[Ovmsdev] crash when calling 12 V history
Thu May 4 01:53:25 HKT 2023
Simon,
the css.map file isn't provided by the module.
The actual error seems to be in the dashboard configuration, at least
that's what could cause an eval syntax error as shown.
That's the initial <script> block in the page response (use the network
panel to see the full response). It should contain a valid JSON element.
Am 03.05.23 um 10:29 schrieb Simon Ehlen:
> Hello Michael,
> unfortunately that did not help.
> In the development console I see that it cannot load the file
> assets/bootstrap-theme.min.css.map.
> Cheers,
> Simon
> Am 03.05.2023 um 10:10 schrieb Michael Balzer:
>> Simon,
>> try clearing your browser cache & doing a full page reload.
>> Am 03.05.23 um 09:37 schrieb Simon Ehlen:
>>> Good morning Michael,
>>> thank you very much for your help. A 'module factory reset' did
>>> indeed bring back the 12 V history and as you suspected, calling the
>>> plugin in the editor had also resulted in a crash.
>>> What I noticed in addition is that the dashboard looks pretty empty.
>>> Not a single gauge is displayed. However, calling the dashboard does
>>> not result in a crash, but no values are read either.
>>> Is there anything else I can reset?
>>> Thanks a lot!
>>> Cheers,
>>> Simon
>>> Am 03.05.2023 um 08:13 schrieb Michael Balzer:
>>>> Simon,
>>>> the crash appears when loading the web UI plugin file, so that's
>>>> probably corrupted. Which in turn means your /store partition is
>>>> likely corrupted as well, so I'd recommend doing a factory reset &
>>>> restore from your latest backup.
>>>> You can try to edit the plugin in the plugin or text editor to see
>>>> if it crashes then as well.
>>>> Regards,
>>>> Michael
>>>> Am 02.05.23 um 19:38 schrieb Simon Ehlen:
>>>>> Hello,
>>>>> since a few days my OVMS crashes as soon as I call the 12 V
>>>>> history monitor from the webinterface. The crash happens right
>>>>> after the click in the menu even before the history web page is
>>>>> loaded.
>>>>> I have not made any changes to my firmware recently nor any
>>>>> changes to the 12 V history at all.
>>>>> Yesterday I compiled the current version as a test, but the error
>>>>> occurs there as well.
>>>>> Attached is the information from a2l with the backtrace.
>>>>> Cheers,
>>>>> Simon
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230503/ea7e8228/attachment.sig>
