[Ovmsdev] Modem - Last Error: User Interrupt
    pi.uhl at bluewin.ch
    Sat Jul 22 03:23:26 HKT 2023
At the moment I have the same problem with at least 3 customers of mine. WLAN doesn't work anymore either. The only solution is powerless and afterwards it works again for some time. I would appreciate to install a watchdog which makes a reset every 24 hours.
Regards
Pierre Uhl
Von: OvmsDev <ovmsdev-bounces at lists.openvehicles.com> Im Auftrag von Chris van der Meijden
Gesendet: Samstag, 15. Juli 2023 15:33
An: ovmsdev at lists.openvehicles.com
Betreff: Re: [Ovmsdev] Modem - Last Error: User Interrupt
With the constantly PoweringOn state my odyssee started with the 5360 Modem.
I recently changed to the 7600 and could not see anything obvious about "neglected" contacts.
If this thing has no solution I'll write a script that does a reboot every 24 hours.
Nothing we can't handle with a nice workaround ...
Am Samstag, dem 15.07.2023 um 14:35 +0200 schrieb sharkcow:
Funny coincindence: my 5360 modem stopped working a few days ago
(constantly in state PoweringOn). I tried rebooting & a different
firmware to no avail. Just took the module out of the car, opened it and
it ran fine on my workbench and then also back in the car... maybe just
some bad contacts that needed some "love" :)
Am 14.07.23 um 19:47 schrieb Chris van der Meijden:
After I upgraded my modem to a SIM7600 (and replaced my SIM card) I
hoped the GSM would be running well again.
I'm sorry to say that I still have issues. Every few days GSM will
disconnect with "Last Error: User Interrupt". When it disconnects this
way it won't connect anymore. Not even when I change location. Only
after a "module reset" the connection comes back for another few days.
The antenna I use is the internal antenna of the car. I had no issues
like this last year. Same antenna then.
Am I alone with this behauviour?
Any ideas?
Thanx
Chris
cellular status
MODEM Status
Model: SIM7600
Network Registration: RegisteredHome
Provider: congstar
Signal: -77 dBm
Mode: GSM;Online
State: NetLoss
Mux: Status up
PPP: Not connected
GPS: Not running
module reset
cellular status
MODEM Status
Model: SIM7600
Provider: congstar
Signal: -79 dBm
Mode: LTE;Online
State: NetMode
Mux: Status up
PPP: Connected on channel: #2
GPS: Not running
OvmsDev mailing list
OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230721/5120c905/attachment.htm>
