[Ovmsdev] GSM + GPS combined antenna working!
Fri Oct 6 18:54:00 HKT 2023
It would be nice to know which component was responsible for the
interference, and what was broken to cause this, but you'd probably need
an EM laboratory to find out.
A broad range of combined GSM/GPS antenna are available now, also some
nice shark fin shaped ones for roof mounting. Unfortunately they are all
much higher priced than the combination of the single purpose ones.
Am 05.10.23 um 06:46 schrieb Michael Geddes:
> I believe I have finally resolved the issue with the GSM daughter
> board and/or antenna interfering with my GPS. I replaced both and it
> seems to be all good now.
> Interestingly, I found this nice Antenna that has GSM and GPS (with 2
> well-labeled tails that are compatible with the OVMS connections).
> https://www.amazon.com.au/dp/B07V9HRF65
> It seems to be working well and is much neater to replace (I snaked it
> up through to the speaker+air cover on the front dash area).
> //.ichael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20231006/f95ee63e/attachment.sig>
