[Ovmsdev] OBD poller module shell proposal
Mon Mar 11 14:51:15 HKT 2024
Actually, separating the poller from the vehicle was part of the plan of
reworking it into a job/worker architecture. I see no reason the
generalized poller would need to remain coupled to the vehicle.
That's why I placed the OBD single request command in the "obdii"
hierarchy (although a more proper naming would have been e.g. "isotp",
but changing the name or having both would confuse users -- and
meanwhile the poller also supports a non-ISO TP variant).
Am 11.03.24 um 00:51 schrieb Mark Webb-Johnson:
> Michael,
> It depends on whether the poller can *only* be used in the vehicle
> class or if it is a framework all by itself (for example with commands
> to manually poll specific PIDs, etc).
> If *only* within vehicle framework, then putting it as a sub-command
> under ‘vehicle’ seems sensible.
> If more general purpose, then perhaps look at ‘copen’
> (component/canopen) as an example.
>> On 10 Mar 2024, at 7:25 AM, Michael Geddes
>> <frog at bunyip.wheelycreek.net> wrote:
>> Hi all,
>> I know some of this (especially for the status) functionality is
>> predicated on code that's not gone up yet - however this is allowing
>> 'pause' and 'resume' of the poller (which has been merged).
>> My question is not so much about the functionality and status
>> information, but about the location of the *poller* subcommand. (See
>> below).
>> Should 'vehicle' be exclusively for switching the vehicle type?
>> Should the 'poller' command be top-level? Under obdii?
>> Thoughts welcome.
>> If you do vehicle poller pause then the last line reads 'Vehicle
>> OBD Polling is paused'
>> -------8<----------------------------------------
>> *OVMS# vehicle ?*
>> Usage: vehicle [list|module|poller|status]
>> list Show list of available vehicle modules
>> module Set (or clear) vehicle module
>> poller OBD polling status
>> status Show vehicle module status
>> *OVMS# vehicle poller ?*
>> Usage: vehicle poller [pause|resume]
>> pause Pause OBD Polling
>> resume Resume OBD Polling*
>> *OVMS# vehicle poller*
>> OBD Polling running on bus 1 with an active list
>> Time between polling ticks is 1000ms with 1 secondary sub-ticks
>> Last poll command received 1s (ticks) ago.
>> Vehicle OBD Polling is running.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240311/257353b8/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240311/257353b8/attachment.sig>
