[Ovmsdev] Auxiliary Battery Monitor (Kia Niro EV)
Fri Feb 9 04:33:10 HKT 2024
Generally, 12V current and temperatures are reported by the vehicle, as
the module cannot measure that, only voltage.
Metrics normally only get updates while/when the car/VCUs are online.
Metrics get "stale" when not receiving updates for a while, but the
AuxBatMon plugin for simplicity doesn't check for staleness.
You're welcome to improve that. Note, you'll need to add a metrics
staleness query Duktape API call first.
The Niro/Konta adapter could also zero the current metrics when
detecting the vehicle being offline.
Am 08.02.24 um 21:03 schrieb Douglas Urner:
> My questions:
> 1. What is the source of the current value? Is it being reported by
> the vehicle? I’m puzzled by it remaining at a high constant value
> even after the charger appears to have shut down.
> 2. Similarly with the charger and environmental temperature values —
> it seems add that they are mostly constant.
> 3. If there is anyone out there with a Niro / Kona, I’d be curious to
> know what the behavior of your auxiliary battery looks like.
> Many thanks, Doug
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240208/5fe0e463/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240208/5fe0e463/attachment.sig>
