[Ovmsdev] Adding Pollers object to Duktape
Sat Jul 6 09:12:48 HKT 2024
please have a good look at the function names.. when I have Get and Set
prefixes.. should I have them.. etc to be consistent.
But  Just FYI (a couple of silly bugs later) - This is the full output from
a test proving that both the 'Times' property works and that at least as a
concept- having the "Poll:PRI" as a key works.
----8<-------------------
JSON.print(OvmsPoller.Times.GetStatus())
  "items": {
    "Poll:PRI": {
      "count_hz": 1.00600004196167,
      "avg_util_pm": 0.5598000288009644,
      "peak_util_pm": 0.6503999829292297,
      "avg_time_ms": 0.05350000038743019,
      "peak_time_ms": 0.9779999852180481
    "Poll:SRX": {
      "count_hz": 1.1330000162124634,
      "avg_util_pm": 0.18970000743865967,
      "peak_util_pm": 0.23240000009536743,
      "avg_time_ms": 0.015799999237060547,
      "peak_time_ms": 0.3319999873638153
    "RxCan1[778]": {
      "count_hz": 1.8489999771118164,
      "avg_util_pm": 1.2870999574661255,
      "peak_util_pm": 1.8909000158309937,
      "avg_time_ms": 0.06909999996423721,
      "peak_time_ms": 2.7119998931884766
    "RxCan1[7bb]": {
      "count_hz": 0.2240000069141388,
      "avg_util_pm": 0.10409999638795853,
      "peak_util_pm": 0.25859999656677246,
      "avg_time_ms": 0.043800000101327896,
      "peak_time_ms": 1.50600004196167
    "RxCan1[7ea]": {
      "count_hz": 1.0670000314712524,
      "avg_util_pm": 0.4699000120162964,
      "peak_util_pm": 0.7283999919891357,
      "avg_time_ms": 0.04830000177025795,
      "peak_time_ms": 1.5379999876022339
    "RxCan1[7ec]": {
      "count_hz": 1.8669999837875366,
      "avg_util_pm": 0.8090000152587891,
      "peak_util_pm": 0.9458000063896179,
      "avg_time_ms": 0.04639999940991402,
      "peak_time_ms": 2.2769999504089355
    "TxCan1[770]": {
      "count_hz": 0.9240000247955322,
      "avg_util_pm": 0.039400000125169754,
      "peak_util_pm": 0.054499998688697815,
      "avg_time_ms": 0.0038999998942017555,
      "peak_time_ms": 0.08699999749660492
    "TxCan1[7b3]": {
      "count_hz": 0.041999999433755875,
      "avg_util_pm": 0.0035000001080334187,
      "peak_util_pm": 0.008299999870359898,
      "avg_time_ms": 0.008500000461935997,
      "peak_time_ms": 0.09200000017881393
    "TxCan1[7e2]": {
      "count_hz": 0.21199999749660492,
      "avg_util_pm": 0.01600000075995922,
      "peak_util_pm": 0.020500000566244125,
      "avg_time_ms": 0.006800000090152025,
      "peak_time_ms": 0.08500000089406967
    "TxCan1[7e4]": {
      "avg_util_pm": 0.006899999920278788,
      "peak_util_pm": 0.009800000116229057,
      "avg_time_ms": 0.002899999963119626,
      "peak_time_ms": 0.05299999937415123
    "Cmd:Thrtl": {
      "count_hz": 0.014999999664723873,
      "avg_util_pm": 0.0006000000284984708,
      "peak_util_pm": 0,
      "avg_time_ms": 0.004699999932199717,
      "peak_time_ms": 0.04699999839067459
    "Cmd:State": {
      "count_hz": 0.039000000804662704,
      "avg_util_pm": 0.002300000051036477,
      "peak_util_pm": 0.007000000216066837,
      "avg_time_ms": 0.006500000134110451,
      "peak_time_ms": 0.09000000357627869
  "tot_count_hz": 8.59000015258789,
  "tot_util_pm": 3.488300085067749,
  "tot_time_ms": 3.1019999980926514
On Wed, 3 Jul 2024 at 14:31, Michael Geddes <frog at bunyip.wheelycreek.net>
wrote:
> OH, and also,
> What do you think of treating the OvmsPoller.Times.GetStatus() items as
> an associative array - or should I treat it as a normal array?
> //.ichael
> On Wed, 3 Jul 2024 at 14:24, Michael Geddes <frog at bunyip.wheelycreek.net>
> wrote:
>> I figured I may as well add an OvmsPoller object to DukTape for Ovms.
>>  I'm waiting to get back to my OVMS so that I can test it.. but this is the
>> documentation I have for the stuff I have coded. Thoughts on this?
>> What do people think of OvmsPoller.Times sub-object?   I've added a
>> general mechanism for this.
>> Also should I have OvmsPoller.Pause()  or OvmsPoller.SetUserPaused(true)
>> OvmsPoller
>> The Ovms Poller object represents the poller sub-system. It contains the
>> following methods:
>> - ``ispaused = OvmsPoller.GetPaused()``: Return true if the poller is
>> paused by the system/user.
>> - ``ispaused = OvmsPoller.GetUserPaused()``: Return true if the poller is
>> paused by the user.
>> - ``OvmsPoller.Pause()``: Pause the poller (adds User poller pause)
>> - ``OvmsPoller.Resume()``: Remove the User poller pause.
>> - ``tracemode = OvmsPoller.GetTrace()``: Return the current trace mode.
>> - ``OvmsPoller.SetTrace(tracemode)``: Set the current trace mode.
>>     The Traces still require that 'Verbose' and 'Debug' levels
>> (depending) for the 'vehicle-poll'
>>     debug tag are set.
>>     Trace modes for verbose logging can be one of:
>>     - ``on``: On for poller loop
>>     - ``txrx``: On for txrx queue (this can be hazardous for some cars)
>>     - ``all``: On for both poller loop and txrx queuing
>>     - ``off``: Logging Off
>>     Note that only ``on`` and ``off`` are recommended.
>> The poller object also contains a ``Times`` property for the OBD
>> Poll-Time tracing
>> which contains the following methods:
>> - ``isrunning = OvmsPoller.Times.GetEnabled()``: Returns true if the
>> time-tracing is enabled
>> - ``OvmsPoller.Times.SetEnabled(isrunning)``: Sets the enabled status of
>> the timer-tracing
>> - ``OvmsPoller.Times.Reset()``: Reset the timers (doesn't affect their
>> current state).
>> - ``OvmsPoller.Times.GetStatus()``: Gets the status of the various times.
>> This returns an object
>>     of this format:
>>     .. code-block:: javascript
>>     return_value = {
>>       "items": {
>>         "Poll:PRI" : {
>>           "count_hz":    1,
>>           "avg_util_pm": 0.529,
>>           "peak_util_pm":0.652,
>>           "avg_time_ms": 0.052,
>>           "peak_time_ms":1.516
>>         "Poll:SRX": {
>>           "count_hz":    1.47,
>>           "avg_util_pm": 0.302,
>>           "peak_util_pm":0.44,
>>           "avg_time_ms": 0.02,
>>           "peak_time_ms":0.573
>>         "RxCan1[778]": {
>>           "count_hz":    0.74,
>>           "avg_util_pm": 0.427,
>>           "peak_util_pm":0.826,
>>           "avg_time_ms": 0.063,
>>           "peak_time_ms":1.872
>>         "RxCan1[7a8]": {
>>           "count_hz":    0.35,
>>           "avg_util_pm": 0.183,
>>           "peak_util_pm":0.355,
>>           "peak_time_ms":1.382
>>         "TxCan1[7b3]": {
>>           "count_hz":    0.07,
>>           "avg_util_pm": 0.005,
>>           "peak_util_pm":0.01,
>>           "avg_time_ms": 0.007,
>>           "peak_time_ms":0.099
>>         "TxCan1[7c6]": {
>>           "count_hz":    0,
>>           "avg_util_pm": 0,
>>           "peak_util_pm":0.009,
>>           "avg_time_ms": 0.004,
>>           "peak_time_ms":0.098
>>         "Cmd:State": {
>>           "count_hz":    0,
>>           "avg_util_pm": 0,
>>           "peak_util_pm":0,
>>           "avg_time_ms": 0.011,
>>           "peak_time_ms":0.109
>>       "tot_count_hz": 11.76,
>>       "tot_util_pm": 6.247,
>>       "tot_time_ms": 4.628
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240706/437da74a/attachment.htm>
