[Ovmsdev] UI redesign in Android App - Needs beta testing
Tue Dec 31 19:13:07 HKT 2024
That makes sense.  It's was fine at topping off level.
Also this is a bit of a weird error here:
Ir might be no data?
On Tue, 31 Dec 2024, 18:50 Developer From Jokela via OvmsDev, <
> Seems like there was an issue with showing charging time estimations.
> Patched out in latest commit.
> Developer From Jokela <info at developerfromjokela.com> kirjoitti 31.12.2024
> kello 11.49:
> Hmm, strange. Could you possibly get a stack trace? If it’s too hard,
> let’s hope I will find it in my own testing :)
> - DFJ
> Michael Geddes <frog at bunyip.wheelycreek.net> kirjoitti 31.12.2024 kello
> 4.35:
> Font size looks all fixed, thanks.
> For some reason when I click on the widget it opens the old look ovms
> still... is the old look still hidden somewhere?
> Also if I start charging my car (not through the app),  then whenever I
> switch to or open the app, the app crashes.
> I'm just doing ac charging from a wallbox.
> //.ichael.
> On Tue, 31 Dec 2024, 06:48 Developer From Jokela via OvmsDev, <
>> Hi.
>> New update is released at
>> https://github.com/openvehicles/Open-Vehicle-Android/tree/test-dfj-ui/latest
>> Brief:
>> - Quick actions customisable
>> - Twizy UI fixes
>> - Font size related issues should be gone (hopefully ;D)
>> - DFJ
>> van der Meijden, Chris <chris at arachnon.de> kirjoitti 30.12.2024 kello
>> 13.12:
>> I like the design of the Mercedes Ne app. Don't need a one to one copy,
>> but it has a good mixture between info and links, I think.
>> Am 30. Dezember 2024 11:29:37 MEZ schrieb Developer From Jokela <
>> info at developerfromjokela.com>:
>>> Hi.
>>> What info would you like to be shown on main screen?
>>> On 30. Dec 2024, at 11.16, Chris van der Meijden <chris at arachnon.de>
>>> wrote:
>>> Also many thanks for the effort. The new design is not my cup of tea,
>>> but that is question of personal liking I suppose. For me the menu is far
>>> to present, whereas the information of the vehicle seems barely visible.
>>> For the e-Up the climate control throws an error. "Fehler bei der
>>> Kommandoausführung".
>>> Kind regards
>>> Chris
>>> Am Montag, dem 30.12.2024 um 15:20 +0800 schrieb Michael Geddes via
>>> OvmsDev:
>>> Thanks for the update. In general I like the new design.
>>> I've attached a screen  shot.  The list box items need to resize for
>>> larger fonts to stop them being all cut off.
>>> Also where does the "Unknown Vehicle model" come from?
>>> <1000012000.jpg>
>>> I have a slightly larger font setting:
>>> <1000012001.jpg>
>>> Also here:
>>> <1000012002.jpg>
>>> ..where the labels are overlapping due to the font size.
>>> And the ... here:
>>> <1000012003.jpg>
>>> I'm also getting a crash when opening the settings on the map. (App
>>> disappears. First time it prompted to clear cache which I did)
>>> Is there a new widget?  If I click on the widget I see the old UI.
>>> //.ichael
>>> On Mon, 30 Dec 2024, 07:28 Developer From Jokela via OvmsDev, <
>>> Hi Android users.
>>> I’ve recently redesigned UI for Android and it would need some testing.
>>> Here is the latest build available for UI redesign:
>>> Please report any issues, improvement suggestions, etc.
>>> Thank you!
>>> Br, DFJ
>>> <Screenshot_20241230-115518_Mercedes-Benz_1.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241231/fd774416/attachment-0001.htm>
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20241231/fd774416/attachment-0001.jpg>
