[Ovmsdev] SSL error?
Michael Stegen michael at stegen.com
Thu Jan 4 21:14:35 HKT 2024
With TLS enabled, the ovms v3 module can not connect to the
openvehicles.com server anymore.
When i disable TLS from the Server v2 configuration tab, the module
successfully connects..
firmware is 3.3.003
Am i doing something wrong or is there a certificate issue?
I (4103952) ovms-server-v2: Connection is api.openvehicles.com:6870
I (4103952) ovms-server-v2: Status: Connecting...
I (4103982) webserver: HTTP GET /shell
I (4104062) webserver: HTTP POST /api/execute
I (4104072) webcommand: HttpCommandStream[0x3f8bfaf8]: 3484084 bytes
free, executing: server v2 status
E (4105182) mongoose: mg_ssl_if_mbed_err 0x3f8c3f54 SSL error: -9984
W (4105182) ovms-server-v2: Connection failed
E (4105192) ovms-server-v2: Status: Error: Connection failed
E (4107502) mongoose: mg_ssl_if_mbed_err 0x3f8c3f54 SSL error: -29312
W (4107502) ovms-server-v2: Connection failed
E (4107502) ovms-server-v2: Status: Error: Connection failed
I (4107512) ovms-server-v2: Status: Disconnected
I (4151302) webserver: HTTP GET /cfg/server/v2
I (4157072) webserver: HTTP POST /cfg/server/v2
I (4162122) webserver: HTTP GET /shell
I (4166952) ovms-server-v2: Connection is api.openvehicles.com:6867
I (4166952) ovms-server-v2: Status: Connecting...
I (4167202) ovms-server-v2: Connection successful
I (4167202) ovms-server-v2: Status: Logging in...
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240104/d0eff583/attachment.htm>
