[Ovmsdev] Hyundai Kona Electric devs?
    Michael Geddes
    Tue Jan 31 06:52:35 HKT 2023
It might be worth pulling a bunch of stuff I did for the Ioniq 5 down into
the common code..  I was able to drastically reduce the battery drain on
the I5.
If you have an OBDII device that is pulling data and you can sniff what
that is doing, that would be a way of doing it. But there certainly aren't
CAN messages just flying about the CAN bus on the I5.
//.ichael
On Tue, 31 Jan 2023 at 00:27, Peter Lord <peter at plord.co.uk> wrote:
> On 30 Jan 2023, at 09:58, Christos Oscar Kambiselis <ckambiselis at gmail.com>
> wrote:
> Are there devs that are focused mainly on the Kona? I would be willing to
> help with CAN data acquisition and interpretation, can't really help much
> on the software side since I only have basic knowledge.
> I did contribute a little to the Kona code, but I’ve not actually used
> OVMS recently due to concerns around 12v battery drain ( although that
> issues seems more likely due to poor quality 12v battery ).
> But are you saying you have a way to get CAN from the Kona ?  The OBDII
> port doesn’t share much what’s going on between the ECU’s, so I’ve yet to
> see a way to record much.
> Pete
> Peter Lord
> [image: Email] <peter at plord.co.uk> [image: Signal]
> <https://signal.me/#p/+447867970260> [image: Telegram]
> <https://telegram.me/PeterLord> [image: Github]
> <https://github.com/plord12> [image: Apple]
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230131/db37476b/attachment.htm>
