[Ovmsdev] Review request
Thu May 18 16:16:33 HKT 2023
Hi Ludovic
Thank you for all your efforts to get ESP-IDF to the newest version.
The reason why I have not been able to test along the way is, that I
was not able to set up a native, non-docker, working test environment
with the newer ESP-IDF versions.
Is there a "step by step" documentation for setting up these newer
versions without docker? That would be really helpfull.
Regards
Chris
Am Donnerstag, dem 18.05.2023 um 00:05 +0200 schrieb Ludovic LANGE:
> Hi List,
> If possible, I'd like a peer-review / discussion of the following
> PRs:
>  * ESP-IDF v4+: we do not have uxMutexesHeld any more #901
>    In ESP-IDF 3.3.x builds of OVMS, we're using a fork of ESP-IDF. In
>    this fork, FreeRTOS has been patched with openvehicles/esp-
>    idf at 95e43fc to add a uxMutexesHeld field in TaskStatus_t.However, in
>    the ESP-IDF >= 4 build we're using mainstream ESP-IDF (for the
>    moment), which does not include this field.So we adapt the display
>    to handle both cases.
>  * ESP-IDF4+ : crash handler and boot status #902
>    error handling rework (xt_set_error_handler_callback is only
>    available in our ESP-IDF 3.3.4
>    fork.)esp_task_wdt_get_trigger_tasknames() not available (feature
>    removed from ESP-IDF4+ builds) TODOfirst steps to support other
>    archs than XTensa in boot_data.crash_data
> These are the last 2 PRs before being able to build with any of these
> ESP-IDF versions : 3.3.4-ovms, 4.4.4, 5.0, 5.0.1, branch-v5.0,
> branch-v5.1, latest - the last mile !
> (One workaround PR is pending to be able to run one of these new
> versions, preventing a crash at boot - but it needs a proper analysis
> first)
> Also, with these 2 PRs, we will be able to enable automatic builds on
> all these versions on master (using GitHub "Actions") - you can have
> a preview of what I mean here :
> https://github.com/llange/Open-Vehicle-Monitoring-System-3/actions
> As we're slowly entering a period of transition between ESP-IDF
> 3.3.4-ovms and a more recent one (5.0.1 ?), we will need a way to
> ensure that the PRs / commits are OK across all these versions.
> Automatic builds can be configured to build on all targeted ESP-IDF
> versions, and can report their result back in the PRs, so that we can
> trap potential compilation errors before merging.
> (Especially as in the newer ESP-IDF versions, more and more warnings
> are treated as compilation errors)
> I also prepared a check for documentation errors using the same
> mechanism.
> Thanks in advance.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230518/f7b0c57e/attachment.htm>
