[Ovmsdev] Modem - Last Error: User Interrupt
    Chris van der Meijden
    chris at arachnon.de
    Sat Jul 22 03:53:44 HKT 2023
Wifi still works for me. I did some lazy search on how to implement a
cronjob script within OVMS without success. So my "workaroud" for now
is to type a preventive
module reset
in the "Messages" command line within the app every morning (as long as
I'm still connected to my wifi).
This is a great example of "Turnschuhadmin" (sneaker admin) ...
Feature request: A simple cron implementation for scripting.
Or a hint on where to find such a feature within OVMS, if it already
exists.
Regards
Chris
Am Freitag, dem 21.07.2023 um 21:23 +0200 schrieb pi.uhl at bluewin.ch:
> At the moment I have the same problem with at least 3 customers of
> mine. WLAN doesn't work anymore either. The only solution is
> powerless and afterwards it works again for some time. I would
> appreciate to install a watchdog which makes a reset every 24 hours.
> Regards
> Pierre Uhl
> Von: OvmsDev <ovmsdev-bounces at lists.openvehicles.com> Im Auftrag von
> Gesendet: Samstag, 15. Juli 2023 15:33
> An: ovmsdev at lists.openvehicles.com
> Betreff: Re: [Ovmsdev] Modem - Last Error: User Interrupt
> With the constantly PoweringOn state my odyssee started with the 5360
> Modem.
> I recently changed to the 7600 and could not see anything obvious
> about "neglected" contacts.
> If this thing has no solution I'll write a script that does a reboot
> every 24 hours.
> Nothing we can't handle with a nice workaround ...
> Am Samstag, dem 15.07.2023 um 14:35 +0200 schrieb sharkcow:
> > Funny coincindence: my 5360 modem stopped working a few days ago
> > (constantly in state PoweringOn). I tried rebooting & a different
> > firmware to no avail. Just took the module out of the car, opened
> > it and
> > it ran fine on my workbench and then also back in the car... maybe
> > just
> > some bad contacts that needed some "love" :)
> > Am 14.07.23 um 19:47 schrieb Chris van der Meijden:
> > > After I upgraded my modem to a SIM7600 (and replaced my SIM card)
> > > I
> > > hoped the GSM would be running well again.
> > > I'm sorry to say that I still have issues. Every few days GSM
> > > will
> > > disconnect with "Last Error: User Interrupt". When it disconnects
> > > this
> > > way it won't connect anymore. Not even when I change location.
> > > Only
> > > after a "module reset" the connection comes back for another few
> > > days.
> > > The antenna I use is the internal antenna of the car. I had no
> > > issues
> > > like this last year. Same antenna then.
> > > Am I alone with this behauviour?
> > > Any ideas?
> > > Thanx
> > > Chris
> > > cellular status
> > > MODEM Status
> > > Model: SIM7600
> > > Network Registration: RegisteredHome
> > > Provider: congstar
> > > Signal: -77 dBm
> > > Mode: GSM;Online
> > > State: NetLoss
> > > Mux: Status up
> > > PPP: Not connected
> > > GPS: Not running
> > > module reset
> > > cellular status
> > > MODEM Status
> > > Model: SIM7600
> > > Provider: congstar
> > > Signal: -79 dBm
> > > Mode: LTE;Online
> > > State: NetMode
> > > Mux: Status up
> > > PPP: Connected on channel: #2
> > > GPS: Not running
> > > _______________________________________________
> > > OvmsDev mailing list
> > > OvmsDev at lists.openvehicles.com
> > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230721/893ca486/attachment-0001.htm>
