[Ovmsdev] UI redesign in Android App - Needs beta testing
Developer From Jokela info at developerfromjokela.com
Tue Dec 31 17:49:00 HKT 2024
Hmm, strange. Could you possibly get a stack trace? If it’s too hard, let’s hope I will find it in my own testing :)
- DFJ
> Michael Geddes <frog at bunyip.wheelycreek.net> kirjoitti 31.12.2024 kello 4.35:
> Font size looks all fixed, thanks.
> For some reason when I click on the widget it opens the old look ovms still... is the old look still hidden somewhere?
> Also if I start charging my car (not through the app),  then whenever I switch to or open the app, the app crashes.
> I'm just doing ac charging from a wallbox.
> //.ichael.
> On Tue, 31 Dec 2024, 06:48 Developer From Jokela via OvmsDev, <ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com>> wrote:
>> Hi.
>> New update is released at https://github.com/openvehicles/Open-Vehicle-Android/tree/test-dfj-ui/latest.
>> Brief:
>> - Quick actions customisable
>> - Twizy UI fixes
>> - Font size related issues should be gone (hopefully ;D)
>> - DFJ
>>> van der Meijden, Chris <chris at arachnon.de <mailto:chris at arachnon.de>> kirjoitti 30.12.2024 kello 13.12:
>>> I like the design of the Mercedes Ne app. Don't need a one to one copy, but it has a good mixture between info and links, I think.
>>> Am 30. Dezember 2024 11:29:37 MEZ schrieb Developer From Jokela <info at developerfromjokela.com <mailto:info at developerfromjokela.com>>:
>>>> Hi.
>>>> What info would you like to be shown on main screen?
>>>>> On 30. Dec 2024, at 11.16, Chris van der Meijden <chris at arachnon.de <mailto:chris at arachnon.de>> wrote:
>>>>> Also many thanks for the effort. The new design is not my cup of tea, but that is question of personal liking I suppose. For me the menu is far to present, whereas the information of the vehicle seems barely visible.
>>>>> For the e-Up the climate control throws an error. "Fehler bei der Kommandoausführung".
>>>>> Kind regards
>>>>> Chris
>>>>> Am Montag, dem 30.12.2024 um 15:20 +0800 schrieb Michael Geddes via OvmsDev:
>>>>>> Thanks for the update. In general I like the new design.
>>>>>> I've attached a screen  shot.  The list box items need to resize for larger fonts to stop them being all cut off.
>>>>>> Also where does the "Unknown Vehicle model" come from?
>>>>>> <1000012000.jpg>
>>>>>> I have a slightly larger font setting:
>>>>>> <1000012001.jpg>
>>>>>> Also here:
>>>>>> <1000012002.jpg>
>>>>>> ..where the labels are overlapping due to the font size.
>>>>>> And the ... here:
>>>>>> <1000012003.jpg>
>>>>>> I'm also getting a crash when opening the settings on the map. (App disappears. First time it prompted to clear cache which I did)
>>>>>> Is there a new widget?  If I click on the widget I see the old UI.
>>>>>> //.ichael
>>>>>> On Mon, 30 Dec 2024, 07:28 Developer From Jokela via OvmsDev, <ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com>> wrote:
>>>>>>> Hi Android users.
>>>>>>> I’ve recently redesigned UI for Android and it would need some testing.
>>>>>>> Here is the latest build available for UI redesign: https://github.com/openvehicles/Open-Vehicle-Android/tree/test-dfj-ui/latest
>>>>>>> Please report any issues, improvement suggestions, etc.
>>>>>>> Thank you!
>>>>>>> Br, DFJ
>>>>>>> OvmsDev mailing list
>>>>>>> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>> <Screenshot_20241230-115518_Mercedes-Benz_1.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241231/d6bfc6f4/attachment.htm>
