl (167 kB)
>> Downloading charset_normalizer-3.4.0-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (142 kB)
>> Downloading idna-3.10-py3-none-any.whl (70 kB)
>> Downloading MarkupSafe-3.0.2-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (23 kB)
>> Downloading urllib3-2.2.3-py3-none-any.whl (126 kB)
>> Installing collected packages: snowballstemmer, urllib3, sphinxcontrib-serializinghtml, sphinxcontrib-qthelp, sphinxcontrib-jsmath, sphinxcontrib-htmlhelp, sphinxcontrib-devhelp, sphinxcontrib-applehelp, Pygments, packaging, MarkupSafe, imagesize, idna, docutils, charset-normalizer, certifi, babel, alabaster, requests, Jinja2, sphinx
>> Successfully installed Jinja2-3.1.4 MarkupSafe-3.0.2 Pygments-2.18.0 alabaster-1.0.0 babel-2.16.0 certifi-2024.8.30 charset-normalizer-3.4.0 docutils-0.21.2 idna-3.10 imagesize-1.4.1 packaging-24.2 requests-2.32.3 snowballstemmer-2.2.0 sphinx-8.1.3 sphinxcontrib-applehelp-2.0.0 sphinxcontrib-devhelp-2.0.0 sphinxcontrib-htmlhelp-2.1.0 sphinxcontrib-jsmath-1.0.1 sphinxcontrib-qthelp-2.0.0 sphinxcontrib-serializinghtml-2.0.0 urllib3-2.2.3
>> [rtd-command-info] start-time: 2024-11-19T23:56:56.096582Z, end-time: 2024-11-19T23:56:59.156352Z, duration: 3, exit-code: 0
>> python -m pip install --exists-action=w --no-cache-dir -r docs/source/requirements.txt
>> Collecting sphinx_rtd_theme (from -r docs/source/requirements.txt (line 1))
>>   Downloading sphinx_rtd_theme-3.0.2-py2.py3-none-any.whl.metadata (4.4 kB)
>> Collecting sphinx_mdinclude (from -r docs/source/requirements.txt (line 2))
>>   Downloading sphinx_mdinclude-0.6.2-py3-none-any.whl.metadata (4.6 kB)
>> Requirement already satisfied: docutils in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from -r docs/source/requirements.txt (line 3)) (0.21.2)
>> Collecting mistune<2.0.0 (from -r docs/source/requirements.txt (line 4))
>>   Downloading mistune-0.8.4-py2.py3-none-any.whl.metadata (8.5 kB)
>> Collecting requests<2.29.0 (from -r docs/source/requirements.txt (line 5))
>>   Downloading requests-2.28.2-py3-none-any.whl.metadata (4.6 kB)
>> Requirement already satisfied: sphinx<9,>=6 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (8.1.3)
>> Collecting sphinxcontrib-jquery<5,>=4 (from sphinx_rtd_theme->-r docs/source/requirements.txt (line 1))
>>   Downloading sphinxcontrib_jquery-4.1-py2.py3-none-any.whl.metadata (2.6 kB)
>> INFO: pip is looking at multiple versions of sphinx-mdinclude to determine which version is compatible with other requirements. This could take a while.
>>   Downloading sphinx_mdinclude-0.6.1-py3-none-any.whl.metadata (4.6 kB)
>>   Downloading sphinx_mdinclude-0.6.0-py3-none-any.whl.metadata (4.6 kB)
>>   Downloading sphinx_mdinclude-0.5.4-py3-none-any.whl.metadata (4.6 kB)
>>   Downloading sphinx_mdinclude-0.5.3-py3-none-any.whl.metadata (4.1 kB)
>>   Downloading sphinx_mdinclude-0.5.2-py3-none-any.whl.metadata (4.0 kB)
>>   Downloading sphinx_mdinclude-0.5.1-py3-none-any.whl.metadata (4.0 kB)
>>   Downloading sphinx_mdinclude-0.5.0-py3-none-any.whl.metadata (4.0 kB)
>> INFO: pip is still looking at multiple versions of sphinx-mdinclude to determine which version is compatible with other requirements. This could take a while.
>>   Downloading sphinx_mdinclude-0.4.0-py3-none-any.whl.metadata (4.0 kB)
>> Requirement already satisfied: charset-normalizer<4,>=2 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from requests<2.29.0->-r docs/source/requirements.txt (line 5)) (3.4.0)
>> Requirement already satisfied: idna<4,>=2.5 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from requests<2.29.0->-r docs/source/requirements.txt (line 5)) (3.10)
>> Collecting urllib3<1.27,>=1.21.1 (from requests<2.29.0->-r docs/source/requirements.txt (line 5))
>>   Downloading urllib3-1.26.20-py2.py3-none-any.whl.metadata (50 kB)
>> Requirement already satisfied: certifi>=2017.4.17 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from requests<2.29.0->-r docs/source/requirements.txt (line 5)) (2024.8.30)
>> Requirement already satisfied: sphinxcontrib-applehelp>=1.0.7 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.0.0)
>> Requirement already satisfied: sphinxcontrib-devhelp>=1.0.6 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.0.0)
>> Requirement already satisfied: sphinxcontrib-htmlhelp>=2.0.6 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.1.0)
>> Requirement already satisfied: sphinxcontrib-jsmath>=1.0.1 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (1.0.1)
>> Requirement already satisfied: sphinxcontrib-qthelp>=1.0.6 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.0.0)
>> Requirement already satisfied: sphinxcontrib-serializinghtml>=1.1.9 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.0.0)
>> Requirement already satisfied: Jinja2>=3.1 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (3.1.4)
>> Requirement already satisfied: Pygments>=2.17 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.18.0)
>> Requirement already satisfied: snowballstemmer>=2.2 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.2.0)
>> Requirement already satisfied: babel>=2.13 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (2.16.0)
>> Requirement already satisfied: alabaster>=0.7.14 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (1.0.0)
>> Requirement already satisfied: imagesize>=1.3 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (1.4.1)
>> INFO: pip is looking at multiple versions of sphinx to determine which version is compatible with other requirements. This could take a while.
>> Collecting sphinx<9,>=6 (from sphinx_rtd_theme->-r docs/source/requirements.txt (line 1))
>>   Downloading sphinx-8.1.2-py3-none-any.whl.metadata (6.4 kB)
>>   Downloading sphinx-8.1.1-py3-none-any.whl.metadata (6.4 kB)
>>   Downloading sphinx-8.1.0-py3-none-any.whl.metadata (6.4 kB)
>>   Downloading sphinx-8.0.2-py3-none-any.whl.metadata (6.2 kB)
>>   Downloading sphinx-8.0.1-py3-none-any.whl.metadata (6.2 kB)
>>   Downloading sphinx-8.0.0-py3-none-any.whl.metadata (6.2 kB)
>>   Downloading sphinx-7.4.7-py3-none-any.whl.metadata (6.1 kB)
>> Collecting alabaster~=0.7.14 (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1))
>>   Downloading alabaster-0.7.16-py3-none-any.whl.metadata (2.9 kB)
>> INFO: pip is still looking at multiple versions of sphinx to determine which version is compatible with other requirements. This could take a while.
>>   Downloading sphinx-7.4.6-py3-none-any.whl.metadata (6.1 kB)
>>   Downloading sphinx-7.4.5-py3-none-any.whl.metadata (6.1 kB)
>>   Downloading sphinx-7.4.4-py3-none-any.whl.metadata (6.1 kB)
>>   Downloading sphinx-7.4.3-py3-none-any.whl.metadata (6.1 kB)
>>   Downloading sphinx-7.4.2-py3-none-any.whl.metadata (6.1 kB)
>> INFO: This is taking longer than usual. You might need to provide the dependency resolver with stricter constraints to reduce runtime. See https://pip.pypa.io/warnings/backtracking for guidance. If you want to abort this run, press Ctrl + C.
>>   Downloading sphinx-7.4.1-py3-none-any.whl.metadata (6.1 kB)
>>   Downloading sphinx-7.4.0-py3-none-any.whl.metadata (6.1 kB)
>>   Downloading sphinx-7.3.7-py3-none-any.whl.metadata (6.0 kB)
>> Requirement already satisfied: packaging>=21.0 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (24.2)
>> Requirement already satisfied: MarkupSafe>=2.0 in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages (from Jinja2>=3.1->sphinx<9,>=6->sphinx_rtd_theme->-r docs/source/requirements.txt (line 1)) (3.0.2)
>> Downloading sphinx_rtd_theme-3.0.2-py2.py3-none-any.whl (7.7 MB)
>>    ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 7.7/7.7 MB 143.1 MB/s eta 0:00:00
>> Downloading sphinx_mdinclude-0.4.0-py3-none-any.whl (14 kB)
>> Downloading mistune-0.8.4-py2.py3-none-any.whl (16 kB)
>> Downloading requests-2.28.2-py3-none-any.whl (62 kB)
>> Downloading sphinx-7.3.7-py3-none-any.whl (3.3 MB)
>>    ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.3/3.3 MB 164.0 MB/s eta 0:00:00
>> Downloading sphinxcontrib_jquery-4.1-py2.py3-none-any.whl (121 kB)
>> Downloading urllib3-1.26.20-py2.py3-none-any.whl (144 kB)
>> Downloading alabaster-0.7.16-py3-none-any.whl (13 kB)
>> Installing collected packages: mistune, urllib3, sphinx_mdinclude, alabaster, requests, sphinx, sphinxcontrib-jquery, sphinx_rtd_theme
>>   Attempting uninstall: urllib3
>>     Found existing installation: urllib3 2.2.3
>>     Uninstalling urllib3-2.2.3:
>>       Successfully uninstalled urllib3-2.2.3
>>   Attempting uninstall: alabaster
>>     Found existing installation: alabaster 1.0.0
>>     Uninstalling alabaster-1.0.0:
>>       Successfully uninstalled alabaster-1.0.0
>>   Attempting uninstall: requests
>>     Found existing installation: requests 2.32.3
>>     Uninstalling requests-2.32.3:
>>       Successfully uninstalled requests-2.32.3
>>   Attempting uninstall: sphinx
>>     Found existing installation: Sphinx 8.1.3
>>     Uninstalling Sphinx-8.1.3:
>>       Successfully uninstalled Sphinx-8.1.3
>> Successfully installed alabaster-0.7.16 mistune-0.8.4 requests-2.28.2 sphinx-7.3.7 sphinx_mdinclude-0.4.0 sphinx_rtd_theme-3.0.2 sphinxcontrib-jquery-4.1 urllib3-1.26.20
>> [rtd-command-info] start-time: 2024-11-19T23:56:59.229935Z, end-time: 2024-11-19T23:56:59.285486Z, duration: 0, exit-code: 0
>> cat docs/source/conf.py
>> # Configuration file for the Sphinx documentation builder.
>> # This file only contains a selection of the most common options. For a full
>> # list see the documentation:
>> # http://www.sphinx-doc.org/en/master/config
>> # -- Path setup --------------------------------------------------------------
>> # If extensions (or modules to document with autodoc) are in another directory,
>> # add these directories to sys.path here. If the directory is relative to the
>> # documentation root, use os.path.abspath to make it absolute, like shown here.
>> # import os
>> # import sys
>> # sys.path.insert(0, os.path.abspath('.'))
>> # -- Project information -----------------------------------------------------
>> project = 'Open Vehicles'
>> copyright = '2019-2024, Open Vehicles Developers'
>> author = 'Open Vehicle Developers'
>> # -- General configuration ---------------------------------------------------
>> # Add any Sphinx extension module names here, as strings. They can be
>> # extensions coming with Sphinx (named 'sphinx.ext.*') or your custom
>> # ones.
>> extensions = [
>>   'sphinx_mdinclude',
>> # Add any paths that contain templates here, relative to this directory.
>> templates_path = ['_templates']
>> # List of patterns, relative to source directory, that match files and
>> # directories to ignore when looking for source files.
>> # This pattern also affects html_static_path and html_extra_path.
>> exclude_patterns = [
>>   'docs',
>>   '*/**.md',
>>   '*/wolfssl/*',
>>   '*/duktape/*',
>>   '*/mongoose/*',
>> master_doc = 'index'
>> # -- Source configuration ----------------------------------------------------
>> # - |clearfix| global substitution to clear floats (e.g. images)
>> rst_epilog = """
>> .. |clearfix| raw:: html
>>   <div class="clearfix"></div>
>> # -- Options for HTML output -------------------------------------------------
>> # The theme to use for HTML and HTML Help pages.  See the documentation for
>> # a list of builtin themes.
>> #html_theme = 'default'
>> html_theme = 'sphinx_rtd_theme'
>> # Add any paths that contain custom static files (such as style sheets) here,
>> # relative to this directory. They are copied after the builtin static files,
>> # so a file named "default.css" will overwrite the builtin "default.css".
>> html_static_path = ['_static']
>> html_context = {
>> def setup(app):
>>     app.add_css_file('theme_overrides.css')
>>     app.add_css_file('copybutton.css')
>>     app.add_js_file('clipboard.min.js')
>>     app.add_js_file('copybutton.js')
>> [rtd-command-info] start-time: 2024-11-19T23:56:59.307664Z, end-time: 2024-11-19T23:56:59.818337Z, duration: 0, exit-code: 2
>> python -m sphinx -T -b html -d _build/doctrees -D language=en . $READTHEDOCS_OUTPUT/html
>> Running Sphinx v7.3.7
>> Traceback (most recent call last):
>>   File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx/registry.py", line 453, in load_extension
>>     mod = import_module(extname)
>>   File "/home/docs/.asdf/installs/python/3.11.10/lib/python3.11/importlib/__init__.py", line 126, in import_module
>>     return _bootstrap._gcd_import(name[level:], package, level)
>>   File "<frozen importlib._bootstrap>", line 1204, in _gcd_import
>>   File "<frozen importlib._bootstrap>", line 1176, in _find_and_load
>>   File "<frozen importlib._bootstrap>", line 1147, in _find_and_load_unlocked
>>   File "<frozen importlib._bootstrap>", line 690, in _load_unlocked
>>   File "<frozen importlib._bootstrap_external>", line 940, in exec_module
>>   File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
>>   File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx_mdinclude/__init__.py", line 17, in <module>
>>     from docutils.core import ErrorString
>> ImportError: cannot import name 'ErrorString' from 'docutils.core' (/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/docutils/core.py)
>> The above exception was the direct cause of the following exception:
>>   File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx/cmd/build.py", line 332, in build_main
>>     app = Sphinx(args.sourcedir, args.confdir, args.outputdir,
>>   File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx/application.py", line 229, in __init__
>>     self.setup_extension(extension)
>>   File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx/application.py", line 402, in setup_extension
>>     self.registry.load_extension(self, extname)
>>   File "/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/sphinx/registry.py", line 456, in load_extension
>>     raise ExtensionError(__('Could not import extension %s') % extname,
>> sphinx.errors.ExtensionError: Could not import extension sphinx_mdinclude (exception: cannot import name 'ErrorString' from 'docutils.core' (/home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.11/site-packages/docutils/core.py))
>> Extension error:
>>> On 20 Nov 2024, at 2:22 AM, Michael Balzer via OvmsDev <ovmsdev at lists.openvehicles.com> <mailto:ovmsdev at lists.openvehicles.com> wrote:
>>> Signed PGP part
>>> I've switched the plugin from m2r2 to sphinx_mdinclude, works here as well.
>>> Note: I've kept the name consistent for the install documentation, this works due to pip automatically switching between underscore & dash as needed.
>>> @Mark: I guess this also needs some change to the ReadTheDocs configuration?
>>> Am 17.11.24 um 23:59 schrieb Michael Geddes:
>>>> Michael what do you think of switching over to mdinclude?
>>>> On Mon, 18 Nov 2024, 05:28 Craig Leres, <leres at xse.com <mailto:leres at xse.com>> wrote:
>>>>> On 11/16/24 16:19, Michael Geddes via OvmsDev wrote:
>>>>> > For some reason I was getting run-time python errors with m2r2 which is
>>>>> > why I tried switching to mdinclude.
>>>>> Over here in FreeBSD-land, I can "gmake html" if I change conf.py to use
>>>>> sphinx_mdinclude instead of m2r2.
>>>>>                 Craig
>>>>> ice 4003 % pkg info | fgrep sphinx
>>>>> py311-sphinx-5.3.0_3,1         Python documentation generator
>>>>> py311-sphinx-mdinclude-0.6.2   Sphinx extension that enables including
>>>>> Markdown documents
>>>>> py311-sphinx_rtd_theme-1.0.0   Mobile-friendly py-sphinx theme
>>>>> py311-sphinxcontrib-applehelp-1.0.2 Extension which outputs Apple help books
>>>>> py311-sphinxcontrib-devhelp-1.0.2 Sphinx extension which outputs Devhelp
>>>>> document
>>>>> py311-sphinxcontrib-htmlhelp-2.1.0 Sphinx extension which renders HTML
>>>>> help files
>>>>> py311-sphinxcontrib-jsmath-1.0.1 Sphinx extension which renders display
>>>>> math in HTML via JavaScript
>>>>> py311-sphinxcontrib-qthelp-2.0.0 Sphinx extension which outputs QtHelp
>>>>> document
>>>>> py311-sphinxcontrib-serializinghtml-2.0.0 Sphinx extension which outputs
>>>>> serialized HTML files (json and pickle)
>>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241120/6fc9efa5/attachment-0001.htm>
