[Ovmsdev] crash when calling 12 V history
Simon Ehlen
ovms at highteq.de
Wed May 3 16:29:07 HKT 2023
Hello Michael,
unfortunately that did not help.
In the development console I see that it cannot load the file assets/bootstrap-theme.min.css.map.
Cheers,
Simon
Am 03.05.2023 um 10:10 schrieb Michael Balzer:
> Simon,
> try clearing your browser cache & doing a full page reload.
> Am 03.05.23 um 09:37 schrieb Simon Ehlen:
>> Good morning Michael,
>> thank you very much for your help. A 'module factory reset' did indeed bring back the 12 V history and as you suspected, calling the plugin in the editor had also resulted in a crash.
>> What I noticed in addition is that the dashboard looks pretty empty. Not a single gauge is displayed. However, calling the dashboard does not result in a crash, but no values are read either.
>> Is there anything else I can reset?
>> Thanks a lot!
>> Cheers,
>> Simon
>> Am 03.05.2023 um 08:13 schrieb Michael Balzer:
>>> Simon,
>>> the crash appears when loading the web UI plugin file, so that's probably corrupted. Which in turn means your /store partition is likely corrupted as well, so I'd recommend doing a factory reset & restore from your latest backup.
>>> You can try to edit the plugin in the plugin or text editor to see if it crashes then as well.
>>> Am 02.05.23 um 19:38 schrieb Simon Ehlen:
>>>> Hello,
>>>> since a few days my OVMS crashes as soon as I call the 12 V history monitor from the webinterface. The crash happens right after the click in the menu even before the history web page is loaded.
>>>> I have not made any changes to my firmware recently nor any changes to the 12 V history at all.
>>>> Yesterday I compiled the current version as a test, but the error occurs there as well.
>>>> Attached is the information from a2l with the backtrace.
>>>> Cheers,
>>>> Simon
>>>> OvmsDev mailing list
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230503/e9ddf605/attachment-0001.png>
