Michael Geddes
Tue Apr 30 14:55:50 HKT 2024
No it will start the poll thread of the poller fine for those that don't
use it. That's the last commit.... so that should be covered. When the
callback is registered the thread is force started.
This is not to say that what you are suggesting isn't a better way
forward... just that it should work.
On Tue, 30 Apr 2024, 14:51 Michael Balzer via OvmsDev, <
> Michael,
> (taking this back to the list, as other developers may have helpful ideas
> or suggestions)
> from a first check, your new patch (PR #1008) won't help for vehicles that
> don't use the poller, like the generic DBC vehicle or the Fiat 500 (plus
> possibly non-public third party vehicles). As the poller is normally
> compiled in, these would need a run time switch to re-enable the vehicle
> task, or more suitably default into that configuration and switch to the
> poller task only when the poller gets initialized.
> How about moving the task back into the vehicle class, but keeping your
> task message extensions while doing so, and adding a way for the poller to
> hook into the task? The dedicated vehicle task is an essential part of the
> vehicle framework, but I do remember some occasions where a general way to
> pass custom messages to the vehicle task would have been helpful to use the
> task for more than CAN processing.
> If the poller shall become avaible as a separate service that can be used
> without any vehicle instance (currently not a defined use case), the
> construct of a CAN processor task that can be extended for custom messages
> (or a message processor task that can subscribe to CAN frames) could be
> factored out into a dedicated class or template. The poller could then
> create his own instance of that class, if it cannot hook into an existing
> one.
> Btw, in case you're not aware of this, FreeRTOS also provides queue sets (
> https://www.freertos.org/RTOS-queue-sets.html). We haven't used them in
> the OVMS yet, but they could be useful, especially if message unions become
> large or tasks shall be able to dynamically subscribe to different message
> sources.
> Am 30.04.24 um 01:20 schrieb Michael Geddes:
> It might be worth reverting, but, I've got a patch suggestion that I'll
> push up which will let me know if I understand everything and which might
> provide a solution.
> If this isn't going to work then revert. (P/R coming)
> While the poller was still a part of the vehicle class it was probably
> still all ok. The poller had taken over what I assume you are talking
> about as the vehicle task. A call-back fromthe poller was calling
> IncomingPollRxFrame which was then coming from the (now) poller task (is
> that correct?)
> While we have OVMS_COMP_POLLER config defined, we could just use the
> poller task to provide the IncomingPollRxFrame call-back from the poller
> (was vehicle?) task.
> The problem is when OVMS_COMP_POLLER is undefined, we need an alternate
> (maybe we could use the 'Event' loop then) which is when I hacked that bad
> solution.
> //.ichael
> I was thinking though that because everything is being queued we could
> divert some calls into the car
> On Mon, 29 Apr 2024, 18:58 Michael Balzer, <dexter at expeedo.de> wrote:
>> Michael,
>> I've found a severe design flaw with your poller change. Sorry, I should
>> have seen that before, and shouldn't have merged this.
>> You have moved the standard CAN frame processing from the vehicle task
>> into the CAN task by changing the vehicle from a CAN listener to a CAN
>> callback processor. That will break all kind of things, vehicles like the
>> Twizy, Smart and many others rely on frame processing being done in the
>> dedicated vehicle task.
>> This especially induces issues regarding CAN processing capacity, as the
>> vehicles rely on having a separate context and not needing to decouple
>> complex processing of incoming frames. So this will degrade the CAN
>> processing performance seriously in many cases, where additional steps
>> involving file or network I/O need to be done.
>> So this needs to be changed back.
>> I assumed you introduced a new dedicated poller task but kept the vehicle
>> task intact. From your naming (OvmsVehicle::IncomingPollRxFrame), it seems
>> you misinterpreted the vehicle task's purpose as only being used for
>> polling.
>> I assume this isn't a small change…? If so we should revert the poller
>> merge, to avoid having a defunctional edge build state until the fix.
>> Secondly: logging is generally expensive regardless of the log level
>> control and log channels enabled. Any log message needs to be queued to the
>> log system, so involves a lock and a potential wait state (for the queue) &
>> resulting context switch (= minimum delay of 10 ms). Therefore, logging
>> must be avoided as far as possible in any time critical context, and is
>> forbidden under some circumstances, e.g. in a timer callback (see FreeRTOS
>> docs on this). The log system load multiplies with connected web clients or
>> enabled file logging and enabled debug / verbose level logging -- that
>> quickly becomes too much, usually triggering the task watchdog.
>> Your logging of nearly all bus events passing to/from the poller
>> (especially the log entry in Queue_PollerFrame) becomes an issue on any
>> vehicle that has high frequency running process data frames on the bus,
>> like the Twizy or Smart. As a counter measure, I've just added a runtime
>> control for all the poller's verbose logging (by default now off), and
>> changed some debug level logs to verbose. Not sure if I've catched all that
>> may need to be silenced by default. Please check all your log calls and
>> place them under the new "trace" control flag wherever appropriate.
>> This won't help avoiding issues with process data frame buses though.
>> Shall I revert the poller merge for now?
>> Am 29.04.24 um 06:18 schrieb Michael Geddes:
>> Btw I included the log changes in the p/r which is a few small commits
>> for the poller.
>> On Mon, 29 Apr 2024, 07:20 Michael Geddes, <frog at bunyip.wheelycreek.net>
>> wrote:
>>> Hey Michael,
>>> I've got to work now (it's Monday), but I suspect those 'giving up' are
>>> from unsolicited messages on the bus.
>>> I can re-order things so that the message will likely be 'dropped (no
>>> poll entry)' rather than the time-out message.
>>> And make it a verbose log.
>>> //.ichael
>>> On Mon, 29 Apr 2024 at 00:25, Michael Balzer <dexter at expeedo.de> wrote:
>>>> Michael,
>>>> forwarding the Twizy logs to you directly, as they contain the user
>>>> location.
>>>> He has just verified it's the new version, he says the module stops
>>>> responding as soon as he turns on the Twizy.
>>>> His description of his actions is a bit ambiguous, and it seems he
>>>> didn't enable logging to the file persistently.
>>>> According to the server, these were the version boot times:
>>>> 2024-04-28 15:30:56 0 3.3.004-32-g125e0841/ota_0/edge (build idf
>>>> v3.3.4-849-g6e214dc335 Apr 26 2024 19:16:50)
>>>> 2024-04-28 16:21:08 0 3.3.004-32-g125e0841/ota_0/edge (build idf
>>>> 2024-04-28 16:38:33 0 3.3.004-63-gf3595561/ota_1/edge (build idf
>>>> v3.3.4-849-g6e214dc335 Apr 27 2024 07:44:50)
>>>> 2024-04-28 16:40:57 0 3.3.004-63-gf3595561/ota_1/edge (build idf
>>>> 2024-04-28 16:43:14 0 3.3.004-63-gf3595561/ota_1/edge (build idf
>>>> 2024-04-28 16:46:39 0 3.3.004-63-gf3595561/ota_1/edge (build idf
>>>> 2024-04-28 16:54:44 0 3.3.004-32-g125e0841/ota_0/edge (build idf
>>>> Attached is also his crash debug log -- a2ll doesn't tell much about
>>>> what happened, but maybe you get an idea from this.
>>>> After the boot at 16:46, there are immediately lots of these messages:
>>>> 2024-04-28 16:46:33.792 CEST D (39042) vehicle-poll: Poller: Queue
>>>> PollerFrame()
>>>> 2024-04-28 16:46:33.792 CEST D (39042) vehicle-poll: [1]Poller:
>>>> Incoming - giving up
>>>> Regards,
>>>> Michael
>>>> Am 28.04.24 um 16:44 schrieb Michael Geddes:
>>>> Ah. OK.
>>>> I could try to fix the vin thing using the new way of doing it and get
>>>> rid of a semaphore?
>>>> It would at least identify the problem possibly?
>>>> Michael
>>>> On Sun, 28 Apr 2024, 22:32 Michael Balzer via OvmsDev, <
>>>>> Not sure if that's the problem, but I've found a different behaviour
>>>>> with the new PollSetState() implementation.
>>>>> The old version only did anything if the new state actually was
>>>>> different from the previous one. The Twizy relies on this behaviour,
>>>>> calling PollSetState() from the per second ticker (see
>>>>> OvmsVehicleRenaultTwizy::ObdTicker1).
>>>>> The new implementation apparently always sends the PollState command
>>>>> to the task, and that in turn always at least locks the poller mutex. Not
>>>>> sure if/how that could cause the observed issues, but it definitely adds
>>>>> quite some (unnecessary?) lock/unlock operations.
>>>>> Am 28.04.24 um 16:05 schrieb Michael Balzer via OvmsDev:
>>>>> The Twizy uses the poller to query the VIN (once) and DTCs (every 10
>>>>> seconds while driving), see rt_obd2.cpp.
>>>>> It also has its own version of the OBD single request
>>>>> (OvmsVehicleRenaultTwizy::ObdRequest), which was the precursor for the
>>>>> generalized version. This is used by custom/user Twizy plugins and scripts
>>>>> to access ECU internals.
>>>>> The Twizy doesn't use IncomingPollRxFrame, but the Twizy's
>>>>> IncomingPollReply handler will log any poll responses it doesn't know
>>>>> about, so that could lead to a lot of log output if something goes wrong
>>>>> there.
>>>>> Am 28.04.24 um 15:49 schrieb Michael Geddes via OvmsDev:
>>>>> AFAICT the twizzy doesn't use the poller list at all. So is it
>>>>> missing a call-back or something??
>>>>> I can see a potential problem with IncomingPollRxFrame being called
>>>>> twice as much as it should be but only when there is a poll list. Maybe
>>>>> commenting out this would do it. (I can find another away to get this
>>>>> called on the thread I want). This might be the problem with the smarted
>>>>> void OvmsVehicle::OvmsVehicleSignal::IncomingPollRxFrame(canbus* bus,
>>>>> CAN_frame_t *frame, bool success)
>>>>> //if (Ready())
>>>>> // m_parent->IncomingPollRxFrame(frame, success);
>>>>> On Sun, 28 Apr 2024 at 21:10, Michael Balzer via OvmsDev <
>>>>>> There may also be an issue with the Renault Twizy, I've received a
>>>>>> report of a user who is using the edge builds, that the latest build
>>>>>> wouldn't work.
>>>>>> He reports all kinds of errors and warnings signaled by the car
>>>>>> during driving, and switching back to the previous build fixed the issues.
>>>>>> I've asked him to provide a debug log excerpt if possible.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 28.04.24 um 14:29 schrieb Michael Geddes via OvmsDev:
>>>>>> OK. That's bad.
>>>>>> Does the reading work in general?
>>>>>> Is it just the writing commands?
>>>>>> Raise a ticket on github and tag me in and we can address it that way.
>>>>>> Michael
>>>>>> On Sun, 28 Apr 2024, 19:49 Thomas Heuer via OvmsDev, <
>>>>>>> Hi,
>>>>>>> The new poller code doesn't seem to work properly with the smarted.
>>>>>>> D (218831) vehicle-poll: [1]PollerNextTick(PRI): cycle complete for
>>>>>>> ticker=215
>>>>>>> V (218831) vehicle-poll: Standard Poll Series: List reset
>>>>>>> D (218831) vehicle-poll: PollSeriesList::NextPollEntry[!v.standard]:
>>>>>>> ReachedEnd
>>>>>>> V (218831) vehicle-poll: [1]PollerSend: Poller Reached End
>>>>>>> D (219691) vehicle-poll: Poller: Queue PollerFrame()
>>>>>>> V (219691) vehicle-poll: Pollers: FrameRx(bus=2)
>>>>>>> *OVMS#* unlock 22
>>>>>>> Vehicle unlocked
>>>>>>> D (219701) vehicle-poll: Poller: Queue PollerFrame()
>>>>>>> V (219701) vehicle-poll: Pollers: FrameRx(bus=2)
>>>>>>> *Von:* OvmsDev <ovmsdev-bounces at lists.openvehicles.com> *Im Auftrag
>>>>>>> von *Michael Geddes via OvmsDev
>>>>>>> *Gesendet:* Sonntag, 28. April 2024 12:27
>>>>>>> *An:* OVMS Developers <ovmsdev at lists.openvehicles.com>
>>>>>>> *Cc:* Michael Geddes <frog at bunyip.wheelycreek.net>
>>>>>>> *Betreff:* [Ovmsdev] OVMS Poller module/singleton
>>>>>>> Hey all,
>>>>>>> The poller singleton code that I've been working on for over a year
>>>>>>> now is merged in. (Thanks Michael for expediting the final step).
>>>>>>> This includes separate multi-frame states per bus and multiple poll
>>>>>>> lists as well as non-blocking one off queries. As well as more 'states'.
>>>>>>> I have included some programming documentation in the change but am
>>>>>>> happy to supply more if needed.
>>>>>>> The ioniq 5 code has some examples of how it can be used. Some
>>>>>>> examples are:
>>>>>>> * grabbing the vin as a one shot without blocking
>>>>>>> * having a short list of queries that are polled quickly for obd2ecu
>>>>>>> (this also demonstrates using a shorter frame break value and then a break
>>>>>>> after successful a response)
>>>>>>> Have a play please!
>>>>>>> Also interested in hearing what user tools might be worth looking at
>>>>>>> next for the poller object.
>>>>>>> //.ichael G.
>>>>>>> OvmsDev mailing list
>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240430/2d7f6ee4/attachment-0001.htm>
