[Ovmsdev] OBD poller module shell proposal
Michael Geddes
Sun Mar 10 07:25:36 HKT 2024
Hi all,
I know some of this (especially for the status) functionality is predicated
on code that's not gone up yet - however this is allowing 'pause' and
'resume' of the poller (which has been merged).
My question is not so much about the functionality and status information,
but about the location of the *poller* subcommand. (See below).
Should 'vehicle' be exclusively for switching the vehicle type? Should the
'poller' command be top-level? Under obdii?
Thoughts welcome.
If you do vehicle poller pause then the last line reads 'Vehicle OBD
Polling is paused'
-------8<----------------------------------------
*OVMS# vehicle ?*
Usage: vehicle [list|module|poller|status]
list Show list of available vehicle modules
module Set (or clear) vehicle module
poller OBD polling status
status Show vehicle module status
*OVMS# vehicle poller ?*
Usage: vehicle poller [pause|resume]
pause Pause OBD Polling
resume Resume OBD Polling
*OVMS# vehicle poller*
OBD Polling running on bus 1 with an active list
Time between polling ticks is 1000ms with 1 secondary sub-ticks
Last poll command received 1s (ticks) ago.
Vehicle OBD Polling is running.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240310/ba17ac62/attachment.htm>
