[Ovmsdev] crash when calling 12 V history
Wed May 3 16:10:26 HKT 2023
Simon,
try clearing your browser cache & doing a full page reload.
Am 03.05.23 um 09:37 schrieb Simon Ehlen:
> Good morning Michael,
> thank you very much for your help. A 'module factory reset' did indeed
> bring back the 12 V history and as you suspected, calling the plugin
> in the editor had also resulted in a crash.
> What I noticed in addition is that the dashboard looks pretty empty.
> Not a single gauge is displayed. However, calling the dashboard does
> not result in a crash, but no values are read either.
> Is there anything else I can reset?
> Thanks a lot!
> Cheers,
> Simon
> Am 03.05.2023 um 08:13 schrieb Michael Balzer:
>> Simon,
>> the crash appears when loading the web UI plugin file, so that's
>> probably corrupted. Which in turn means your /store partition is
>> likely corrupted as well, so I'd recommend doing a factory reset &
>> restore from your latest backup.
>> You can try to edit the plugin in the plugin or text editor to see if
>> it crashes then as well.
>> Am 02.05.23 um 19:38 schrieb Simon Ehlen:
>>> Hello,
>>> since a few days my OVMS crashes as soon as I call the 12 V history
>>> monitor from the webinterface. The crash happens right after the
>>> click in the menu even before the history web page is loaded.
>>> I have not made any changes to my firmware recently nor any changes
>>> to the 12 V history at all.
>>> Yesterday I compiled the current version as a test, but the error
>>> occurs there as well.
>>> Attached is the information from a2l with the backtrace.
>>> Cheers,
>>> Simon
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230503/8f118569/attachment-0001.sig>
