[Ovmsdev] Adding Pollers object to Duktape
Sat Jul 6 14:54:10 HKT 2024
Michael,
looks good to me.
IMO API calls representing direct shell commands should not be
represented as getters/setters in the JS API, so ".Pause()" &
".Resume()" are better. They are also more readable (e.g. "Resume()" vs
"SetUserPaused(false)") and leave room for future command specific
arguments.
Using an object structure is OK for the times, unless you want/need to
make sure the same order as with the other outputs (shell/data) will be
kept stable on any object transformation or transfer. Object properties
(if they are strings) are normally kept in insertion order, but only
within Javascript. When deserializing JS objects into other
environments, the order isn't guaranteed.
Am 06.07.24 um 03:12 schrieb Michael Geddes via OvmsDev:
> please have a good look at the function names.. when I have Get and
> Set prefixes.. should I have them.. etc to be consistent.
> But  Just FYI (a couple of silly bugs later) - This is the full output
> from a test proving that both the 'Times' property works and that at
> least as a concept- having the "Poll:PRI" as a key works.
> ----8<-------------------
> JSON.print(OvmsPoller.Times.GetStatus())
>   "items": {
>     "Poll:PRI": {
>       "count_hz": 1.00600004196167,
>       "avg_util_pm": 0.5598000288009644,
>       "peak_util_pm": 0.6503999829292297,
>       "avg_time_ms": 0.05350000038743019,
>       "peak_time_ms": 0.9779999852180481
>     "Poll:SRX": {
>       "count_hz": 1.1330000162124634,
>       "avg_util_pm": 0.18970000743865967,
>       "peak_util_pm": 0.23240000009536743,
>       "avg_time_ms": 0.015799999237060547,
>       "peak_time_ms": 0.3319999873638153
>     "RxCan1[778]": {
>       "count_hz": 1.8489999771118164,
>       "avg_util_pm": 1.2870999574661255,
>       "peak_util_pm": 1.8909000158309937,
>       "avg_time_ms": 0.06909999996423721,
>       "peak_time_ms": 2.7119998931884766
>     "RxCan1[7bb]": {
>       "count_hz": 0.2240000069141388,
>       "avg_util_pm": 0.10409999638795853,
>       "peak_util_pm": 0.25859999656677246,
>       "avg_time_ms": 0.043800000101327896,
>       "peak_time_ms": 1.50600004196167
>     "RxCan1[7ea]": {
>       "count_hz": 1.0670000314712524,
>       "avg_util_pm": 0.4699000120162964,
>       "peak_util_pm": 0.7283999919891357,
>       "avg_time_ms": 0.04830000177025795,
>       "peak_time_ms": 1.5379999876022339
>     "RxCan1[7ec]": {
>       "count_hz": 1.8669999837875366,
>       "avg_util_pm": 0.8090000152587891,
>       "peak_util_pm": 0.9458000063896179,
>       "avg_time_ms": 0.04639999940991402,
>       "peak_time_ms": 2.2769999504089355
>     "TxCan1[770]": {
>       "count_hz": 0.9240000247955322,
>       "avg_util_pm": 0.039400000125169754,
>       "peak_util_pm": 0.054499998688697815,
>       "avg_time_ms": 0.0038999998942017555,
>       "peak_time_ms": 0.08699999749660492
>     "TxCan1[7b3]": {
>       "count_hz": 0.041999999433755875,
>       "avg_util_pm": 0.0035000001080334187,
>       "peak_util_pm": 0.008299999870359898,
>       "avg_time_ms": 0.008500000461935997,
>       "peak_time_ms": 0.09200000017881393
>     "TxCan1[7e2]": {
>       "count_hz": 0.21199999749660492,
>       "avg_util_pm": 0.01600000075995922,
>       "peak_util_pm": 0.020500000566244125,
>       "avg_time_ms": 0.006800000090152025,
>       "peak_time_ms": 0.08500000089406967
>     "TxCan1[7e4]": {
>       "avg_util_pm": 0.006899999920278788,
>       "peak_util_pm": 0.009800000116229057,
>       "avg_time_ms": 0.002899999963119626,
>       "peak_time_ms": 0.05299999937415123
>     "Cmd:Thrtl": {
>       "count_hz": 0.014999999664723873,
>       "avg_util_pm": 0.0006000000284984708,
>       "peak_util_pm": 0,
>       "avg_time_ms": 0.004699999932199717,
>       "peak_time_ms": 0.04699999839067459
>     "Cmd:State": {
>       "count_hz": 0.039000000804662704,
>       "avg_util_pm": 0.002300000051036477,
>       "peak_util_pm": 0.007000000216066837,
>       "avg_time_ms": 0.006500000134110451,
>       "peak_time_ms": 0.09000000357627869
>   "tot_count_hz": 8.59000015258789,
>   "tot_util_pm": 3.488300085067749,
>   "tot_time_ms": 3.1019999980926514
> On Wed, 3 Jul 2024 at 14:31, Michael Geddes
> <frog at bunyip.wheelycreek.net> wrote:
>     OH, and also,
>     What do you think of treating the OvmsPoller.Times.GetStatus()
>     items as an associative array - or should I treat it as a normal
>     array?
>     //.ichael
>     On Wed, 3 Jul 2024 at 14:24, Michael Geddes
>         I figured I may as well add an OvmsPoller object to DukTape
>         for Ovms.   I'm waiting to get back to my OVMS so that I can
>         test it.. but this is the documentation I have for the stuff I
>         have coded. Thoughts on this?
>         What do people think of OvmsPoller.Times sub-object?   I've
>         added a general mechanism for this.
>         Also should I have OvmsPoller.Pause()  or
>         OvmsPoller.SetUserPaused(true)  ?
>         OvmsPoller
>         The Ovms Poller object represents the poller sub-system. It
>         contains the following methods:
>         - ``ispaused = OvmsPoller.GetPaused()``: Return true if the
>         poller is paused by the system/user.
>         - ``ispaused = OvmsPoller.GetUserPaused()``: Return true if
>         the poller is paused by the user.
>         - ``OvmsPoller.Pause()``: Pause the poller (adds User poller
>         pause)
>         - ``OvmsPoller.Resume()``: Remove the User poller pause.
>         - ``tracemode = OvmsPoller.GetTrace()``: Return the current
>         trace mode.
>         - ``OvmsPoller.SetTrace(tracemode)``: Set the current trace mode.
>             The Traces still require that 'Verbose' and 'Debug' levels
>         (depending) for the 'vehicle-poll'
>             debug tag are set.
>             Trace modes for verbose logging can be one of:
>             - ``on``: On for poller loop
>             - ``txrx``: On for txrx queue (this can be hazardous for
>         some cars)
>             - ``all``: On for both poller loop and txrx queuing
>             - ``off``: Logging Off
>             Note that only ``on`` and ``off`` are recommended.
>         The poller object also contains a ``Times`` property for the
>         OBD Poll-Time tracing
>         which contains the following methods:
>         - ``isrunning = OvmsPoller.Times.GetEnabled()``: Returns true
>         if the time-tracing is enabled
>         - ``OvmsPoller.Times.SetEnabled(isrunning)``: Sets the enabled
>         status of the timer-tracing
>         - ``OvmsPoller.Times.Reset()``: Reset the timers (doesn't
>         affect their current state).
>         - ``OvmsPoller.Times.GetStatus()``: Gets the status of the
>         various times. This returns an object
>             of this format:
>             .. code-block:: javascript
>             return_value = {
>               "items": {
>                 "Poll:PRI" : {
>                   "count_hz":    1,
>                   "avg_util_pm": 0.529,
>                   "peak_util_pm":0.652,
>                   "avg_time_ms": 0.052,
>                   "peak_time_ms":1.516
>                 "Poll:SRX": {
>                   "count_hz":    1.47,
>                   "avg_util_pm": 0.302,
>                   "peak_util_pm":0.44,
>                   "avg_time_ms": 0.02,
>                   "peak_time_ms":0.573
>                 "RxCan1[778]": {
>                   "count_hz":    0.74,
>                   "avg_util_pm": 0.427,
>                   "peak_util_pm":0.826,
>                   "avg_time_ms": 0.063,
>                   "peak_time_ms":1.872
>                 "RxCan1[7a8]": {
>                   "count_hz":    0.35,
>                   "avg_util_pm": 0.183,
>                   "peak_util_pm":0.355,
>                   "peak_time_ms":1.382
>                 "TxCan1[7b3]": {
>                   "count_hz":    0.07,
>                   "avg_util_pm": 0.005,
>                   "peak_util_pm":0.01,
>                   "avg_time_ms": 0.007,
>                   "peak_time_ms":0.099
>                 "TxCan1[7c6]": {
>                   "count_hz":    0,
>                   "avg_util_pm": 0,
>                   "peak_util_pm":0.009,
>                   "avg_time_ms": 0.004,
>                   "peak_time_ms":0.098
>                 "Cmd:State": {
>                   "count_hz":    0,
>                   "avg_util_pm": 0,
>                   "peak_util_pm":0,
>                   "avg_time_ms": 0.011,
>                   "peak_time_ms":0.109
>               "tot_count_hz": 11.76,
>               "tot_util_pm": 6.247,
>               "tot_time_ms": 4.628
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240706/efaf0a2c/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240706/efaf0a2c/attachment-0001.sig>
