[Ovmsdev] OBD poller module shell proposal
Sun Mar 17 16:58:05 HKT 2024
Thanks Michael,
I'll definitely add the config - pretty much sorted out the singleton
(except for the change of directory).  Just wondering if I should rebase
this change down earlier or just keep it as the 'last change' that is
making the final break.  It might be a better transition that way?
Anyway have a look at this little class below; we have a bunch of different
implementations for an event register and came up with the
OvmsCallBackRegister below.
In my example the event notification looks like this:
    void PollRunFinished(canbus *bus)
      m_runfinished_callback.Call(
        [bus](const std::string &name, const PollCallback &cb)
          cb(bus, nullptr);
I could possibly but it in main/ovms_utils.h  ??  It could also use a
std:map to implement it, though I think we save space this way and tbh the
use case wouldn't be doing a lot of Register and Unregister which would be
the slowest operations...   I've made it not shrink the list size .... but
again, not that important in the context.
Thoughts?
//.ichael
--------------8< -----------------------------------
/* Call-back register.
 * The list does not shrink which is fine for this use-case.
 * Can be made inexpensively threadsafe/re-entrant safe.
template <typename FN>
class OvmsCallBackRegister
  private:
  class CallbackEntry
    public:
      CallbackEntry(const std::string &caller, FN callback)
        m_name = caller;
        m_callback = callback;
      ~CallbackEntry() {}
    public:
      std::string m_name;
      FN m_callback;
    typedef std::forward_list<CallbackEntry> callbacklist_t;
    callbacklist_t m_list;
  public:
    ~OvmsCallBackRegister()
    void Register(const std::string &nametag, FN callback)
      // Replace
      for (auto it = m_list.begin(); it != m_list.end(); ++it)
        if ((*it).m_name == nametag)
          (*it).m_callback = callback;
          return;
      if (!callback)
        return;
        if (!(*it).m_callback)
          CallbackEntry &entry = *it;
          entry.m_name = nametag;
          entry.m_callback = callback;
          return;
      m_list.push_front(CallbackEntry(nametag, callback));
    void Deregister(const std::string &nametag)
      Register(nametag, nullptr);
    typedef std::function<void (const std::string &nametag, FN callback)>
visit_fn_t;
    void Call(visit_fn_t visit)
        const CallbackEntry &entry = *it;
        if (entry.m_callback)
          visit(entry.m_name, entry.m_callback);
On Thu, 14 Mar 2024 at 12:08, Mark Webb-Johnson <mark at webb-johnson.net>
wrote:
> Michael,
> I suggest that if it is a separate component then better to move it to
> it’s own component directory (just as canopen is done).
> For completeness, I suggest it would also be good to include
> a CONFIG_OVMS_COMP_* sdkconfig (default: yes), and put that as a
> requirement for your component (as well as for any vehicle doing polling, I
> guess).
> Regards, Mark
> On 14 Mar 2024, at 11:01 AM, Michael Geddes <frog at bunyip.wheelycreek.net>
> wrote:
> Thanks Michael, Mark,
> Sorry for not acknowledging earlier.. this feedback is great; I've just
> been cogitating on the consequences.
> I still have the Poller hanging onto the vehicle by a thread so I should
> just cut the thread making the Poller a separate singleton (it's still
> embedded in the vehicle class for now with a small interface joining them).
> If I do, does it need to get moved to a new directory or can it stay in
> the vehicle/ directory?  The file vehicle_poller.cpp (and the _isotp and
> vwtp parts to it) are still pretty much as they were with only a change in
> class name..
> I think I just need the poller to get its own values of m_can1 etc and
> provide a different way of getting the feedback results.
> I also need to make sure I'm not cutting off the 'vehicle' class' access
> to non-solicited messages (ie stuff that is just on the bus).
> //.ichael
> On Mon, 11 Mar 2024 at 14:51, Michael Balzer <dexter at expeedo.de> wrote:
>> Actually, separating the poller from the vehicle was part of the plan of
>> reworking it into a job/worker architecture. I see no reason the
>> generalized poller would need to remain coupled to the vehicle.
>> That's why I placed the OBD single request command in the "obdii"
>> hierarchy (although a more proper naming would have been e.g. "isotp", but
>> changing the name or having both would confuse users -- and meanwhile the
>> poller also supports a non-ISO TP variant).
>> Am 11.03.24 um 00:51 schrieb Mark Webb-Johnson:
>> Michael,
>> It depends on whether the poller can *only* be used in the vehicle class
>> or if it is a framework all by itself (for example with commands to
>> manually poll specific PIDs, etc).
>> If *only* within vehicle framework, then putting it as a sub-command
>> under ‘vehicle’ seems sensible.
>> If more general purpose, then perhaps look at ‘copen’ (component/canopen)
>> as an example.
>> On 10 Mar 2024, at 7:25 AM, Michael Geddes <frog at bunyip.wheelycreek.net>
>> <frog at bunyip.wheelycreek.net> wrote:
>> Hi all,
>> I know some of this (especially for the status) functionality is
>> predicated on code that's not gone up yet - however this is allowing
>> 'pause' and 'resume' of the poller (which has been merged).
>> My question is not so much about the functionality and status
>> information, but about the location of the *poller* subcommand. (See
>> below).
>> Should 'vehicle' be exclusively for switching the vehicle type?  Should
>> the 'poller' command be top-level?  Under obdii?
>> Thoughts welcome.
>> If you do  vehicle poller pause  then the last line reads  'Vehicle OBD
>> Polling is paused'
>> -------8<----------------------------------------
>> *OVMS# vehicle ?*
>> Usage: vehicle [list|module|poller|status]
>> list                 Show list of available vehicle modules
>> module               Set (or clear) vehicle module
>> poller               OBD polling status
>> status               Show vehicle module status
>> *OVMS# vehicle poller ?*
>> Usage: vehicle poller [pause|resume]
>> pause                Pause OBD Polling
>> resume               Resume OBD Polling
>> *OVMS# vehicle poller*
>> OBD Polling running on bus 1 with an active list
>> Time between polling ticks is 1000ms with 1 secondary sub-ticks
>> Last poll command received 1s (ticks) ago.
>> Vehicle OBD Polling is running.
>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240317/c628ee80/attachment.htm>
