[Ovmsdev] UI redesign in Android App - Needs beta testing
Developer From Jokela
info at developerfromjokela.com
Tue Dec 31 18:50:11 HKT 2024
Seems like there was an issue with showing charging time estimations. Patched out in latest commit.
> Developer From Jokela <info at developerfromjokela.com> kirjoitti 31.12.2024 kello 11.49:
> Hmm, strange. Could you possibly get a stack trace? If it’s too hard, let’s hope I will find it in my own testing :)
> - DFJ
>> Michael Geddes <frog at bunyip.wheelycreek.net> kirjoitti 31.12.2024 kello 4.35:
>> Font size looks all fixed, thanks.
>> For some reason when I click on the widget it opens the old look ovms still... is the old look still hidden somewhere?
>> Also if I start charging my car (not through the app), then whenever I switch to or open the app, the app crashes.
>> I'm just doing ac charging from a wallbox.
>> //.ichael.
>> On Tue, 31 Dec 2024, 06:48 Developer From Jokela via OvmsDev, <ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com>> wrote:
>>> Hi.
>>> New update is released at https://github.com/openvehicles/Open-Vehicle-Android/tree/test-dfj-ui/latest.
>>> Brief:
>>> - Quick actions customisable
>>> - Twizy UI fixes
>>> - Font size related issues should be gone (hopefully ;D)
>>> - DFJ
>>>> van der Meijden, Chris <chris at arachnon.de <mailto:chris at arachnon.de>> kirjoitti 30.12.2024 kello 13.12:
>>>> I like the design of the Mercedes Ne app. Don't need a one to one copy, but it has a good mixture between info and links, I think.
>>>> Am 30. Dezember 2024 11:29:37 MEZ schrieb Developer From Jokela <info at developerfromjokela.com <mailto:info at developerfromjokela.com>>:
>>>>> Hi.
>>>>> What info would you like to be shown on main screen?
>>>>>> On 30. Dec 2024, at 11.16, Chris van der Meijden <chris at arachnon.de <mailto:chris at arachnon.de>> wrote:
>>>>>> Also many thanks for the effort. The new design is not my cup of tea, but that is question of personal liking I suppose. For me the menu is far to present, whereas the information of the vehicle seems barely visible.
>>>>>> For the e-Up the climate control throws an error. "Fehler bei der Kommandoausführung".
>>>>>> Kind regards
>>>>>> Chris
>>>>>> Am Montag, dem 30.12.2024 um 15:20 +0800 schrieb Michael Geddes via OvmsDev:
>>>>>>> Thanks for the update. In general I like the new design.
>>>>>>> I've attached a screen shot. The list box items need to resize for larger fonts to stop them being all cut off.
>>>>>>> Also where does the "Unknown Vehicle model" come from?
>>>>>>> <1000012000.jpg>
>>>>>>> I have a slightly larger font setting:
>>>>>>> <1000012001.jpg>
>>>>>>> Also here:
>>>>>>> <1000012002.jpg>
>>>>>>> ..where the labels are overlapping due to the font size.
>>>>>>> And the ... here:
>>>>>>> <1000012003.jpg>
>>>>>>> I'm also getting a crash when opening the settings on the map. (App disappears. First time it prompted to clear cache which I did)
>>>>>>> Is there a new widget? If I click on the widget I see the old UI.
>>>>>>> //.ichael
>>>>>>> On Mon, 30 Dec 2024, 07:28 Developer From Jokela via OvmsDev, <ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com>> wrote:
>>>>>>>> Hi Android users.
>>>>>>>> I’ve recently redesigned UI for Android and it would need some testing.
>>>>>>>> Here is the latest build available for UI redesign: https://github.com/openvehicles/Open-Vehicle-Android/tree/test-dfj-ui/latest
>>>>>>>> Please report any issues, improvement suggestions, etc.
>>>>>>>> Thank you!
>>>>>>>> Br, DFJ
>>>>>>>> OvmsDev mailing list
>>>>>>>> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>> <Screenshot_20241230-115518_Mercedes-Benz_1.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241231/7dd3e136/attachment-0001.htm>
