[Ovmsdev] Adding Pollers object to Duktape
Michael Geddes
Sun Jul 7 08:43:33 HKT 2024
Soo.. for the start stop of the Poller itself we still have
OvmsPoller.Pause
OvmsPoller.Resume
print(OvmsPoller.GetUserPaused())
then for the timer we now have
OvmsPoller.Times.Start
OvmsPoller.Times.Stop
print( OvmsPoller.Times.GetStarted())
For the tracing (which is simply setting 2 bits) I'm torn between having
the following mirroring the commands:
OvmsPoller.Trace.On(),
OvmsPoller.Trace.TxRx()
OvmsPoller.Trace.AllOn()
OvmsPoller.Trace.Off()
print(OvmsPoller.Trace.GetStatus())
Or to have 2 properties 'Trace.Poller' and 'Trace.TxRx' with "C"
getter/setter (which I have implemented successfully)
OvmsPoller.Trace.Poller = true
OvmsPoller.Trace.TxRx = false
print(OvmsPoller.Trace.Poller)
I don't know about the existing GetTrace() and SetTrace("on") - it does
work but it's a bit clunky
The registering of the getter/setters was a bit of work - but in the end
looks like this in code!
DuktapeObjectRegistration* dto_trace =
new DuktapeObjectRegistration("OvmsPollerTrace");
dto_trace->RegisterDuktapeProperty(DukOvmsPollerTracePollerGet,DukOvmsPollerTracePollerSet,
0, "Poller");
dto_trace->RegisterDuktapeProperty(DukOvmsPollerTraceTxRxGet,DukOvmsPollerTraceTxRxSet,
0, "TxRx");
dto->RegisterDuktapeObject(dto_trace, "Trace");
I do like the splitting of functionality using 'Trace' and 'Times' to
mirror sub-commands.
Thoughts?
//.ichael
On Sat, 6 Jul 2024 at 16:07, Michael Geddes <frog at bunyip.wheelycreek.net>
wrote:
> I'll change SetUserPaused. I flip flopped a bit on that so happy to go
> with your suggestion which makes sense.
> The order doesn't matter on the dictionary. A lot of JSON serialised like
> to alphabetise so aware of that.
> Anyway internally it's a map which doesn't guarantee order afaik. Could be
> in hash order anyway!
> Also That's partly why I had separate total properties on the base object.
> Michael.
> On Sat, 6 July 2024, 14:54 Michael Balzer via OvmsDev, <
> ovmsdev at lists.openvehicles.com> wrote:
>> Michael,
>> looks good to me.
>> IMO API calls representing direct shell commands should not be
>> represented as getters/setters in the JS API, so ".Pause()" & ".Resume()"
>> are better. They are also more readable (e.g. "Resume()" vs
>> "SetUserPaused(false)") and leave room for future command specific
>> arguments.
>> Using an object structure is OK for the times, unless you want/need to
>> make sure the same order as with the other outputs (shell/data) will be
>> kept stable on any object transformation or transfer. Object properties (if
>> they are strings) are normally kept in insertion order, but only within
>> Javascript. When deserializing JS objects into other environments, the
>> order isn't guaranteed.
>> Am 06.07.24 um 03:12 schrieb Michael Geddes via OvmsDev:
>> please have a good look at the function names.. when I have Get and Set
>> prefixes.. should I have them.. etc to be consistent.
>> But Just FYI (a couple of silly bugs later) - This is the full output
>> from a test proving that both the 'Times' property works and that at least
>> as a concept- having the "Poll:PRI" as a key works.
>> ----8<-------------------
>> JSON.print(OvmsPoller.Times.GetStatus())
>> "items": {
>> "Poll:PRI": {
>> "count_hz": 1.00600004196167,
>> "avg_util_pm": 0.5598000288009644,
>> "peak_util_pm": 0.6503999829292297,
>> "avg_time_ms": 0.05350000038743019,
>> "peak_time_ms": 0.9779999852180481
>> "Poll:SRX": {
>> "count_hz": 1.1330000162124634,
>> "avg_util_pm": 0.18970000743865967,
>> "peak_util_pm": 0.23240000009536743,
>> "avg_time_ms": 0.015799999237060547,
>> "peak_time_ms": 0.3319999873638153
>> "RxCan1[778]": {
>> "count_hz": 1.8489999771118164,
>> "avg_util_pm": 1.2870999574661255,
>> "peak_util_pm": 1.8909000158309937,
>> "avg_time_ms": 0.06909999996423721,
>> "peak_time_ms": 2.7119998931884766
>> "RxCan1[7bb]": {
>> "count_hz": 0.2240000069141388,
>> "avg_util_pm": 0.10409999638795853,
>> "peak_util_pm": 0.25859999656677246,
>> "avg_time_ms": 0.043800000101327896,
>> "peak_time_ms": 1.50600004196167
>> "RxCan1[7ea]": {
>> "count_hz": 1.0670000314712524,
>> "avg_util_pm": 0.4699000120162964,
>> "peak_util_pm": 0.7283999919891357,
>> "avg_time_ms": 0.04830000177025795,
>> "peak_time_ms": 1.5379999876022339
>> "RxCan1[7ec]": {
>> "count_hz": 1.8669999837875366,
>> "avg_util_pm": 0.8090000152587891,
>> "peak_util_pm": 0.9458000063896179,
>> "avg_time_ms": 0.04639999940991402,
>> "peak_time_ms": 2.2769999504089355
>> "TxCan1[770]": {
>> "count_hz": 0.9240000247955322,
>> "avg_util_pm": 0.039400000125169754,
>> "peak_util_pm": 0.054499998688697815,
>> "avg_time_ms": 0.0038999998942017555,
>> "peak_time_ms": 0.08699999749660492
>> "TxCan1[7b3]": {
>> "count_hz": 0.041999999433755875,
>> "avg_util_pm": 0.0035000001080334187,
>> "peak_util_pm": 0.008299999870359898,
>> "avg_time_ms": 0.008500000461935997,
>> "peak_time_ms": 0.09200000017881393
>> "TxCan1[7e2]": {
>> "count_hz": 0.21199999749660492,
>> "avg_util_pm": 0.01600000075995922,
>> "peak_util_pm": 0.020500000566244125,
>> "avg_time_ms": 0.006800000090152025,
>> "peak_time_ms": 0.08500000089406967
>> "TxCan1[7e4]": {
>> "avg_util_pm": 0.006899999920278788,
>> "peak_util_pm": 0.009800000116229057,
>> "avg_time_ms": 0.002899999963119626,
>> "peak_time_ms": 0.05299999937415123
>> "Cmd:Thrtl": {
>> "count_hz": 0.014999999664723873,
>> "avg_util_pm": 0.0006000000284984708,
>> "peak_util_pm": 0,
>> "avg_time_ms": 0.004699999932199717,
>> "peak_time_ms": 0.04699999839067459
>> "Cmd:State": {
>> "count_hz": 0.039000000804662704,
>> "avg_util_pm": 0.002300000051036477,
>> "peak_util_pm": 0.007000000216066837,
>> "avg_time_ms": 0.006500000134110451,
>> "peak_time_ms": 0.09000000357627869
>> "tot_count_hz": 8.59000015258789,
>> "tot_util_pm": 3.488300085067749,
>> "tot_time_ms": 3.1019999980926514
>> On Wed, 3 Jul 2024 at 14:31, Michael Geddes <frog at bunyip.wheelycreek.net>
>> wrote:
>>> OH, and also,
>>> What do you think of treating the OvmsPoller.Times.GetStatus() items as
>>> an associative array - or should I treat it as a normal array?
>>> //.ichael
>>> On Wed, 3 Jul 2024 at 14:24, Michael Geddes <frog at bunyip.wheelycreek.net>
>>> wrote:
>>>> I figured I may as well add an OvmsPoller object to DukTape for Ovms.
>>>> I'm waiting to get back to my OVMS so that I can test it.. but this is the
>>>> documentation I have for the stuff I have coded. Thoughts on this?
>>>> What do people think of OvmsPoller.Times sub-object? I've added a
>>>> general mechanism for this.
>>>> Also should I have OvmsPoller.Pause() or
>>>> OvmsPoller.SetUserPaused(true) ?
>>>> OvmsPoller
>>>> The Ovms Poller object represents the poller sub-system. It contains
>>>> the following methods:
>>>> - ``ispaused = OvmsPoller.GetPaused()``: Return true if the poller is
>>>> paused by the system/user.
>>>> - ``ispaused = OvmsPoller.GetUserPaused()``: Return true if the poller
>>>> is paused by the user.
>>>> - ``OvmsPoller.Pause()``: Pause the poller (adds User poller pause)
>>>> - ``OvmsPoller.Resume()``: Remove the User poller pause.
>>>> - ``tracemode = OvmsPoller.GetTrace()``: Return the current trace mode.
>>>> - ``OvmsPoller.SetTrace(tracemode)``: Set the current trace mode.
>>>> The Traces still require that 'Verbose' and 'Debug' levels
>>>> (depending) for the 'vehicle-poll'
>>>> debug tag are set.
>>>> Trace modes for verbose logging can be one of:
>>>> - ``on``: On for poller loop
>>>> - ``txrx``: On for txrx queue (this can be hazardous for some cars)
>>>> - ``all``: On for both poller loop and txrx queuing
>>>> - ``off``: Logging Off
>>>> Note that only ``on`` and ``off`` are recommended.
>>>> The poller object also contains a ``Times`` property for the OBD
>>>> Poll-Time tracing
>>>> which contains the following methods:
>>>> - ``isrunning = OvmsPoller.Times.GetEnabled()``: Returns true if the
>>>> time-tracing is enabled
>>>> - ``OvmsPoller.Times.SetEnabled(isrunning)``: Sets the enabled status
>>>> of the timer-tracing
>>>> - ``OvmsPoller.Times.Reset()``: Reset the timers (doesn't affect their
>>>> current state).
>>>> - ``OvmsPoller.Times.GetStatus()``: Gets the status of the various
>>>> times. This returns an object
>>>> of this format:
>>>> .. code-block:: javascript
>>>> return_value = {
>>>> "items": {
>>>> "Poll:PRI" : {
>>>> "count_hz": 1,
>>>> "avg_util_pm": 0.529,
>>>> "peak_util_pm":0.652,
>>>> "avg_time_ms": 0.052,
>>>> "peak_time_ms":1.516
>>>> "Poll:SRX": {
>>>> "count_hz": 1.47,
>>>> "avg_util_pm": 0.302,
>>>> "peak_util_pm":0.44,
>>>> "avg_time_ms": 0.02,
>>>> "peak_time_ms":0.573
>>>> "RxCan1[778]": {
>>>> "count_hz": 0.74,
>>>> "avg_util_pm": 0.427,
>>>> "peak_util_pm":0.826,
>>>> "avg_time_ms": 0.063,
>>>> "peak_time_ms":1.872
>>>> "RxCan1[7a8]": {
>>>> "count_hz": 0.35,
>>>> "avg_util_pm": 0.183,
>>>> "peak_util_pm":0.355,
>>>> "peak_time_ms":1.382
>>>> "TxCan1[7b3]": {
>>>> "count_hz": 0.07,
>>>> "avg_util_pm": 0.005,
>>>> "peak_util_pm":0.01,
>>>> "avg_time_ms": 0.007,
>>>> "peak_time_ms":0.099
>>>> "TxCan1[7c6]": {
>>>> "count_hz": 0,
>>>> "avg_util_pm": 0,
>>>> "peak_util_pm":0.009,
>>>> "avg_time_ms": 0.004,
>>>> "peak_time_ms":0.098
>>>> "Cmd:State": {
>>>> "count_hz": 0,
>>>> "avg_util_pm": 0,
>>>> "peak_util_pm":0,
>>>> "avg_time_ms": 0.011,
>>>> "peak_time_ms":0.109
>>>> "tot_count_hz": 11.76,
>>>> "tot_util_pm": 6.247,
>>>> "tot_time_ms": 4.628
>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240707/66a2b2f5/attachment-0001.htm>
