Tue Apr 30 17:45:32 HKT 2024
OK, understood & merged, thanks for the quick fix/workaround.
I'll ask the Twizy driver to test this.
PS: side note: there's a shutdown race condition arising from `while
(!m_is_shutdown)` in the new `OvmsVehicle::VehicleTask()`: if the task
receives a message while m_is_shutdown already has been set, it will
exit the loop and return from the task function, which isn't allowed. I
think FreeRTOS will abort in that case.
Am 30.04.24 um 08:55 schrieb Michael Geddes:
> No it will start the poll thread of the poller fine for those that
> don't use it. That's the last commit.... so that should be covered.
> When the callback is registered the thread is force started.
> This is not to say that what you are suggesting isn't a better way
> forward... just that it should work.
> On Tue, 30 Apr 2024, 14:51 Michael Balzer via OvmsDev,
> <ovmsdev at lists.openvehicles.com> wrote:
> Michael,
> (taking this back to the list, as other developers may have
> helpful ideas or suggestions)
> from a first check, your new patch (PR #1008) won't help for
> vehicles that don't use the poller, like the generic DBC vehicle
> or the Fiat 500 (plus possibly non-public third party vehicles).
> As the poller is normally compiled in, these would need a run time
> switch to re-enable the vehicle task, or more suitably default
> into that configuration and switch to the poller task only when
> the poller gets initialized.
> How about moving the task back into the vehicle class, but keeping
> your task message extensions while doing so, and adding a way for
> the poller to hook into the task? The dedicated vehicle task is an
> essential part of the vehicle framework, but I do remember some
> occasions where a general way to pass custom messages to the
> vehicle task would have been helpful to use the task for more than
> CAN processing.
> If the poller shall become avaible as a separate service that can
> be used without any vehicle instance (currently not a defined use
> case), the construct of a CAN processor task that can be extended
> for custom messages (or a message processor task that can
> subscribe to CAN frames) could be factored out into a dedicated
> class or template. The poller could then create his own instance
> of that class, if it cannot hook into an existing one.
> Btw, in case you're not aware of this, FreeRTOS also provides
> queue sets (https://www.freertos.org/RTOS-queue-sets.html). We
> haven't used them in the OVMS yet, but they could be useful,
> especially if message unions become large or tasks shall be able
> to dynamically subscribe to different message sources.
> Am 30.04.24 um 01:20 schrieb Michael Geddes:
>> It might be worth reverting, but, I've got a patch suggestion
>> that I'll push up which will let me know if I understand
>> everything and which might provide a solution.
>> If this isn't going to work then revert. (P/R coming)
>> While the poller was still a part of the vehicle class it was
>> probably still all ok. The poller had taken over what I assume
>> you are talking about as the vehicle task. A call-back fromthe
>> poller was calling IncomingPollRxFrame which was then coming from
>> the (now) poller task (is that correct?)
>> While we have OVMS_COMP_POLLER config defined, we could just use
>> the poller task to provide the IncomingPollRxFrame call-back from
>> the poller (was vehicle?) task.
>> The problem is when OVMS_COMP_POLLER is undefined, we need an
>> alternate (maybe we could use the 'Event' loop then) which is
>> when I hacked that bad solution.
>> //.ichael
>> I was thinking though that because everything is being queued we
>> could divert some calls into the car
>> On Mon, 29 Apr 2024, 18:58 Michael Balzer, <dexter at expeedo.de> wrote:
>> Michael,
>> I've found a severe design flaw with your poller change.
>> Sorry, I should have seen that before, and shouldn't have
>> merged this.
>> You have moved the standard CAN frame processing from the
>> vehicle task into the CAN task by changing the vehicle from a
>> CAN listener to a CAN callback processor. That will break all
>> kind of things, vehicles like the Twizy, Smart and many
>> others rely on frame processing being done in the dedicated
>> vehicle task.
>> This especially induces issues regarding CAN processing
>> capacity, as the vehicles rely on having a separate context
>> and not needing to decouple complex processing of incoming
>> frames. So this will degrade the CAN processing performance
>> seriously in many cases, where additional steps involving
>> file or network I/O need to be done.
>> So this needs to be changed back.
>> I assumed you introduced a new dedicated poller task but kept
>> the vehicle task intact. From your naming
>> (OvmsVehicle::IncomingPollRxFrame), it seems you
>> misinterpreted the vehicle task's purpose as only being used
>> for polling.
>> I assume this isn't a small change…? If so we should revert
>> the poller merge, to avoid having a defunctional edge build
>> state until the fix.
>> Secondly: logging is generally expensive regardless of the
>> log level control and log channels enabled. Any log message
>> needs to be queued to the log system, so involves a lock and
>> a potential wait state (for the queue) & resulting context
>> switch (= minimum delay of 10 ms). Therefore, logging must be
>> avoided as far as possible in any time critical context, and
>> is forbidden under some circumstances, e.g. in a timer
>> callback (see FreeRTOS docs on this). The log system load
>> multiplies with connected web clients or enabled file logging
>> and enabled debug / verbose level logging -- that quickly
>> becomes too much, usually triggering the task watchdog.
>> Your logging of nearly all bus events passing to/from the
>> poller (especially the log entry in Queue_PollerFrame)
>> becomes an issue on any vehicle that has high frequency
>> running process data frames on the bus, like the Twizy or
>> Smart. As a counter measure, I've just added a runtime
>> control for all the poller's verbose logging (by default now
>> off), and changed some debug level logs to verbose. Not sure
>> if I've catched all that may need to be silenced by default.
>> Please check all your log calls and place them under the new
>> "trace" control flag wherever appropriate.
>> This won't help avoiding issues with process data frame buses
>> though.
>> Shall I revert the poller merge for now?
>> Am 29.04.24 um 06:18 schrieb Michael Geddes:
>>> Btw I included the log changes in the p/r which is a few
>>> small commits for the poller.
>>> On Mon, 29 Apr 2024, 07:20 Michael Geddes,
>>> <frog at bunyip.wheelycreek.net> wrote:
>>> Hey Michael,
>>> I've got to work now (it's Monday), but I suspect those
>>> 'giving up' are from unsolicited messages on the bus.
>>> I can re-order things so that the message will likely be
>>> 'dropped (no poll entry)' rather than the time-out message.
>>> And make it a verbose log.
>>> //.ichael
>>> On Mon, 29 Apr 2024 at 00:25, Michael Balzer
>>> Michael,
>>> forwarding the Twizy logs to you directly, as they
>>> contain the user location.
>>> He has just verified it's the new version, he says
>>> the module stops responding as soon as he turns on
>>> the Twizy.
>>> His description of his actions is a bit ambiguous,
>>> and it seems he didn't enable logging to the file
>>> persistently.
>>> According to the server, these were the version boot
>>> times:
>>> 2024-04-28 15:30:56 0
>>> 3.3.004-32-g125e0841/ota_0/edge (build idf
>>> v3.3.4-849-g6e214dc335 Apr 26 2024 19:16:50)
>>> 2024-04-28 16:21:08 0
>>> 2024-04-28 16:38:33 0
>>> 3.3.004-63-gf3595561/ota_1/edge (build idf
>>> v3.3.4-849-g6e214dc335 Apr 27 2024 07:44:50)
>>> 2024-04-28 16:40:57 0
>>> 2024-04-28 16:43:14 0
>>> 2024-04-28 16:46:39 0
>>> 2024-04-28 16:54:44 0
>>> Attached is also his crash debug log -- a2ll doesn't
>>> tell much about what happened, but maybe you get an
>>> idea from this.
>>> After the boot at 16:46, there are immediately lots
>>> of these messages:
>>> 2024-04-28 16:46:33.792 CEST D (39042) vehicle-poll:
>>> Poller: Queue PollerFrame()
>>> [1]Poller: Incoming - giving up
>>> Am 28.04.24 um 16:44 schrieb Michael Geddes:
>>>> Ah. OK.
>>>> I could try to fix the vin thing using the new way
>>>> of doing it and get rid of a semaphore?
>>>> It would at least identify the problem possibly?
>>>> Michael
>>>> On Sun, 28 Apr 2024, 22:32 Michael Balzer via
>>>> OvmsDev, <ovmsdev at lists.openvehicles.com> wrote:
>>>> Not sure if that's the problem, but I've found
>>>> a different behaviour with the new
>>>> PollSetState() implementation.
>>>> The old version only did anything if the new
>>>> state actually was different from the previous
>>>> one. The Twizy relies on this behaviour,
>>>> calling PollSetState() from the per second
>>>> ticker (see OvmsVehicleRenaultTwizy::ObdTicker1).
>>>> The new implementation apparently always sends
>>>> the PollState command to the task, and that in
>>>> turn always at least locks the poller mutex.
>>>> Not sure if/how that could cause the observed
>>>> issues, but it definitely adds quite some
>>>> (unnecessary?) lock/unlock operations.
>>>> Am 28.04.24 um 16:05 schrieb Michael Balzer via
>>>> OvmsDev:
>>>>> The Twizy uses the poller to query the VIN
>>>>> (once) and DTCs (every 10 seconds while
>>>>> driving), see rt_obd2.cpp.
>>>>> It also has its own version of the OBD single
>>>>> request (OvmsVehicleRenaultTwizy::ObdRequest),
>>>>> which was the precursor for the generalized
>>>>> version. This is used by custom/user Twizy
>>>>> plugins and scripts to access ECU internals.
>>>>> The Twizy doesn't use IncomingPollRxFrame, but
>>>>> the Twizy's IncomingPollReply handler will log
>>>>> any poll responses it doesn't know about, so
>>>>> that could lead to a lot of log output if
>>>>> something goes wrong there.
>>>>> Am 28.04.24 um 15:49 schrieb Michael Geddes
>>>>> via OvmsDev:
>>>>>> AFAICT the twizzy doesn't use the poller list
>>>>>> at all. So is it missing a call-back or
>>>>>> something??
>>>>>> I can see a potential problem with
>>>>>> IncomingPollRxFrame being called twice as
>>>>>> much as it should be but only when there is a
>>>>>> poll list. Maybe commenting out this would do
>>>>>> it. (I can find another away to get this
>>>>>> called on the thread I want). This might be
>>>>>> the problem with the smarted
>>>>>> void
>>>>>> OvmsVehicle::OvmsVehicleSignal::IncomingPollRxFrame(canbus*
>>>>>> bus, CAN_frame_t *frame, bool success)
>>>>>> //if (Ready())
>>>>>> // m_parent->IncomingPollRxFrame(frame,
>>>>>> success);
>>>>>> On Sun, 28 Apr 2024 at 21:10, Michael Balzer
>>>>>> via OvmsDev <ovmsdev at lists.openvehicles.com>
>>>>>> wrote:
>>>>>> There may also be an issue with the
>>>>>> Renault Twizy, I've received a report of
>>>>>> a user who is using the edge builds, that
>>>>>> the latest build wouldn't work.
>>>>>> He reports all kinds of errors and
>>>>>> warnings signaled by the car during
>>>>>> driving, and switching back to the
>>>>>> previous build fixed the issues.
>>>>>> I've asked him to provide a debug log
>>>>>> excerpt if possible.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 28.04.24 um 14:29 schrieb Michael
>>>>>> Geddes via OvmsDev:
>>>>>>> OK. That's bad.
>>>>>>> Does the reading work in general?
>>>>>>> Is it just the writing commands?
>>>>>>> Raise a ticket on github and tag me in
>>>>>>> and we can address it that way.
>>>>>>> Michael
>>>>>>> On Sun, 28 Apr 2024, 19:49 Thomas Heuer
>>>>>>> via OvmsDev,
>>>>>>> Hi,
>>>>>>> The new poller code doesn't seem to
>>>>>>> work properly with the smarted.
>>>>>>> D (218831) vehicle-poll:
>>>>>>> [1]PollerNextTick(PRI): cycle
>>>>>>> complete for ticker=215
>>>>>>> V (218831) vehicle-poll: Standard
>>>>>>> Poll Series: List reset
>>>>>>> PollSeriesList::NextPollEntry[!v.standard]:
>>>>>>> ReachedEnd
>>>>>>> [1]PollerSend: Poller Reached End
>>>>>>> D (219691) vehicle-poll: Poller:
>>>>>>> Queue PollerFrame()
>>>>>>> Queue PollerFrame()
>>>>>>> V (219691) vehicle-poll: Pollers:
>>>>>>> FrameRx(bus=2)
>>>>>>> Queue PollerFrame()
>>>>>>> FrameRx(bus=2)
>>>>>>> FrameRx(bus=2)
>>>>>>> Queue PollerFrame()
>>>>>>> *OVMS#*unlock 22
>>>>>>> Vehicle unlocked
>>>>>>> FrameRx(bus=2)
>>>>>>> Queue PollerFrame()
>>>>>>> FrameRx(bus=2)
>>>>>>> D (219701) vehicle-poll: Poller:
>>>>>>> Queue PollerFrame()
>>>>>>> V (219701) vehicle-poll: Pollers:
>>>>>>> FrameRx(bus=2)
>>>>>>> Queue PollerFrame()
>>>>>>> FrameRx(bus=2)
>>>>>>> Queue PollerFrame()
>>>>>>> FrameRx(bus=2)
>>>>>>> Queue PollerFrame()
>>>>>>> FrameRx(bus=2)
>>>>>>> Queue PollerFrame()
>>>>>>> FrameRx(bus=2)
>>>>>>> Queue PollerFrame()
>>>>>>> FrameRx(bus=2)
>>>>>>> Queue PollerFrame()
>>>>>>> FrameRx(bus=2)
>>>>>>> Queue PollerFrame()
>>>>>>> FrameRx(bus=2)
>>>>>>> Queue PollerFrame()
>>>>>>> FrameRx(bus=2)
>>>>>>> Queue PollerFrame()
>>>>>>> FrameRx(bus=2)
>>>>>>> Queue PollerFrame()
>>>>>>> *Von:*OvmsDev
>>>>>>> <ovmsdev-bounces at lists.openvehicles.com>
>>>>>>> *Im Auftrag von *Michael Geddes via
>>>>>>> OvmsDev
>>>>>>> *Gesendet:* Sonntag, 28. April 2024
>>>>>>> 12:27
>>>>>>> *An:* OVMS Developers
>>>>>>> *Cc:* Michael Geddes
>>>>>>> *Betreff:* [Ovmsdev] OVMS Poller
>>>>>>> module/singleton
>>>>>>> Hey all,
>>>>>>> The poller singleton code that I've
>>>>>>> been working on for over a year now
>>>>>>> is merged in. (Thanks Michael for
>>>>>>> expediting the final step).
>>>>>>> This includes separate multi-frame
>>>>>>> states per bus and multiple poll
>>>>>>> lists as well as non-blocking one
>>>>>>> off queries. As well as more 'states'.
>>>>>>> I have included some programming
>>>>>>> documentation in the change but am
>>>>>>> happy to supply more if needed.
>>>>>>> The ioniq 5 code has some examples
>>>>>>> of how it can be used. Some examples
>>>>>>> are:
>>>>>>> * grabbing the vin as a one shot
>>>>>>> without blocking
>>>>>>> * having a short list of queries
>>>>>>> that are polled quickly for obd2ecu
>>>>>>> (this also demonstrates using a
>>>>>>> shorter frame break value and then a
>>>>>>> break after successful a response)
>>>>>>> Have a play please!
>>>>>>> Also interested in hearing what user
>>>>>>> tools might be worth looking at next
>>>>>>> for the poller object.
>>>>>>> //.ichael G.
>>>>>>> OvmsDev mailing list
>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240430/93efcdf7/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240430/93efcdf7/attachment-0001.sig>
