[Ovmsdev] GSM + GPS combined antenna working!
Michael Geddes
Fri Oct 6 19:19:04 HKT 2023
Indeed, it would be good.. unless somebody in Perth happens to have such a
Lab... yeah, might be a bit hard.
I guess I could try ruling out the antennas..
On Fri, 6 Oct 2023, 18:54 Michael Balzer, <dexter at expeedo.de> wrote:
> It would be nice to know which component was responsible for the
> interference, and what was broken to cause this, but you'd probably need
> an EM laboratory to find out.
> A broad range of combined GSM/GPS antenna are available now, also some
> nice shark fin shaped ones for roof mounting. Unfortunately they are all
> much higher priced than the combination of the single purpose ones.
> Am 05.10.23 um 06:46 schrieb Michael Geddes:
> > I believe I have finally resolved the issue with the GSM daughter
> > board and/or antenna interfering with my GPS. I replaced both and it
> > seems to be all good now.
> > Interestingly, I found this nice Antenna that has GSM and GPS (with 2
> > well-labeled tails that are compatible with the OVMS connections).
> > https://www.amazon.com.au/dp/B07V9HRF65
> > It seems to be working well and is much neater to replace (I snaked it
> > up through to the speaker+air cover on the front dash area).
> > //.ichael
> > OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20231006/df4424fd/attachment.htm>
