[Ovmsdev] UI redesign in Android App - Needs beta testing
van der Meijden, Chris
chris at arachnon.de
Tue Dec 31 15:38:39 HKT 2024
The apo crashes regardless how I open it.
I'm running on LineageOS (based on Android 14) without Google. I don't give the app GPS permissions.
@Michael: The old UI is still in the app. You can select it from the gear symbol under "Settings".
Regards
Chris
Am 31. Dezember 2024 03:35:21 MEZ schrieb Michael Geddes via OvmsDev <ovmsdev at lists.openvehicles.com>:
>Font size looks all fixed, thanks.
>For some reason when I click on the widget it opens the old look ovms
>still... is the old look still hidden somewhere?
>Also if I start charging my car (not through the app), then whenever I
>switch to or open the app, the app crashes.
>I'm just doing ac charging from a wallbox.
>//.ichael.
>On Tue, 31 Dec 2024, 06:48 Developer From Jokela via OvmsDev, <
>ovmsdev at lists.openvehicles.com> wrote:
>> Hi.
>> New update is released at
>> https://github.com/openvehicles/Open-Vehicle-Android/tree/test-dfj-ui/latest
>> Brief:
>> - Quick actions customisable
>> - Twizy UI fixes
>> - Font size related issues should be gone (hopefully ;D)
>> - DFJ
>> van der Meijden, Chris <chris at arachnon.de> kirjoitti 30.12.2024 kello
>> 13.12:
>> I like the design of the Mercedes Ne app. Don't need a one to one copy,
>> but it has a good mixture between info and links, I think.
>> Am 30. Dezember 2024 11:29:37 MEZ schrieb Developer From Jokela <
>> info at developerfromjokela.com>:
>>> Hi.
>>> What info would you like to be shown on main screen?
>>> On 30. Dec 2024, at 11.16, Chris van der Meijden <chris at arachnon.de>
>>> wrote:
>>> Also many thanks for the effort. The new design is not my cup of tea, but
>>> that is question of personal liking I suppose. For me the menu is far to
>>> present, whereas the information of the vehicle seems barely visible.
>>> For the e-Up the climate control throws an error. "Fehler bei der
>>> Kommandoausführung".
>>> Kind regards
>>> Chris
>>> Am Montag, dem 30.12.2024 um 15:20 +0800 schrieb Michael Geddes via
>>> OvmsDev:
>>> Thanks for the update. In general I like the new design.
>>> I've attached a screen shot. The list box items need to resize for
>>> larger fonts to stop them being all cut off.
>>> Also where does the "Unknown Vehicle model" come from?
>>> <1000012000.jpg>
>>> I have a slightly larger font setting:
>>> <1000012001.jpg>
>>> Also here:
>>> <1000012002.jpg>
>>> ..where the labels are overlapping due to the font size.
>>> And the ... here:
>>> <1000012003.jpg>
>>> I'm also getting a crash when opening the settings on the map. (App
>>> disappears. First time it prompted to clear cache which I did)
>>> Is there a new widget? If I click on the widget I see the old UI.
>>> //.ichael
>>> On Mon, 30 Dec 2024, 07:28 Developer From Jokela via OvmsDev, <
>>> Hi Android users.
>>> I’ve recently redesigned UI for Android and it would need some testing.
>>> Here is the latest build available for UI redesign:
>>> Please report any issues, improvement suggestions, etc.
>>> Thank you!
>>> Br, DFJ
>>> <Screenshot_20241230-115518_Mercedes-Benz_1.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241231/0f6863db/attachment.htm>
