[Ovmsdev] FIAT e-Doblo (same as Peugeot Rifter, Opel Combo, Citroen Berlingo?)
Raphael Mack ramack at raphael-mack.de
Wed Apr 3 00:54:13 HKT 2024
Thanks Mark for your answer!
It would even have been fine to simply refer
to https://www.openvehicles.com/developers#gbaqjodltq 😉️
and https://docs.google.com/document/d/1q5M9Lb5jzQhJzPMnkMKwy4Es5YK12ACQejX_NWEixr0/edit
Anyhow, as I've identified the SoC and milage signals already and can
extract them from traces I would like to go on with a real code change
and wonder about the best name for this case. Could you do me the favor
and comment in the github ticket to guide me on the naming?
Last but not least, I don't want to miss saying thank you for the great
tool you all here developed! Already being able to recod traces or
stream the traffic via network is really a big help in this reverese
engineering tasks and it's fun using it!
Rapha
Am Donnerstag, dem 29.02.2024 um 22:42 +0100 schrieb Raphael Mack:
> Hi,
> I own a eDoblo from Fiat and recently bought an OVMS. Very
> cool.project, thanks for all.the effort you all have put in it!
> Beside trouble to permanently plug in the generic ODB2 connector due
> to space below the cover I face the fact that it is not supported by
> OVMS. So I created
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/976
>  and would like to contribute.
> In my former life I worked in automotive industry but I already
> recognized that it is much easier to read a CAN trace if you have a
> DBC and the well known Vector tools at hand 😃.
> In case anyone has some hints where I can get more info about the
> frames and signals, even from other cars in the same family (EMP2,
> Peugeot e208, e2008, Opel mokka-e) from the Stellantis brands or
> former PSA it could be a great help to sort at least some ID into the
> 'interesting' or 'boring' boxes.
> Last but not least any idea where I could get an overall bus
> architecture for the car from would be cool, as I would like to
> install the the OVMS in a permanent place different from the ODB2
> connector.
> Looking forward to a great journey here.
> BTW: initially I had trouble receiving mails from the list, as the
> sending servers IP was on some blacklist and therefore blocked on my
> incoming mailserver. So if you could put me personally on CC on an
> answer I'd be happy, just in case this is not yet sorted out.
> Rapha
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20240402/ffe0de0c/attachment.htm>
