[Ovmsdev] OBD poller module shell proposal
Mon Mar 11 07:51:51 HKT 2024
Michael,
It depends on whether the poller can *only* be used in the vehicle class or if it is a framework all by itself (for example with commands to manually poll specific PIDs, etc).
If *only* within vehicle framework, then putting it as a sub-command under ‘vehicle’ seems sensible.
If more general purpose, then perhaps look at ‘copen’ (component/canopen) as an example.
> On 10 Mar 2024, at 7:25 AM, Michael Geddes <frog at bunyip.wheelycreek.net> wrote:
> Hi all,
> I know some of this (especially for the status) functionality is predicated on code that's not gone up yet - however this is allowing 'pause' and 'resume' of the poller (which has been merged).
> My question is not so much about the functionality and status information, but about the location of the poller subcommand. (See below).
> Should 'vehicle' be exclusively for switching the vehicle type?  Should the 'poller' command be top-level?  Under obdii?
> Thoughts welcome.
> If you do  vehicle poller pause  then the last line reads  'Vehicle OBD Polling is paused'
> -------8<----------------------------------------
> OVMS# vehicle ?
> Usage: vehicle [list|module|poller|status]
> list                 Show list of available vehicle modules
> module               Set (or clear) vehicle module
> poller               OBD polling status
> status               Show vehicle module status
> OVMS# vehicle poller ?
> Usage: vehicle poller [pause|resume]
> pause                Pause OBD Polling
> resume               Resume OBD Polling
> OBD Polling running on bus 1 with an active list
> Time between polling ticks is 1000ms with 1 secondary sub-ticks
> Last poll command received 1s (ticks) ago.
> Vehicle OBD Polling is running.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240311/b0046be4/attachment.htm>
