[Ovmsdev] UI redesign in Android App - Needs beta testing
Tue Dec 31 15:47:45 HKT 2024
Ah, thanks Chris.  Maybe you need to obey that setting when you click on
the widget then :)
On Tue, 31 Dec 2024 at 15:38, van der Meijden, Chris via OvmsDev <
> The apo crashes regardless how I open it.
> I'm running on LineageOS (based on Android 14) without Google. I don't
> give the app GPS permissions.
> @Michael: The old UI is still in the app. You can select it from the gear
> symbol under "Settings".
> Regards
> Chris
> Am 31. Dezember 2024 03:35:21 MEZ schrieb Michael Geddes via OvmsDev <
> ovmsdev at lists.openvehicles.com>:
>> Font size looks all fixed, thanks.
>> For some reason when I click on the widget it opens the old look ovms
>> still... is the old look still hidden somewhere?
>> Also if I start charging my car (not through the app),  then whenever I
>> switch to or open the app, the app crashes.
>> I'm just doing ac charging from a wallbox.
>> //.ichael.
>> On Tue, 31 Dec 2024, 06:48 Developer From Jokela via OvmsDev, <
>>> Hi.
>>> New update is released at
>>> https://github.com/openvehicles/Open-Vehicle-Android/tree/test-dfj-ui/latest
>>> Brief:
>>> - Quick actions customisable
>>> - Twizy UI fixes
>>> - Font size related issues should be gone (hopefully ;D)
>>> - DFJ
>>> van der Meijden, Chris <chris at arachnon.de> kirjoitti 30.12.2024 kello
>>> 13.12:
>>> I like the design of the Mercedes Ne app. Don't need a one to one copy,
>>> but it has a good mixture between info and links, I think.
>>> Am 30. Dezember 2024 11:29:37 MEZ schrieb Developer From Jokela <
>>> info at developerfromjokela.com>:
>>>> Hi.
>>>> What info would you like to be shown on main screen?
>>>> On 30. Dec 2024, at 11.16, Chris van der Meijden <chris at arachnon.de>
>>>> wrote:
>>>> Also many thanks for the effort. The new design is not my cup of tea,
>>>> but that is question of personal liking I suppose. For me the menu is far
>>>> to present, whereas the information of the vehicle seems barely visible.
>>>> For the e-Up the climate control throws an error. "Fehler bei der
>>>> Kommandoausführung".
>>>> Kind regards
>>>> Chris
>>>> Am Montag, dem 30.12.2024 um 15:20 +0800 schrieb Michael Geddes via
>>>> OvmsDev:
>>>> Thanks for the update. In general I like the new design.
>>>> I've attached a screen  shot.  The list box items need to resize for
>>>> larger fonts to stop them being all cut off.
>>>> Also where does the "Unknown Vehicle model" come from?
>>>> <1000012000.jpg>
>>>> I have a slightly larger font setting:
>>>> <1000012001.jpg>
>>>> Also here:
>>>> <1000012002.jpg>
>>>> ..where the labels are overlapping due to the font size.
>>>> And the ... here:
>>>> <1000012003.jpg>
>>>> I'm also getting a crash when opening the settings on the map. (App
>>>> disappears. First time it prompted to clear cache which I did)
>>>> Is there a new widget?  If I click on the widget I see the old UI.
>>>> //.ichael
>>>> On Mon, 30 Dec 2024, 07:28 Developer From Jokela via OvmsDev, <
>>>> Hi Android users.
>>>> I’ve recently redesigned UI for Android and it would need some testing.
>>>> Here is the latest build available for UI redesign:
>>>> Please report any issues, improvement suggestions, etc.
>>>> Thank you!
>>>> Br, DFJ
>>>> OvmsDev mailing list
>>>> <Screenshot_20241230-115518_Mercedes-Benz_1.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241231/7ef311e7/attachment-0001.htm>
