[Ovmsdev] Adding Pollers object to Duktape
Sat Jul 6 16:07:42 HKT 2024
I'll change SetUserPaused. I flip flopped a bit on that so  happy to go
with your suggestion which makes sense.
The order doesn't matter on the dictionary.  A lot of JSON serialised like
to alphabetise so aware of that.
Anyway internally it's a map which doesn't guarantee order afaik. Could be
in hash order anyway!
Also That's partly why I had separate total properties on the base object.
Michael.
On Sat, 6 July 2024, 14:54 Michael Balzer via OvmsDev, <
> Michael,
> looks good to me.
> IMO API calls representing direct shell commands should not be represented
> as getters/setters in the JS API, so ".Pause()" & ".Resume()" are better.
> They are also more readable (e.g. "Resume()" vs "SetUserPaused(false)") and
> leave room for future command specific arguments.
> Using an object structure is OK for the times, unless you want/need to
> make sure the same order as with the other outputs (shell/data) will be
> kept stable on any object transformation or transfer. Object properties (if
> they are strings) are normally kept in insertion order, but only within
> Javascript. When deserializing JS objects into other environments, the
> order isn't guaranteed.
> Am 06.07.24 um 03:12 schrieb Michael Geddes via OvmsDev:
> please have a good look at the function names.. when I have Get and Set
> prefixes.. should I have them.. etc to be consistent.
> But  Just FYI (a couple of silly bugs later) - This is the full output
> from a test proving that both the 'Times' property works and that at least
> as a concept- having the "Poll:PRI" as a key works.
> ----8<-------------------
> JSON.print(OvmsPoller.Times.GetStatus())
>   "items": {
>     "Poll:PRI": {
>       "count_hz": 1.00600004196167,
>       "avg_util_pm": 0.5598000288009644,
>       "peak_util_pm": 0.6503999829292297,
>       "avg_time_ms": 0.05350000038743019,
>       "peak_time_ms": 0.9779999852180481
>     "Poll:SRX": {
>       "count_hz": 1.1330000162124634,
>       "avg_util_pm": 0.18970000743865967,
>       "peak_util_pm": 0.23240000009536743,
>       "avg_time_ms": 0.015799999237060547,
>       "peak_time_ms": 0.3319999873638153
>     "RxCan1[778]": {
>       "count_hz": 1.8489999771118164,
>       "avg_util_pm": 1.2870999574661255,
>       "peak_util_pm": 1.8909000158309937,
>       "avg_time_ms": 0.06909999996423721,
>       "peak_time_ms": 2.7119998931884766
>     "RxCan1[7bb]": {
>       "count_hz": 0.2240000069141388,
>       "avg_util_pm": 0.10409999638795853,
>       "peak_util_pm": 0.25859999656677246,
>       "avg_time_ms": 0.043800000101327896,
>       "peak_time_ms": 1.50600004196167
>     "RxCan1[7ea]": {
>       "count_hz": 1.0670000314712524,
>       "avg_util_pm": 0.4699000120162964,
>       "peak_util_pm": 0.7283999919891357,
>       "avg_time_ms": 0.04830000177025795,
>       "peak_time_ms": 1.5379999876022339
>     "RxCan1[7ec]": {
>       "count_hz": 1.8669999837875366,
>       "avg_util_pm": 0.8090000152587891,
>       "peak_util_pm": 0.9458000063896179,
>       "avg_time_ms": 0.04639999940991402,
>       "peak_time_ms": 2.2769999504089355
>     "TxCan1[770]": {
>       "count_hz": 0.9240000247955322,
>       "avg_util_pm": 0.039400000125169754,
>       "peak_util_pm": 0.054499998688697815,
>       "avg_time_ms": 0.0038999998942017555,
>       "peak_time_ms": 0.08699999749660492
>     "TxCan1[7b3]": {
>       "count_hz": 0.041999999433755875,
>       "avg_util_pm": 0.0035000001080334187,
>       "peak_util_pm": 0.008299999870359898,
>       "avg_time_ms": 0.008500000461935997,
>       "peak_time_ms": 0.09200000017881393
>     "TxCan1[7e2]": {
>       "count_hz": 0.21199999749660492,
>       "avg_util_pm": 0.01600000075995922,
>       "peak_util_pm": 0.020500000566244125,
>       "avg_time_ms": 0.006800000090152025,
>       "peak_time_ms": 0.08500000089406967
>     "TxCan1[7e4]": {
>       "avg_util_pm": 0.006899999920278788,
>       "peak_util_pm": 0.009800000116229057,
>       "avg_time_ms": 0.002899999963119626,
>       "peak_time_ms": 0.05299999937415123
>     "Cmd:Thrtl": {
>       "count_hz": 0.014999999664723873,
>       "avg_util_pm": 0.0006000000284984708,
>       "peak_util_pm": 0,
>       "avg_time_ms": 0.004699999932199717,
>       "peak_time_ms": 0.04699999839067459
>     "Cmd:State": {
>       "count_hz": 0.039000000804662704,
>       "avg_util_pm": 0.002300000051036477,
>       "peak_util_pm": 0.007000000216066837,
>       "avg_time_ms": 0.006500000134110451,
>       "peak_time_ms": 0.09000000357627869
>   "tot_count_hz": 8.59000015258789,
>   "tot_util_pm": 3.488300085067749,
>   "tot_time_ms": 3.1019999980926514
> On Wed, 3 Jul 2024 at 14:31, Michael Geddes <frog at bunyip.wheelycreek.net>
> wrote:
>> OH, and also,
>> What do you think of treating the OvmsPoller.Times.GetStatus() items as
>> an associative array - or should I treat it as a normal array?
>> //.ichael
>> On Wed, 3 Jul 2024 at 14:24, Michael Geddes <frog at bunyip.wheelycreek.net>
>> wrote:
>>> I figured I may as well add an OvmsPoller object to DukTape for Ovms.
>>>  I'm waiting to get back to my OVMS so that I can test it.. but this is the
>>> documentation I have for the stuff I have coded. Thoughts on this?
>>> What do people think of OvmsPoller.Times sub-object?   I've added a
>>> general mechanism for this.
>>> Also should I have OvmsPoller.Pause()  or
>>> OvmsPoller.SetUserPaused(true)  ?
>>> OvmsPoller
>>> The Ovms Poller object represents the poller sub-system. It contains the
>>> following methods:
>>> - ``ispaused = OvmsPoller.GetPaused()``: Return true if the poller is
>>> paused by the system/user.
>>> - ``ispaused = OvmsPoller.GetUserPaused()``: Return true if the poller
>>> is paused by the user.
>>> - ``OvmsPoller.Pause()``: Pause the poller (adds User poller pause)
>>> - ``OvmsPoller.Resume()``: Remove the User poller pause.
>>> - ``tracemode = OvmsPoller.GetTrace()``: Return the current trace mode.
>>> - ``OvmsPoller.SetTrace(tracemode)``: Set the current trace mode.
>>>     The Traces still require that 'Verbose' and 'Debug' levels
>>> (depending) for the 'vehicle-poll'
>>>     debug tag are set.
>>>     Trace modes for verbose logging can be one of:
>>>     - ``on``: On for poller loop
>>>     - ``txrx``: On for txrx queue (this can be hazardous for some cars)
>>>     - ``all``: On for both poller loop and txrx queuing
>>>     - ``off``: Logging Off
>>>     Note that only ``on`` and ``off`` are recommended.
>>> The poller object also contains a ``Times`` property for the OBD
>>> Poll-Time tracing
>>> which contains the following methods:
>>> - ``isrunning = OvmsPoller.Times.GetEnabled()``: Returns true if the
>>> time-tracing is enabled
>>> - ``OvmsPoller.Times.SetEnabled(isrunning)``: Sets the enabled status of
>>> the timer-tracing
>>> - ``OvmsPoller.Times.Reset()``: Reset the timers (doesn't affect their
>>> current state).
>>> - ``OvmsPoller.Times.GetStatus()``: Gets the status of the various
>>> times. This returns an object
>>>     of this format:
>>>     .. code-block:: javascript
>>>     return_value = {
>>>       "items": {
>>>         "Poll:PRI" : {
>>>           "count_hz":    1,
>>>           "avg_util_pm": 0.529,
>>>           "peak_util_pm":0.652,
>>>           "avg_time_ms": 0.052,
>>>           "peak_time_ms":1.516
>>>         "Poll:SRX": {
>>>           "count_hz":    1.47,
>>>           "avg_util_pm": 0.302,
>>>           "peak_util_pm":0.44,
>>>           "avg_time_ms": 0.02,
>>>           "peak_time_ms":0.573
>>>         "RxCan1[778]": {
>>>           "count_hz":    0.74,
>>>           "avg_util_pm": 0.427,
>>>           "peak_util_pm":0.826,
>>>           "avg_time_ms": 0.063,
>>>           "peak_time_ms":1.872
>>>         "RxCan1[7a8]": {
>>>           "count_hz":    0.35,
>>>           "avg_util_pm": 0.183,
>>>           "peak_util_pm":0.355,
>>>           "peak_time_ms":1.382
>>>         "TxCan1[7b3]": {
>>>           "count_hz":    0.07,
>>>           "avg_util_pm": 0.005,
>>>           "peak_util_pm":0.01,
>>>           "avg_time_ms": 0.007,
>>>           "peak_time_ms":0.099
>>>         "TxCan1[7c6]": {
>>>           "count_hz":    0,
>>>           "avg_util_pm": 0,
>>>           "peak_util_pm":0.009,
>>>           "avg_time_ms": 0.004,
>>>           "peak_time_ms":0.098
>>>         "Cmd:State": {
>>>           "count_hz":    0,
>>>           "avg_util_pm": 0,
>>>           "peak_util_pm":0,
>>>           "avg_time_ms": 0.011,
>>>           "peak_time_ms":0.109
>>>       "tot_count_hz": 11.76,
>>>       "tot_util_pm": 6.247,
>>>       "tot_time_ms": 4.628
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240706/ef292456/attachment-0001.htm>
