[Ovmsdev] SSL error?
Thu Jan 4 21:33:13 HKT 2024
I can't reproduce this from here & now, the connection works. Also, the
certificate is valid:
- Certificate[0] info:
  - subject `CN=*.openvehicles.com', issuer `CN=GoGetSSL RSA DV
CA,O=GoGetSSL,L=Riga,C=LV', serial 0x00f7ab603c192ea805072f3355cb3c1db5,
RSA key 2048 bits, signed using RSA-SHA256, activated `2023-01-26
00:00:00 UTC', expires `2024-02-12 23:59:59 UTC',
pin-sha256="DKzmnK01VCoa+IG6Q40dsA2dDe1lWzJeX0P1ma36Pu8="
Possibly just a temporary glitch.
Am 04.01.24 um 14:14 schrieb Michael Stegen:
> With TLS enabled, the ovms v3 module can not connect to the
> openvehicles.com server anymore.
> When i disable TLS from the Server v2 configuration tab, the module
> successfully connects..
> firmware is 3.3.003
> Am i doing something wrong or is there a certificate issue?
> I (4103952) ovms-server-v2: Connection is api.openvehicles.com:6870
> I (4103952) ovms-server-v2: Status: Connecting...
> I (4103982) webserver: HTTP GET /shell
> I (4104062) webserver: HTTP POST /api/execute
> I (4104072) webcommand: HttpCommandStream[0x3f8bfaf8]: 3484084 bytes
> free, executing: server v2 status
> E (4105182) mongoose: mg_ssl_if_mbed_err 0x3f8c3f54 SSL error: -9984
> W (4105182) ovms-server-v2: Connection failed
> E (4105192) ovms-server-v2: Status: Error: Connection failed
> E (4107502) mongoose: mg_ssl_if_mbed_err 0x3f8c3f54 SSL error: -29312
> W (4107502) ovms-server-v2: Connection failed
> E (4107502) ovms-server-v2: Status: Error: Connection failed
> I (4107512) ovms-server-v2: Status: Disconnected
> I (4151302) webserver: HTTP GET /cfg/server/v2
> I (4157072) webserver: HTTP POST /cfg/server/v2
> I (4162122) webserver: HTTP GET /shell
> I (4166952) ovms-server-v2: Connection is api.openvehicles.com:6867
> I (4166952) ovms-server-v2: Status: Connecting...
> I (4167202) ovms-server-v2: Connection successful
> I (4167202) ovms-server-v2: Status: Logging in...
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240104/1b389cda/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240104/1b389cda/attachment.sig>
