[Ovmsdev] crash when calling 12 V history
Wed May 3 14:13:39 HKT 2023
Simon,
the crash appears when loading the web UI plugin file, so that's
probably corrupted. Which in turn means your /store partition is likely
corrupted as well, so I'd recommend doing a factory reset & restore from
your latest backup.
You can try to edit the plugin in the plugin or text editor to see if it
crashes then as well.
Am 02.05.23 um 19:38 schrieb Simon Ehlen:
> Hello,
> since a few days my OVMS crashes as soon as I call the 12 V history
> monitor from the webinterface. The crash happens right after the click
> in the menu even before the history web page is loaded.
> I have not made any changes to my firmware recently nor any changes to
> the 12 V history at all.
> Yesterday I compiled the current version as a test, but the error
> occurs there as well.
> Attached is the information from a2l with the backtrace.
> Cheers,
> Simon
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230503/231297ab/attachment.sig>
