[Ovmsdev] SSL error?
Michael Stegen
michael at stegen.com
Fri Jan 5 02:02:32 HKT 2024
Thanks,
I think i found the issue, the time was set to
Time Zone: CET-1CEST,M3.5.0,M10.5.0/3
UTC Time: 2004-05-20 17:22:52 UTC
Probably due to the GPS bug the Tesla Roadster has.
Is there any way to set the date manually?
-Michael
Op 4-1-2024 om 14:33 schreef Michael Balzer:
> I can't reproduce this from here & now, the connection works. Also,
> the certificate is valid:
> - Certificate[0] info:
> - subject `CN=*.openvehicles.com', issuer `CN=GoGetSSL RSA DV
> CA,O=GoGetSSL,L=Riga,C=LV', serial
> 0x00f7ab603c192ea805072f3355cb3c1db5, RSA key 2048 bits, signed using
> RSA-SHA256, activated `2023-01-26 00:00:00 UTC', expires `2024-02-12
> 23:59:59 UTC', pin-sha256="DKzmnK01VCoa+IG6Q40dsA2dDe1lWzJeX0P1ma36Pu8="
> Possibly just a temporary glitch.
> Am 04.01.24 um 14:14 schrieb Michael Stegen:
>> With TLS enabled, the ovms v3 module can not connect to the
>> openvehicles.com server anymore.
>> When i disable TLS from the Server v2 configuration tab, the module
>> successfully connects..
>> firmware is 3.3.003
>> Am i doing something wrong or is there a certificate issue?
>> I (4103952) ovms-server-v2: Connection is api.openvehicles.com:6870
>> I (4103952) ovms-server-v2: Status: Connecting...
>> I (4103982) webserver: HTTP GET /shell
>> I (4104062) webserver: HTTP POST /api/execute
>> I (4104072) webcommand: HttpCommandStream[0x3f8bfaf8]: 3484084 bytes
>> free, executing: server v2 status
>> E (4105182) mongoose: mg_ssl_if_mbed_err 0x3f8c3f54 SSL error: -9984
>> W (4105182) ovms-server-v2: Connection failed
>> E (4105192) ovms-server-v2: Status: Error: Connection failed
>> E (4107502) mongoose: mg_ssl_if_mbed_err 0x3f8c3f54 SSL error: -29312
>> W (4107502) ovms-server-v2: Connection failed
>> E (4107502) ovms-server-v2: Status: Error: Connection failed
>> I (4107512) ovms-server-v2: Status: Disconnected
>> I (4151302) webserver: HTTP GET /cfg/server/v2
>> I (4157072) webserver: HTTP POST /cfg/server/v2
>> I (4162122) webserver: HTTP GET /shell
>> I (4166952) ovms-server-v2: Connection is api.openvehicles.com:6867
>> I (4166952) ovms-server-v2: Status: Connecting...
>> I (4167202) ovms-server-v2: Connection successful
>> I (4167202) ovms-server-v2: Status: Logging in...
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240104/c2810e06/attachment-0001.htm>
