[Ovmsdev] Can't compile due to wolfssh
Sun May 14 03:39:59 HKT 2023
"git submodule sync --recursive" did the trick.
I was on wolfssh 1.4.13. Now I'm back on 1.4.10 and 3.3.003-467-
ge7f41bd8-dirty compiles.
Still "dirty" but it compiles.
Thanx!
Am Samstag, dem 13.05.2023 um 21:23 +0200 schrieb Ludovic LANGE:
> Indeed I was going to suggest that you pull fresh from master in
> another new dir in fact.
> When doing so, you should have:
> * "vehicle/OVMS.V3/components/wolfssh/wolfssh" as a submodule
> * "vehicle/OVMS.V3/components/wolfssl/wolfssl" as a normal dir (for
> now. Will change in a few PR's)
> You can check that with :
> $ git submodule status 7b953e7ebb440ce9461ee469159c3759450e7c98
> vehicle/OVMS.V3/components/mongoose/mongoose (6.2-882-g7b953e7)
> c05f6c7530a8670e3d0ffdf04ee4cecb2d3b0496
> vehicle/OVMS.V3/components/wolfssh/wolfssh (v1.4.10-stable)
> 7c3878f8302c0e84578a67473e49e60bc6b3ada7
> vehicle/OVMS.V3/components/zip/libzip (rel-1-5-1-60-g7c3878f)
> d6bcf4ca4d02479f058fff44cfd171f928148179
> vehicle/OVMS.V3/components/zip/zlib (v1.2.11-65-gd6bcf4c)
> In particular, you should have wolfssh at v1.4.10-stable
> If not, please try both:
> git submodule update --init --recursive
> If not, please be sure that you do all this in a separate fresh
> directory.
> If a new user tries to compile from scratch, I believe it should
> work. (I've just tried it, and it "works for me")
> The error you have seems to imply that wolfssh is not at the proper
> 1.4.10 version but at a version >= 1.4.12
> Let us know.
> Le 13/05/2023 à 19:59, Chris van der Meijden a écrit :
> Could you please explain in detail what I need to do?
> I tried to pull the code completely fresh from master. That does not
> work.
> What if a new user tries to compile from scratch? Will they run into
> the same issues?
> Am Samstag, dem 13.05.2023 um 19:32 +0200 schrieb Ludovic LANGE:
> > Hi Chris,
> > Yes we unfortunately had an issue where we merged, then reverted a
> > patch.
> > It seems that unfortunately it didn't work for you. Could you try
> > to fetch, then reset your git repo to HEAD, it seems you did not
> > fetch the "revert" patches ?
> > Let us know.
> > Le 13/05/2023 à 19:08, Chris van der Meijden a écrit :
> > Today I pulled the newest version. During the pull my Wolfssh
> > directory was deleted. I then renewed all the submodules and I got
> > the newest Wolfssh.
> > But now the verion 3.3.003-467-ge7f41bd8-dirty won't compile (why
> > is it "dirty" anyways, I didn't change the code ...).
> > First I get
> > CXX build/console_ssh/src/console_ssh.o
> > /home/chris/OVMS/Open-Vehicle-Monitoring-System-
> > 3/vehicle/OVMS.V3/components/console_ssh/src/console_ssh.cpp: In
> > function 'void wolfssh_logger(wolfSSH_LogLevel, const char*)':
> > 3/vehicle/OVMS.V3/components/console_ssh/src/console_ssh.cpp:1176:1
> > 0: error: enumeration value 'WS_LOG_CERTMAN' not handled in switch
> > [-Werror=switch]
> > switch (level)
> > Then I add case WS_LOG_CERTMAN: on line 1178:
> > static void wolfssh_logger(enum wolfSSH_LogLevel level, const char*
> > const msg)
> > switch (level)
> > But the I run into this error:
> > 3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c: In
> > function 'IdentifyKey':
> > 3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c:883:9:
> > warning: unused variable 'dynType' [-Wunused-variable]
> > int dynType = isPrivate ? DYNTYPE_PRIVKEY : DYNTYPE_PUBKEY;
> > function 'DoKexDhReply':
> > 3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c:3947:17
> > : error: implicit declaration of function 'PRIVATE_KEY_UNLOCK' [-
> > Werror=implicit-function-declaration]
> > PRIVATE_KEY_UNLOCK();
> > 3/vehicle/OVMS.V3/components/wolfssh/wolfssh/src/internal.c:3952:17
> > : error: implicit declaration of function 'PRIVATE_KEY_LOCK' [-
> > PRIVATE_KEY_LOCK();
> > Any ideas?
> > Regards Chris
> > OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230513/96b1356f/attachment-0001.htm>
