[Ovmsdev] crash when calling 12 V history
Simon Ehlen
ovms at highteq.de
Wed May 3 15:37:26 HKT 2023
Good morning Michael,
thank you very much for your help. A 'module factory reset' did indeed bring back the 12 V history and as you suspected, calling the plugin in the editor had also resulted in a crash.
What I noticed in addition is that the dashboard looks pretty empty. Not a single gauge is displayed. However, calling the dashboard does not result in a crash, but no values are read either.
Is there anything else I can reset?
Thanks a lot!
Cheers,
Simon
Am 03.05.2023 um 08:13 schrieb Michael Balzer:
> Simon,
> the crash appears when loading the web UI plugin file, so that's probably corrupted. Which in turn means your /store partition is likely corrupted as well, so I'd recommend doing a factory reset & restore from your latest backup.
> You can try to edit the plugin in the plugin or text editor to see if it crashes then as well.
> Am 02.05.23 um 19:38 schrieb Simon Ehlen:
>> Hello,
>> since a few days my OVMS crashes as soon as I call the 12 V history monitor from the webinterface. The crash happens right after the click in the menu even before the history web page is loaded.
>> I have not made any changes to my firmware recently nor any changes to the 12 V history at all.
>> Yesterday I compiled the current version as a test, but the error occurs there as well.
>> Attached is the information from a2l with the backtrace.
>> Cheers,
>> Simon
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230503/84b625c3/attachment.png>
