[Ovmsdev] OBD poller module shell proposal
Thu Mar 14 12:07:53 HKT 2024
Michael,
I suggest that if it is a separate component then better to move it to it’s own component directory (just as canopen is done).
For completeness, I suggest it would also be good to include a CONFIG_OVMS_COMP_* sdkconfig (default: yes), and put that as a requirement for your component (as well as for any vehicle doing polling, I guess).
> On 14 Mar 2024, at 11:01 AM, Michael Geddes <frog at bunyip.wheelycreek.net> wrote:
> Thanks Michael, Mark,
> Sorry for not acknowledging earlier.. this feedback is great; I've just been cogitating on the consequences.
> I still have the Poller hanging onto the vehicle by a thread so I should just cut the thread making the Poller a separate singleton (it's still embedded in the vehicle class for now with a small interface joining them).
> If I do, does it need to get moved to a new directory or can it stay in the vehicle/ directory? The file vehicle_poller.cpp (and the _isotp and vwtp parts to it) are still pretty much as they were with only a change in class name..
> I think I just need the poller to get its own values of m_can1 etc and provide a different way of getting the feedback results.
> I also need to make sure I'm not cutting off the 'vehicle' class' access to non-solicited messages (ie stuff that is just on the bus).
> //.ichael
> On Mon, 11 Mar 2024 at 14:51, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> Actually, separating the poller from the vehicle was part of the plan of reworking it into a job/worker architecture. I see no reason the generalized poller would need to remain coupled to the vehicle.
>> That's why I placed the OBD single request command in the "obdii" hierarchy (although a more proper naming would have been e.g. "isotp", but changing the name or having both would confuse users -- and meanwhile the poller also supports a non-ISO TP variant).
>> Am 11.03.24 um 00:51 schrieb Mark Webb-Johnson:
>>> Michael,
>>> It depends on whether the poller can *only* be used in the vehicle class or if it is a framework all by itself (for example with commands to manually poll specific PIDs, etc).
>>> If *only* within vehicle framework, then putting it as a sub-command under ‘vehicle’ seems sensible.
>>> If more general purpose, then perhaps look at ‘copen’ (component/canopen) as an example.
>>>> On 10 Mar 2024, at 7:25 AM, Michael Geddes <frog at bunyip.wheelycreek.net> <mailto:frog at bunyip.wheelycreek.net> wrote:
>>>> Hi all,
>>>> I know some of this (especially for the status) functionality is predicated on code that's not gone up yet - however this is allowing 'pause' and 'resume' of the poller (which has been merged).
>>>> My question is not so much about the functionality and status information, but about the location of the poller subcommand. (See below).
>>>> Should 'vehicle' be exclusively for switching the vehicle type? Should the 'poller' command be top-level? Under obdii?
>>>> Thoughts welcome.
>>>> If you do vehicle poller pause then the last line reads 'Vehicle OBD Polling is paused'
>>>> -------8<----------------------------------------
>>>> OVMS# vehicle ?
>>>> Usage: vehicle [list|module|poller|status]
>>>> list Show list of available vehicle modules
>>>> module Set (or clear) vehicle module
>>>> poller OBD polling status
>>>> status Show vehicle module status
>>>> OVMS# vehicle poller ?
>>>> Usage: vehicle poller [pause|resume]
>>>> pause Pause OBD Polling
>>>> resume Resume OBD Polling
>>>> OBD Polling running on bus 1 with an active list
>>>> Time between polling ticks is 1000ms with 1 secondary sub-ticks
>>>> Last poll command received 1s (ticks) ago.
>>>> Vehicle OBD Polling is running.
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240314/c6ee290c/attachment.htm>
