[Ovmsdev] Messages stopped being received on phone
Derek Caudwell d.caudwell at gmail.com
Fri Jan 26 10:49:44 HKT 2024
Hi Michael, Greg
Fyi, it looks like my messages also stopped on the 8 Jan GMT, I'm on
Android 12 OVMS app version 4.1.2.
On Fri, 26 Jan 2024 at 14:35, <ovmsdev-request at lists.openvehicles.com>
wrote:
> Send OvmsDev mailing list submissions to
>         ovmsdev at lists.openvehicles.com
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         ovmsdev-owner at lists.openvehicles.com
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of OvmsDev digest..."
> Today's Topics:
>    1. Re: Messages stopped being received on phone (Michael Balzer)
>    2. Re: Working on ESP-IDF5 + Have a question about ovms_module
>       'Name' (Michael Geddes)
>    3. Re: Working on ESP-IDF5 + Have a question about ovms_module
>       'Name' (Mark Webb-Johnson)
> Message: 1
> Date: Thu, 25 Jan 2024 19:55:40 +0100
> From: Michael Balzer <dexter at expeedo.de>
> To: ovmsdev at lists.openvehicles.com
> Subject: Re: [Ovmsdev] Messages stopped being received on phone
> Message-ID: <93610d48-1492-4ca8-b3ff-1adee6c75ee0 at expeedo.de>
> Content-Type: text/plain; charset="utf-8"; Format="flowed"
> Greg,
> 8th of January matches our preparation steps for the Firebase messaging
> migration.
> But that to my knowledge didn't involve any change to the server yet,
> and should only have added the Firebase instance to the Google cloud
> account without disabling the old GCM.
> Also? if it was an issue of the server / Google cloud, there certainly
> would be other users affected.
> I assume you didn't install the beta test App build yet? That could be
> worth a try. The new build works with both the old & new server API.
> Google wrote the old Android APIs would continue to work until June, but
> maybe that was too optimistic?
> Am 25.01.24 um 00:22 schrieb Greg D.:
> > Hi folks,
> > I recently noticed that Alerts (Messages) have stopped coming to my
> > phone.? The last one was on 8-January '24.? The car is still operating
> > / charging normally, and has been driven since then. The Battery, Car,
> > and Location screens are up to date and live. The OVMS module is
> > connected to the home Wi-Fi, as normal, and I can access it through
> > the internal web server (dashboard, status, etc.).? But the phone
> > app's Messages page stops at 8-January.
> > I've not messed with the module in a long time.? Last boot, in fact,
> > was a crash back in July 2023, from which it recovered normally. (So
> > lovely seeing an uptime in excess of 17 million seconds.)
> > So, what happened back on 8-January?? The only thing I can think of
> > was that Android is being more aggressive about shutting down
> > background processing (in the name of increased battery life), but
> > leaving the app running in foreground and triggering an event still
> > wasn't seen on the phone.? I can see them on the Web's Dashboard, so
> > the events are being generated and processed otherwise normally.
> > The phone is a Pixel 7a, Android 14.? OVMS firmware is
> > 3.3.003/ota_1/eap (build idf v3.3.4-848-g1ff5e24b1 Sep 1 2022 08:40:30).
> > Any ideas?
> > Thanks,
> > Greg
> -------------- next part --------------
> A non-text attachment was scrubbed...
> Type: application/pgp-signature
> Desc: OpenPGP digital signature
> URL: <
> http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240125/7996b03f/attachment-0001.sig
> Message: 2
> Date: Fri, 26 Jan 2024 09:23:42 +0800
> From: Michael Geddes <frog at bunyip.wheelycreek.net>
> To: OVMS Developers <ovmsdev at lists.openvehicles.com>
> Cc: "casner at acm.org" <casner at acm.org>
> Subject: Re: [Ovmsdev] Working on ESP-IDF5 + Have a question about
>         ovms_module 'Name'
> Message-ID:
> CAH0p7u+KC5Nh1+dds4ib3srAnVzMsNP3Lg7JVdrOF1YYpopy4w at mail.gmail.com>
> Thanks Michael,
> I hadn't considered there would be an essay in the commit, thanks for that
> - though it doesn't shed a lot of light on the situation
> There seems to be 2 places that mark a Name using the high bit, and only
> one place that kinda-sorta reads it.
> The Name is 'marked' during populate() which seems to be to mark each name
> with a '*' and the high-bit, before going through and getting the current
> names for the processes - adding new ones and replacing the old ones
> without '*' and high-bit mark.  So items which are double marked are
> effectively stale/historic.
> It is also 'marked' during the find call .. which basically marks the
> 'found' name if it was not found and then constructed.  The does not appear
> to be any purpose to this that I can ascertain.
> The one place (afaict) it reads the value is in zero() below - the problem
> is that it looks at the entire top uint32 rather than just that high
> byte!!   It's hard to work out whether this is just a long-standing bug or
> whether it is weeding out names > 12 characters as well from being removed.
> So this seems to remove an item from the map, but only if it isn't marked
> (or long) ie if it isn't stale - or been 'seen' I guess?
>     bool zero(TaskHandle_t taskid)
>       for (int i = 0; i < count; ++i)
>         if (map[i].id == taskid)
> *          if (map[i].name.words[NAMELEN/4-1] > 0)*
>             return false;
>           for (++i ; i < count; ++i)
>             map[i-1] = map[i];
>           --count;
>           return true;
>       return false;
> Does this help? Any thoughts on what this was meant to do ? I've CCd
> Stephen with a hope he might chip in?
> On Wed, 24 Jan 2024 at 15:09, Michael Balzer <dexter at expeedo.de> wrote:
> > Michael,
> > Am 21.01.24 um 02:54 schrieb Michael Geddes:
> > Hey, In working trying to get ESP-IDF 5+ Working, I came across the
> > following fun thing that I'm trying to work out what is going on!!
> > This is from main/ovms_module.cpp
> > I'm not sure why we don't just go through all the words and compare - why
> > the masked compare for the last entry! And why that value?? It might make
> > sense if you masked out the final byte ... I'm just struggling to
> > understand.
> > From the further accesses to the last word/byte in TaskMap, I'd guess
> > Steve intended using the sign bit on the last byte as some special
> > indicator, but it's not clear to me for what purpose. It also doesn't
> seem
> > to be relevant anymore.
> > Steve's commit message is verbose
> > (30d0a403a380e797f9b222b01dab8da791ab388c), and maybe you can find some
> > more explanation in the list archives.
> > Regards,
> > Michael
> > Why am I looking at it?? Well there's a new warning about copy
> > constructors.. and then I ran into a problem where 'Name' is sometimes in
> > memory that can only be accessed 32bit int aligned (which is why the
> > strange implementation in the first place - I get that).
> > Can anybody shed any light on this?
> > class Name
> >    inline bool operator==(const Name& a) const
> >       for (int i = 0; i < NAMELEN/4 - 1; ++i)
> >         if (a.words[i] != words[i]) return false;
> >       i*f (a.words[NAMELEN/4-1] != (words[NAMELEN/4-1] &  0x7FFFFFFF))
> > return false;*
> >       return true;
> > OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://
> An HTML attachment was scrubbed...
> URL: <
> http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240126/5ca8f078/attachment-0001.htm
> Message: 3
> Date: Fri, 26 Jan 2024 09:34:09 +0800
>         ovms_module 'Name'
> Message-ID: <E6A7C991-83E1-40E2-9CD1-19C827EA865F at webb-johnson.net>
> Michael,
> Unfortunately, Steve passed away in 2022 so is unlikely to reply :-(
> He did work on some of the lower level and more complex parts of OVMS, as
> well as the command processing framework, and is sorely missed.
> I can?t help much with the code you are working on, other than to ask if
> this functionality is still required in the v5 IDF framework? A lot of
> stuff we did back then was to address inadequacies in the very new early
> buggy frameworks coming out of Espressif for the just released ESP-32.
> An embedded message was scrubbed...
> Subject: Passing of Steve Casner
> Date: Fri, 8 Jul 2022 08:19:25 +0800
> URL: <
> http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240126/251d3df8/attachment.eml
> > On 26 Jan 2024, at 9:23 AM, Michael Geddes <frog at bunyip.wheelycreek.net>
> Subject: Digest Footer
> End of OvmsDev Digest, Vol 144, Issue 8
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240126/bc9c2d20/attachment.htm>
