[Ovmsdev] OBD poller module shell proposal
Sun Apr 7 16:43:40 HKT 2024
Michael,
I think this…
https://github.com/frogonwheels/Open-Vehicle-Monitoring-System-3/blob/new-poller/vehicle/OVMS.V3/components/vehicle/vehicle.cpp#L358
   MyPollers.*RegisterRunFinished*(TAG,
std::bind(&OvmsVehicle::PollerStateTickerNotify, this, _1, _2));
…should be a call to MyPollers.RegisterPollStateTicker() instead, and
OvmsVehicle::ShuttingDown() is missing a call to
DeregisterPollStateTicker().
Am 31.03.24 um 01:44 schrieb Michael Geddes:
> I have pushed up changes for PR#966 as well as to the 'new-poller'
> branch that handle the PollerStateTicker()
> //.ichael
> On Sat, 30 Mar 2024 at 08:39, Michael Geddes
> <frog at bunyip.wheelycreek.net> wrote:
>     Thanks so much for giving this a good run.
>     I totally missed that about the purpose of PollerStateTicker() damn.
>     I think I can call this on primary ticks only from PollerSend()
>     itself outside of the mutex.  That would work - I'll get onto that.
>     In the original PR# 966 PollerSend() is an OvmsVehicle() member
>     and as such this is a no-brainer.
>     That would mean it will get called from the Rx/Poller task rather
>     than the schedule (ticker1) task which is not necessarily a bad
>     thing... but different.
>     I believe that for the Poller implementation though, this will
>     need to be an event similar to PollRunFinished()  - which kind of
>     has similar usage but occurs between (effectively) poller ticks
>     (ie when all the
>     entries in the list have been dealt with) rather than what will be
>     at the beginning of each Primary tick.
>     Unless you have an objection - I'll pass in (canbus* bus) to this
>     - similar to PollRunFinished()
>     //.ichael
>     On Fri, 29 Mar 2024 at 21:51, Michael Balzer <dexter at expeedo.de>
>     wrote:
>         Michael,
>         first feedback: testing this revealed some strange issues with
>         vehicle state changes apparently not being detected or reacted
>         to properly.
>         A quick first check shows you have changed the way, the
>         PollerStateTicker() hook works: it's now called independently
>         from / as of the component ticker.1 registration sequence
>         after the poller's primary send, rather than before.
>         The callback was explicitly meant to provide a means to change
>         the poller state just before the next poll would take place:
>          * PollerStateTicker: check for state changes (stub, override
>         with vehicle implementation)
>          *  This is called by VehicleTicker1() just before the next
>         PollerSend().
>          *  Implement your poller state transition logic in this
>         method, so the changes
>          *  will get applied immediately.
>         This change is already present in PR #966, so I'll delay
>         merging that.
>         Apart from that, the new poller seems to work normally, i.e.
>         the polling scheme works and results are coming in, at least
>         regarding ISOTP. I haven't tested VWTP yet.
>         Regards,
>         Michael
>         Am 26.03.24 um 08:46 schrieb Michael Geddes:
>>         Yeah wow.  So close and yet so far.
>>         Fix pushed.
>>         On Sat, 23 Mar 2024 at 21:58, Michael Balzer
>>         <dexter at expeedo.de> wrote:
>>             Michael,
>>             looking forward to test this, but trying to run your
>>             branch with the VW e-Up leads to an early crash boot loop.
>>             Apparently `OvmsPollers::PollSetPidList()` doesn't check
>>             for a NULL plist:
>>             0x40195b6f is in OvmsPollers::PollSetPidList(canbus*,
>>             OvmsPoller::poll_pid_t const*,
>>             OvmsPoller::VehicleSignal*)
>>             (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/poller/src/vehicle_poller.cpp:1201).
>>             1196      bool hasbus[1+VEHICLE_MAXBUSSES];
>>             1197      for (int i = 0 ; i <= VEHICLE_MAXBUSSES; ++i)
>>             1198        hasbus[i] = false;
>>             1199
>>             1200      // Check for an Empty list.
>>             *1201      if (plist->txmoduleid == 0)*
>>             1202        {
>>             1203        plist = nullptr;
>>             1204        ESP_LOGD(TAG, "PollSetPidList - Setting Empty
>>             List");
>>             1205        }
>>             0x401a2675 is in OvmsVehicle::PollSetPidList(canbus*,
>>             OvmsPoller::poll_pid_t const*)
>>             (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/vehicle/vehicle.cpp:2278).
>>             2273      return m_pollsignal;
>>             2274      }
>>             2275    void OvmsVehicle::PollSetPidList(canbus* bus,
>>             const OvmsPoller::poll_pid_t* plist)
>>             2276      {
>>             2277      m_poll_bus_default = bus;
>>             2278      MyPollers.PollSetPidList(bus, plist,
>>             GetPollerSignal());
>>             2279      }
>>             2280    #endif
>>             2281
>>             2282    /**
>>             0x4023209e is in OvmsVehicleVWeUp::OBDInit()
>>             (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/vehicle_vweup/src/vweup_obd.cpp:233).
>>             228       obd_state_t previous_state = m_obd_state;
>>             229       m_obd_state = OBDS_Config;
>>             230
>>             231       if (previous_state != OBDS_Pause)
>>             232       {
>>             *233 PollSetPidList(m_can1, NULL);*
>>             234         PollSetThrottling(0);
>>             235 PollSetResponseSeparationTime(1);
>>             236
>>             237         if
>>             (StandardMetrics.ms_v_charge_inprogress->AsBool())
>>             Regards,
>>             Michael
>>             Am 21.03.24 um 10:17 schrieb Michael Geddes:
>>>             I've pushed up my working tree  here:
>>>             https://github.com/frogonwheels/Open-Vehicle-Monitoring-System-3/tree/new-poller
>>>             partly for feedback, and partly because I wanted it
>>>             backed up!
>>>             This incorporates about 10 pull/requests worth of work
>>>             which is why I didn't even add it as a draft, so I see
>>>             this as taking some number of months to push up.
>>>             Of interest is really the final
>>>             components/poller/src/vehicle_poller* files and how that
>>>             has all come together..  I've added some preliminary
>>>             documentation for that  which I'm quite happy to accept
>>>             any critiques or requests for specific information!
>>>             The Duktape  metrics 'stale, age' methods are probably
>>>             ready for a p/r as-is.
>>>             //.ichael
>>>             On Sun, 17 Mar 2024 at 16:58, Michael Geddes
>>>                 Thanks Michael,
>>>                 I'll definitely add the config - pretty much sorted
>>>                 out the singleton (except for the change of
>>>                 directory).  Just wondering if I should rebase this
>>>                 change down earlier or just keep it as the 'last
>>>                 change' that is making the final break.  It might be
>>>                 a better transition that way?
>>>                 Anyway have a look at this little class below; we
>>>                 have a bunch of different implementations for an
>>>                 event register and came up with the
>>>                 OvmsCallBackRegister below.
>>>                 In my example the event notification looks like this:
>>>                     void PollRunFinished(canbus *bus)
>>>                 m_runfinished_callback.Call(
>>>                         [bus](const std::string &name, const
>>>                 PollCallback &cb)
>>>                           cb(bus, nullptr);
>>>                 I could possibly but it in main/ovms_utils.h  ??  It
>>>                 could also use a std:map to implement it, though I
>>>                 think we save space this way and tbh the use case
>>>                 wouldn't be doing a lot of Register and Unregister
>>>                 which would be the slowest operations...   I've made
>>>                 it not shrink the list size .... but again, not that
>>>                 important in the context.
>>>                 Thoughts?
>>>                 //.ichael
>>>                 --------------8< -----------------------------------
>>>                 /* Call-back register.
>>>                  * The list does not shrink which is fine for this
>>>                 use-case.
>>>                  * Can be made inexpensively threadsafe/re-entrant safe.
>>>                 template <typename FN>
>>>                 class OvmsCallBackRegister
>>>                   private:
>>>                   class CallbackEntry
>>>                     public:
>>>                       CallbackEntry(const std::string &caller, FN
>>>                 callback)
>>>                         m_name = caller;
>>>                         m_callback = callback;
>>>                       ~CallbackEntry() {}
>>>                     public:
>>>                       std::string m_name;
>>>                       FN m_callback;
>>>                     typedef std::forward_list<CallbackEntry>
>>>                 callbacklist_t;
>>>                     callbacklist_t m_list;
>>>                   public:
>>>                     ~OvmsCallBackRegister()
>>>                     void Register(const std::string &nametag, FN
>>>                 callback)
>>>                       // Replace
>>>                       for (auto it = m_list.begin(); it !=
>>>                 m_list.end(); ++it)
>>>                         if ((*it).m_name == nametag)
>>>                           (*it).m_callback = callback;
>>>                           return;
>>>                       if (!callback)
>>>                         return;
>>>                 m_list.end(); ++it)
>>>                         if (!(*it).m_callback)
>>>                           CallbackEntry &entry = *it;
>>>                           entry.m_name = nametag;
>>>                           entry.m_callback = callback;
>>>                           return;
>>>                 m_list.push_front(CallbackEntry(nametag, callback));
>>>                     void Deregister(const std::string &nametag)
>>>                       Register(nametag, nullptr);
>>>                     typedef std::function<void (const std::string
>>>                 &nametag, FN callback)> visit_fn_t;
>>>                     void Call(visit_fn_t visit)
>>>                 m_list.end(); ++it)
>>>                         const CallbackEntry &entry = *it;
>>>                         if (entry.m_callback)
>>>                           visit(entry.m_name, entry.m_callback);
>>>                 On Thu, 14 Mar 2024 at 12:08, Mark Webb-Johnson
>>>                 <mark at webb-johnson.net> wrote:
>>>                     Michael,
>>>                     I suggest that if it is a separate component
>>>                     then better to move it to it’s own component
>>>                     directory (just as canopen is done).
>>>                     For completeness, I suggest it would also be
>>>                     good to include a CONFIG_OVMS_COMP_* sdkconfig
>>>                     (default: yes), and put that as a requirement
>>>                     for your component (as well as for any vehicle
>>>                     doing polling, I guess).
>>>                     Regards, Mark
>>>>                     On 14 Mar 2024, at 11:01 AM, Michael Geddes
>>>>                     Thanks Michael, Mark,
>>>>                     Sorry for not acknowledging earlier.. this
>>>>                     feedback is great; I've just been cogitating on
>>>>                     the consequences.
>>>>                     I still have the Poller hanging onto the
>>>>                     vehicle by a thread so I should just cut the
>>>>                     thread making the Poller a separate singleton
>>>>                     (it's still embedded in the vehicle class for
>>>>                     now with a small interface joining them).
>>>>                     If I do, does it need to get moved to a new
>>>>                     directory or can it stay in the vehicle/
>>>>                     directory? The file vehicle_poller.cpp (and the
>>>>                     _isotp and vwtp parts to it) are still pretty
>>>>                     much as they were with only a change in class
>>>>                     name..
>>>>                     I think I just need the poller to get its own
>>>>                     values of m_can1 etc and provide a different
>>>>                     way of getting the feedback results.
>>>>                     I also need to make sure I'm not cutting off
>>>>                     the 'vehicle' class' access to non-solicited
>>>>                     messages (ie stuff that is just on the bus).
>>>>                     //.ichael
>>>>                     On Mon, 11 Mar 2024 at 14:51, Michael Balzer
>>>>                         Actually, separating the poller from the
>>>>                         vehicle was part of the plan of reworking
>>>>                         it into a job/worker architecture. I see no
>>>>                         reason the generalized poller would need to
>>>>                         remain coupled to the vehicle.
>>>>                         That's why I placed the OBD single request
>>>>                         command in the "obdii" hierarchy (although
>>>>                         a more proper naming would have been e.g.
>>>>                         "isotp", but changing the name or having
>>>>                         both would confuse users -- and meanwhile
>>>>                         the poller also supports a non-ISO TP variant).
>>>>                         Regards,
>>>>                         Michael
>>>>                         Am 11.03.24 um 00:51 schrieb Mark Webb-Johnson:
>>>>>                         Michael,
>>>>>                         It depends on whether the poller can
>>>>>                         *only* be used in the vehicle class or if
>>>>>                         it is a framework all by itself (for
>>>>>                         example with commands to manually poll
>>>>>                         specific PIDs, etc).
>>>>>                         If *only* within vehicle framework, then
>>>>>                         putting it as a sub-command under
>>>>>                         ‘vehicle’ seems sensible.
>>>>>                         If more general purpose, then perhaps look
>>>>>                         at ‘copen’ (component/canopen) as an example.
>>>>>                         Regards, Mark.
>>>>>>                         On 10 Mar 2024, at 7:25 AM, Michael
>>>>>>                         Geddes <frog at bunyip.wheelycreek.net>
>>>>>>                         <mailto:frog at bunyip.wheelycreek.net> wrote:
>>>>>>                         Hi all,
>>>>>>                         I know some of this (especially for the
>>>>>>                         status) functionality is predicated on
>>>>>>                         code that's not gone up yet - however
>>>>>>                         this is allowing 'pause' and 'resume' of
>>>>>>                         the poller (which has been merged).
>>>>>>                         My question is not so much about the
>>>>>>                         functionality and status information, but
>>>>>>                         about the location of the
>>>>>>                         *poller* subcommand. (See below).
>>>>>>                         Should 'vehicle' be exclusively for
>>>>>>                         switching the vehicle type?  Should the
>>>>>>                         'poller' command be top-level? Under obdii?
>>>>>>                         Thoughts welcome.
>>>>>>                         If you do  vehicle poller pause then the
>>>>>>                         last line reads 'Vehicle OBD Polling is
>>>>>>                         paused'
>>>>>>                         -------8<----------------------------------------
>>>>>>                         *OVMS# vehicle ?*
>>>>>>                         Usage: vehicle [list|module|poller|status]
>>>>>>                         list       Show list of available vehicle
>>>>>>                         modules
>>>>>>                         module       Set (or clear) vehicle module
>>>>>>                         poller       OBD polling status
>>>>>>                         status       Show vehicle module status
>>>>>>                         *OVMS# vehicle poller ?*
>>>>>>                         Usage: vehicle poller [pause|resume]
>>>>>>                         pause        Pause OBD Polling
>>>>>>                         resume       Resume OBD Polling*
>>>>>>                         *OVMS# vehicle poller*
>>>>>>                         OBD Polling running on bus 1 with an
>>>>>>                         active list
>>>>>>                         Time between polling ticks is 1000ms with
>>>>>>                         1 secondary sub-ticks
>>>>>>                         Last poll command received 1s (ticks) ago.
>>>>>>                         Vehicle OBD Polling is running.
>>>>>>                         _______________________________________________
>>>>>>                         OvmsDev mailing list
>>>>>>                         OvmsDev at lists.openvehicles.com
>>>>>>                         http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>                         Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>                         Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240407/0aec32d1/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240407/0aec32d1/attachment-0001.sig>
