[Ovmsdev] OBD poller module shell proposal
Michael Geddes
Thu Mar 14 11:01:41 HKT 2024
Thanks Michael, Mark,
Sorry for not acknowledging earlier.. this feedback is great; I've just
been cogitating on the consequences.
I still have the Poller hanging onto the vehicle by a thread so I should
just cut the thread making the Poller a separate singleton (it's still
embedded in the vehicle class for now with a small interface joining them).
If I do, does it need to get moved to a new directory or can it stay in the
vehicle/ directory? The file vehicle_poller.cpp (and the _isotp and vwtp
parts to it) are still pretty much as they were with only a change in class
name..
I think I just need the poller to get its own values of m_can1 etc and
provide a different way of getting the feedback results.
I also need to make sure I'm not cutting off the 'vehicle' class' access to
non-solicited messages (ie stuff that is just on the bus).
//.ichael
On Mon, 11 Mar 2024 at 14:51, Michael Balzer <dexter at expeedo.de> wrote:
> Actually, separating the poller from the vehicle was part of the plan of
> reworking it into a job/worker architecture. I see no reason the
> generalized poller would need to remain coupled to the vehicle.
> That's why I placed the OBD single request command in the "obdii"
> hierarchy (although a more proper naming would have been e.g. "isotp", but
> changing the name or having both would confuse users -- and meanwhile the
> poller also supports a non-ISO TP variant).
> Am 11.03.24 um 00:51 schrieb Mark Webb-Johnson:
> Michael,
> It depends on whether the poller can *only* be used in the vehicle class
> or if it is a framework all by itself (for example with commands to
> manually poll specific PIDs, etc).
> If *only* within vehicle framework, then putting it as a sub-command under
> ‘vehicle’ seems sensible.
> If more general purpose, then perhaps look at ‘copen’ (component/canopen)
> as an example.
> On 10 Mar 2024, at 7:25 AM, Michael Geddes <frog at bunyip.wheelycreek.net>
> <frog at bunyip.wheelycreek.net> wrote:
> Hi all,
> I know some of this (especially for the status) functionality is
> predicated on code that's not gone up yet - however this is allowing
> 'pause' and 'resume' of the poller (which has been merged).
> My question is not so much about the functionality and status information,
> but about the location of the *poller* subcommand. (See below).
> Should 'vehicle' be exclusively for switching the vehicle type? Should
> the 'poller' command be top-level? Under obdii?
> Thoughts welcome.
> If you do vehicle poller pause then the last line reads 'Vehicle OBD
> Polling is paused'
> -------8<----------------------------------------
> *OVMS# vehicle ?*
> Usage: vehicle [list|module|poller|status]
> list Show list of available vehicle modules
> module Set (or clear) vehicle module
> poller OBD polling status
> status Show vehicle module status
> *OVMS# vehicle poller ?*
> Usage: vehicle poller [pause|resume]
> pause Pause OBD Polling
> resume Resume OBD Polling
> *OVMS# vehicle poller*
> OBD Polling running on bus 1 with an active list
> Time between polling ticks is 1000ms with 1 secondary sub-ticks
> Last poll command received 1s (ticks) ago.
> Vehicle OBD Polling is running.
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240314/61d06669/attachment.htm>
