[Ovmsdev] SSL error?
Charles B Cangialose chip at cangmag.com
Fri Jan 5 05:01:48 HKT 2024
With a fairly simple cable (if you’re handy with a soldering iron, you can make it yourself), and a MS-Windows computer (you can download the update software from Garmin), you can update the firmware in the Garmin GPS (in the Roadster) and it will fix the date issue.  The cable is also available on loan from members of the Tesla Motor Club.  See the following thread in the Tesla Motor Club Roadster forum:
https://teslamotorsclub.com/tmc/threads/caution-annual-service-car-power-down-gps-issue.163328/page-10 <https://teslamotorsclub.com/tmc/threads/caution-annual-service-car-power-down-gps-issue.163328/page-10>
Chip
> On Jan 4, 2024, at 10:02 AM, Michael Stegen <michael at stegen.com> wrote:
> Thanks,
> I think i found the issue, the time was set to
> Time Zone:  CET-1CEST,M3.5.0,M10.5.0/3
> UTC Time:   2004-05-20 17:22:52 UTC
> Probably due to the GPS bug the Tesla Roadster has.
> Is there any way to set the date manually?
> -Michael
> Op 4-1-2024 om 14:33 schreef Michael Balzer:
>> I can't reproduce this from here & now, the connection works. Also, the certificate is valid:
>> - Certificate[0] info:
>>  - subject `CN=*.openvehicles.com', issuer `CN=GoGetSSL RSA DV CA,O=GoGetSSL,L=Riga,C=LV', serial 0x00f7ab603c192ea805072f3355cb3c1db5, RSA key 2048 bits, signed using RSA-SHA256, activated `2023-01-26 00:00:00 UTC', expires `2024-02-12 23:59:59 UTC', pin-sha256="DKzmnK01VCoa+IG6Q40dsA2dDe1lWzJeX0P1ma36Pu8="
>> Possibly just a temporary glitch.
>> Am 04.01.24 um 14:14 schrieb Michael Stegen:
>>> With TLS enabled, the ovms v3 module can not connect to the openvehicles.com server anymore.
>>> When i disable TLS from the Server v2 configuration tab, the module successfully connects..
>>> firmware is 3.3.003
>>> Am i doing something wrong or is there a certificate issue?
>>> I (4103952) ovms-server-v2: Connection is api.openvehicles.com:6870
>>> I (4103952) ovms-server-v2: Status: Connecting...
>>> I (4103982) webserver: HTTP GET /shell
>>> I (4104062) webserver: HTTP POST /api/execute
>>> I (4104072) webcommand: HttpCommandStream[0x3f8bfaf8]: 3484084 bytes free, executing: server v2 status
>>> E (4105182) mongoose: mg_ssl_if_mbed_err   0x3f8c3f54 SSL error: -9984
>>> W (4105182) ovms-server-v2: Connection failed
>>> E (4105192) ovms-server-v2: Status: Error: Connection failed
>>> E (4107502) mongoose: mg_ssl_if_mbed_err   0x3f8c3f54 SSL error: -29312
>>> W (4107502) ovms-server-v2: Connection failed
>>> E (4107502) ovms-server-v2: Status: Error: Connection failed
>>> I (4107512) ovms-server-v2: Status: Disconnected
>>> I (4151302) webserver: HTTP GET /cfg/server/v2
>>> I (4157072) webserver: HTTP POST /cfg/server/v2
>>> I (4162122) webserver: HTTP GET /shell
>>> I (4166952) ovms-server-v2: Connection is api.openvehicles.com:6867
>>> I (4166952) ovms-server-v2: Status: Connecting...
>>> I (4167202) ovms-server-v2: Connection successful
>>> I (4167202) ovms-server-v2: Status: Logging in...
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240104/c14c5496/attachment.htm>
